the anti skid computer in a 2005 prius
Discussion in 'Gen 2 Prius Technical Discussion' started by billsuea, Apr 20, 2011.
  1. billsuea
    billsuea New Member
    chicago
    bought a used 2005 prius 8 months ago. what is apparently the anti skid computer warning light is on and off intermittently. If this computer is faulty/not functioning, how is the car's performance effected. Does the car lose normal braking ability? I cannot feel any difference whether the dash lite is on or off...
    thanks, Bill
  2. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Thread moved from "File Library" to "Gen2 Technical Discussion"
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    It really depends on what's going on. Usually when the warning light is on, that means that most/all advanced braking functions are offline, such as ABS, traction control, and vehicle stability control. You can test this by finding a gravel/dirt road when the light is on, and seeing if you can lock up the wheels with a low speed panic stop.
    You could get the codes read at an auto parts store and report back if you would like further information.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    What is the condition of your tires? Do they have plenty of tread or are they worn?
