The basic Tool Roll?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Polaris96, Dec 18, 2014.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
    It's NOT how you apply force. It's where you apply the force and how it is controlled that counts.
    Over the years, I've worked on many machines and mechanical devices.
    As for cars, if you are going to keep and maintain a car for a long time, one of the very least expensive things any owner can do is to spray a penetrating rustproofing compound on the bolts and moving metal parts in the engine area and under the chassis of he car in the early months of its life. It doesn't hurt, even if the car is used.
    Even if you don't work on you own car, it will likely prevent any mechanic from breaking rust frozen bolts and other parts. If the mechanic breaks a brake bleeding valve, who do you think pays for the repair placement?
    A couple of hours and $20-30 of spray cans can save you big bucks in the future.
    In the 45 years that I've own cars, I have not ever broken a rusted together bolt when removing it.
    edthefox5 likes this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Exactly.Been advocating spraying the chassis with an antiCorrosion since the car is new7 years later no rust anywhere. Pb blaster CSP was made for this. And works great. And don't clean the engine either. All your doingis accelerating corrosion.Ill keep my 3 foot extension pipe. Beating a breaker bar With a ball peen hammer is not a good idea.
    The wheel getting stuck on the hub is a really bad problem with a PriusLots of posts about that.
    When still new on first tire rotation I greased the wheelHub mating area with synthetic grease. Then put the wheel back on without the center cap. I filled the center cap wheel hole with Synthetic grease and put the cap back on. This keeps the axle nut from becoming a corroded mess. 65000 miles later the nut looks pretty good.
    Alto of folks have had better success loosening The lug nuts and lowering the jack on the loose wheel And it pops loose. I have not had an issue getting stuck yet.
    Mike500 likes this.
  3. Mike500
    2,593
    767
    It doesn't matter here you live. The space between fasteners are traps for water, debris and salt. The earlier you coat the spaces; the less likely corrosion will start there.
    There is a myth that ALL parts of the car are adequately protected from rust at the factory.
  4. Yakoma
    Yakoma Active Member
    470
    125
    sss
    OK...thinking of doing this. This is probably a stupid question, but assuming I have only some ramps, jackstands and a floor jack, what is the best way to do this without also applying anti-rust protectant to my entire body - not the car body, the person body.
  5. Polaris96
    Polaris96 Junior Member
    I realize the thread has grown a bit stale. In reply to Mr. Wong's comment on cheater bars, though.
    Many people, even many technicians, don't understand why a cheater bar is bad. So, here's a knowledge biscuit...
    It has to do with energy and a material quality called plastic deformation. I'll start with plastic deformation.
    Materials which can be stretched are called malleable materials. Most types of steel are malleable. but steels are also Resilient, which means are "springy". So we can think of steel as being able to absorb a certain amount of energy and then spring back to shape. If they have reached their maximum springiness and energy is still applied, they will stretch malleably and NOT return to shape after the force is removed. This point is called plastic deformation.
    As plastic deformation increase, strength radically decreases, eventually ending in failure. Think about breaking a paperclip by bending it back and forth. It starts out taking a bit of effort to bend the thing, but the more you work it back and forth, the easier it gets until the paper clip breaks. That's plastic deformation in action.
    SO we think of the strength of a normal metal as a curve. The strength remains constant in the resilient range and decreases in plastic deformation. When the strength reaches zero, the material fails.
    What does this have to do with cheater bars?
    Cheater bars add energy at a constant level. You're applying a torque equal to the length of the bar multiplied by the force you're pulling with. That doesn't change unless the bolt moves ... IF you remain within the resilient region of the object. If you apply too much force and drift into the plastic region, you will break the bolt. You will not be able to relax your pull quickly enough to avoid twisting it off. As the material deforms, the amount of energy required to keep it deforming drops until it fails and you've twisted it right off. If you worked in any of the trades that involve machines, you have done this numerous times.
    If you're smart, you got tired of it.
    Slugging (impact guns are slugging devices) SAVES material because force is applied is packets. When you whack the tire iron, you're maxing out the force. And then, there's a period of relaxation. This allows the material to "return to zero" all the internal energy is released and you start from square zero again. Engineers call this type of action "impulse" and it's much less likely to cause damage than a constant force approach.
    Impact guns aren't magic, they strike quicker than you can by hand. And you can break studs with slugging or an impact gun. It's harder, though.
    I could go further but this post is already too long. If you're interested, google it. The deeper you go, the more you'll understand why slugging beats wrenching.
    EDIT:
    Additionally, when you slug, you adding vibrations, which always helps free the part. Any kind of dynamic loading stresses material boundaries like the gunk that's clogging your threads or the rust film between the bolt head and the part. This is why, even if you MUST use plain torque (cheater bar) it's always a smart idea to take a few whacks at a frozen nut/bolt/stud with a ball peen before you start torqueing on it.
    #25 Polaris96, Dec 29, 2014
