The beeping stopped
Discussion in 'Prius c Main Forum' started by Josh331, May 16, 2019.
  1. Josh331
    Josh331 Junior Member
    47
    Coeur d'Alene ID
    ya know when you close the door and it beeps three times, or when it locks it beeps once? Well mine slowly faded away, you no longer hear anything except the doors being locked when you press the handle. What exactly does this mean?
    52,862
    the beeper died? not sure i've heard of that before. check the 12v just for kicks
  3. Josh331
    47
    Coeur d'Alene ID
    Yeah it just slowly got quieter and quieter than disappeared completely.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Time for a hearing test ??
    That is offered only partly in jest.
    One can lose his high frequency hearing without really being aware of it.
    I found out when I could no longer hear the beep of an electronic kitchen timer.
  5. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    There's a beep when the door is closed? Just so you know, I'm being totally serious. Sam, you've got a 2017, your car beeps at you?
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes, for various things.
    Turn the headlights ON.
    Turn the car OFF.
    Open the drivers door.
  7. Josh331
    47
    Coeur d'Alene ID
    My 2012 c beeps three times when the doors close while the car is on. When off and you go to lock it it beeps once. And like I said now there is no beep
  8. bisco
    52,862
    if you want the beeper back, you'll likely need the schematic and a good sense of electrical troubleshooting.
    personally, i got along just fine before cars started beeping.
  9. bisco
    52,862
    do the lights flash when you lock the doors?
  10. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Mine doesn't do this at all. I hear a "tone" when I've left my keys in the ignition, but I have never heard any beep for anything at all.
  11. bisco
    52,862
  12. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    There is a setting that you can turn off or on in regards to the beeping notifications.
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    OK....tone.....beep.....under some circumstances, it should make SOME noise.
    Exactly which one may depend on the model that you have (trim level 1,2, 3 or 4).
  14. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    This explains why I don't hear anything apparently. :)
    ztanos likes this.
  15. Josh331
    47
    Coeur d'Alene ID
    Yes the lights still flash but no noise
