The battery fires at ECU sense connector thread
Discussion in 'Generation 1 Prius Discussion' started by ChapmanF, Mar 19, 2015.
  1. OBJUAN
    OBJUAN Member
    166
    81
    canada
    The sense wires at the battery will be corroded as well. I made a new harness with the Aliexpress connector, 22AWG silicone wires and brass crimp rings. Had to salvage the larger square flat terminals to use on the main Neg and Positive cables, save the others as spare. I used water proof heat shrink to seal the sense wire ends at the battery. Good Luck
  2. Travis Sanders
    63
    27
    Hawaii
    So I did solder the wires on my gen 2 directly to the board today. I wasn't nearly as easy as using a heat gun would have been to replace the connector. It took quite a long time so all time included maybe it would be around break Even to simply buy the overpriced connector from eBay. But then you would still have the high voltage right next to each other problem in the connector which would eventually cause the same problem especially in wet areas or places of high humidity like the tropics where I am. So maybe soldering the wire is on like I have will be a permanent solution.
    SFO likes this.
  3. ChapmanF
    19,054
    The 290 would be a worst-case figure between two pins that are farthest apart electrically, but it looks like some thought went into how those pins are physically arranged in the connector. I looked at that some back in post #2:
    My lazy look there did, of course, come with an important asterisk:
    That's still a thing somebody less lazy than I am could do.
  4. dabard051
    dabard051 Tinkerer-in-Charge
    262
    98
    Rochester, NY USA
    2002 Prius
    Going through all the pictures of corroded/damaged ECU connector pins, it's always the two on the left that suffer the most damage.
    Does someone have a guess as to why that is?
    Do those pins have the highest average voltage w/r/t ground, even tho they carry no current (i.e., sense only)?
    If I remember correctly from earlier in the thread, the green stuff that grows is malachite, which has interesting conductivity v temperature characteristics.
    reference:
    Malachite (Cu2(CO3)(OH)2) | CH6Cu2O5 - PubChem
    Malachite Morphology — Part I | Rock & Gem Magazine
    https://en.wikipedia.org/wiki/Malachite
    I can't find an authoritative source for electrical and/or mechanical characteristics of malachite, so l ask for help from any chemists...
    PriFi and Travis Sanders like this.
  5. ChapmanF
    19,054
    The pinouts and most of the guesses are back on page 2 of this thread
    The battery fires at ECU sense connector thread | Page 2 | PriusChat
    including the link supplied by hobbit.
    Travis Sanders likes this.
  6. OBJUAN
    OBJUAN Member
    166
    81
    canada
    the battery negative posts all leak, a bit of condensation will make it travel.
  7. Freeport
    Freeport Junior Member
    Seattle
    Possible to use dielectric grease on the connectors to alleviate corrosion?
  8. Travis Sanders
    63
    27
    Hawaii
    Yes I tried it a few years ago and haven't had any issues on one of my cars. But it will collect dust and I thought that could be problematic
  9. 265chemic
    265chemic New Member
    QLD
    Well, I've read through this thread and thought I'd share my experience too. I wrote up a report about what I had found (attached PDF), albeit for a 2012 Camry Hybrid, not a Prius.
    Additionally, I have found a direct solder in sense board connector - ebay item 116188480840 (sorry I can't post links yet), which is also applicable to:
    2010-2015 Prius
    2012-2019 Prius C
    2012-2017 Prius V
    2012-2017 Camry Hybrid
    I was considering lopping off the board connector but leaving the pins, then using 22AWG balance wires like these: ebay item 256759708028 to connect to each row of 10 pins (its a 20pin connector, but only 18 are populated), splicing and heat shrinking to the factory battery side connections and remaining wires.
    I've also sent the report to my local Toyota dealer for comment.
    Sadly while the sense module is an available part, for my vehicle the sense harness itself is not.
