The BMW Volt?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, Mar 14, 2012.
  1. hill
    9,014
    I'd never heard of BMW's PHEV - the i8 ... but it sure got MY attention via the styling. But beyond styling, one necessarily thinks of the only factory PHEV on the road. If the Volt's characteristics aren't what they were originally touted to be, this may explain:
    The BMW Volt?
    Wow - I didn't realized there was a nexus between the 2 company's projects, or that a Volt program leader had jumped ship.
    If the i8 has PiP like capabilities, couple that with it's styling, then the only thing left to know is how (extreamly :p ) much?
    Wouldn't you think that with the guts worked on by both GM & BMW (although abandoned by GM), that the technology is sufficiently cross-licensed so as to prevent future litigation?
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Ok, at the end of the video, the driver stepped out of the vehicle to pee! LOL
  3. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    That blog post is unreliable. It says the Volt has an "Atkinson" gas engine which is not true.
    The business about the Volt design being changed to "not regenerate power by braking" is nonsense. The Volt has regenerative braking both via the brake pedal and when the Accelerator pedal is released (mild normally, relatively strong regeneration in 'L' "gear").
    The 2-mode program that BMW, Chrysler, and GM developed together has not been abandoned by GM. GM sells several large SUVs and pickup trucks that use the RWD version and they are working on a FWD variant of it for use in a Cruze plugin that may be released in 2014 to compete with the PiP and Ford Fusion Energi plugin.
    Frank Weber is German, I think, so it's not surprising that he might want to go back to Germany and develop plugin cars for BMW.
  4. Sergiospl
    3,938
    1,351
    28
    How the Chevy Volt Became a BMW - TheStreet
  5. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    It's nice to see BMW actually making an effort.
    Mercedes is probably still working on the next GLK-650 AMG that gets 11mpg. :rolleyes:
  6. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    Is this the same BMW that is airing commercials that say:
    We don't build hybrids, we don't build electric cars....we build BMWs?
    gotcha.
  7. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Does anyone have a bargepole I can borrow? I need to not touch that car.
    Luxury brand = high-margin price and higher margin maintenance.
  8. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    It's only about the money?
  9. Sergiospl
    3,938
    1,351
    28
    No, Its Not About The Money!
  10. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    Sorry, but actually, the Volt (At least the 2011 model) that I was looking at, and speaking with the Salesperson, does NOT have regenerative braking. And this is from the Chevy dealership I visited in Santa Barbara to fulfill my curiousity while he was trying to sell me on it and give up on my Prius v after I told him several times I was curious, but not interested in buying.
  11. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    That blog was full of misinformation. BMW & Mercedes have killed their two mode SUVs because of costs and built a lower priced hibrid system together. I doubt they are using two mode technology in there. The car is built for speed. It does have a turbo 3 cyl engine like the volt concept, but this is a 220 hp high power version using the latest tech. It also is a through the road hybrid, with front wheel/rear wheel/awd modes.
    BMW i8 Concept - First Look - Automobile Magazine
    Mercedes Presents Its First Extended Range EV - AutoObserver
    They are building a less expensive B class phev:D
    Car salesmen can be idiots. He was giving you bad information.
  12. Keiichi
    808
    79
    Goleta
    Mind you, the volt he was showing me was the 2011 model, which has that big gaping hole showing the cargo area and a 10/6 EPA Smog/Emissions. The 2012 models have no gaping hole in the rear seat area and a 10/8 EPA
  13. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    You believe car salespeople when they tell you technical details about a car? :)
    Try the Google instead. Try watching the power flow screen (similar to the one in the Prius) show (with a text title at the bottom) that power is being regenerated into the battery when you take your foot off the accelerator or press on the brake.
    Actually, the 2011 Volt can regenerate up to 60kW when braking at highway speeds which is way more than the Prius or PiP can regenerate into their battery packs.
    By switching from 'D' to the 'L' gear selector position you increase regeneration when the accelerator pedal is released and get around .1g of regenerative braking which is equivalent to light braking using the brake pedal but is guaranteed to not use friction braking. Stepping on the brake pedal will then add further regeneration.
    Here's a video posted by GM on their own social media website for the Volt which talks about regenerative braking:
    Chevrolet VoltAge - Volt Intuition: Regenerative Braking
  14. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The 2011 and 2012 Volt have identical seating arrangements.
    The ChevroletVoltage link I just posted was uploaded in May 2011 and was describing the 2011 Volt (details about the 2012 Volt had not yet been disclosed). I own a 2011 Volt and have read the service manual and the various SAE technical papers submitted by GM engineers about the car.
    The 2011 Volt has regenerative braking.
  15. Sergiospl
    3,938
    1,351
    28
    Glad they don't go into more complicated hybrids unless their current cars are known for;
    Better reliability,
    Lower emissions,
    Better gas mileage,
    Lower maintenance,
    compared to the competition
  16. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    It makes sense. Volt was supposed to be a pure series hybrid. GM decided to throw in the simplified 2-mode hybrid plugin from the discontinued Saturn VUE plugin. That's probably when the planetary gearset and 3 clutched came about.
  17. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    There's an optional thingie you can buy that fills up the gap between the rear seats. It's the same for both model years, you just saw one with it and one without.
    I'm not going to get it because my dog is going to love putting his nose through that gap :)
  18. Hildegard52
    Hildegard52 New Member
    us
  19. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Washington State, (Near Portland)
    Well, I guess we know that this car did not come equipped with luxury seats with the built-in urinal option.
    BMW, The Ultimate Driving Machine -- well not quite....
    Keith
  20. Sergiospl
    3,938
    1,351
    28
    20-mile all-electric range, Will they call it a Plug-in hybrid or an EV?
    Amusing, Autobloggreen is giving BMW credit for out-of-the-box thinking "20-mile all-electric range, then a 1.5-liter three-cylinder extended range".
    BMW nixes plan for M version of i8, but production car to have more power? [w/video]
