The [B] gear??
Discussion in 'Gen 2 Prius Main Forum' started by senectus, Feb 27, 2005.
  1. Frank Hudon
    Frank Hudon Senior Member
    4,147
    the difference using "B" in the Classic and the 2k4 is really noticable. The 2k4 drops speed better and faster, more powerful you bet. one day I'll do comparison on reg icons, as I notice the 2k3 is a lot better at regen than our 2k1 was. The 2k3 gets better mileage as well and that has been documented by Yellow Cab 15.
  2. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Attila on PriusOnline has been able to interface into the CAN and decipher quite a bit of info through a laptop/pda. I'll ask him to analyze B mode.
    By the way, a few times I have used B, once I stopped at a light while in B, my ICE did not until I got out of B. Normal 6 bar SOC. What gives?
  3. Frank Hudon
    4,147
    ICE runs all the time when in B stopped or not. Stopped it gets fuel to run and if moving the ICE runs with and without fuel as needed.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Not quite. On the 2G if you drop into when ICE is off AND you're going less than 20mph the ICE will not start up. Otherwise you're correct.
  5. Frank Hudon
    4,147
    your right on the less than 20. Where I get caught is at the bottom of the big hill on the way to work is pull up to the traffic light and sit there thinking why won't it stop look at the scanner and all parameters are right and then look at the shift indicator and sure enough it's in B. Put in D and have more coffee to wake up.
  6. DanMan32
    3,799
    27
    Tampa Bay, FL
    Why in the world did they do that? There's no justification for it. I might understand if they run MG1 to crank the engine unfueled to try and bleed off excess SOC that might have occured because of B, but it does not make sense to unconditionally burn fuel at a stop.
  7. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    Maybe they're doing it to remind you to take it out of B mode?
  8. PriusPhotog
    PriusPhotog New Member
    16
    Kansas
    I'm trying to get to the bottom of this gear question. When I test drove a 2005 Prius last month (yes, I got lucky and the local dealer had one on the lot!!) I talked a lot with the salesman. He was very knowledgable regarding the car and its many details. He had driven various Prius's many times and seemed to have quite a lot of personal driving experience.
    He encouraged me to plan ahead and to use the gear to break whenever possible. He said that driving was more efficient this way, and this seems to be at least partially backed up by the first paragraph of this Car and Driver Magazine review. Does anyone know if this is really true?
    http://www.caranddriver.com/article.asp?se...1&page_number=3
    I'd like to learn more about it before my new Prius arrives sometimes this month. Thanks!
  9. senectus
    senectus New Member
    111
    Perth, Western Australia
    LOVE this quote..
  10. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Measurements done by a few owners have provided data proving this false. They showed less regeneration occured when in ... which makes sense.
