The Car Care Nut uncovers an exhaust pre-heater leak
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Georgina Rudkus, Jan 15, 2024.
  1. ColoradoBoo
    ColoradoBoo Senior Member
    1,240
    826
    Monument, Colorado USA
    So the TSB came out in 2019 so anybody with older Gen 4's need to be aware of the possible issue...check that coolant level often (at least weekly) and also look for white smoke out of the exhaust.
    I wonder how many folks had their head gasket replaced when that's not the root cause? Yikes
    Doug McC likes this.
  2. Doug McC
    Doug McC Senior Member
    1,079
    416
    Midwest
    2022 Prius
    AND test the coolant (like the maintenance schedule calls for) and change it when the test results indicate degradation of the coolant (ie: preform coolant system preventive maintenance). Regardless of the year.
    ColoradoBoo likes this.
    51,895
    so i guess the answer is, dealers can't read
  4. ColoradoBoo
    1,240
    826
    I just change it out every 5-years and did the 2017 last summer...only took a gallon and a half for both radiator and traction system.
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,131
    6,294
    Texas Hill Country
    Car Care Nut was late to the party on Gen3 Head Gaskets as well. In some of his early videos he stated he never saw one while working at the dealership. Of course relatively few bring their high mile cars to a dealership.
    In this case the gen4 heat exchanger problem is emerging, it’s not an infant mortality flaw, it is a higher mileage failure.
    Several clear distinctions from a hg; all four cylinders steam cleaned, fast coolant loss and the engine does not rattle on startup. Plus copious white smoke from exhaust which is only late end stage on a hg.
    If it were my car it would be bypassed and the thermal exhaust heat exchanger valve would be clamped open to the free flow state.
    Gen4
    (*1 Engine, *4 Exhaust Pipe Gas ControlActuator, *5 and *6 catalytic_converters, *9 Heat Recirculator, *e Exhaust Flow Control Valve )
    Pic from gen3
    Full TSB
    One open question in my mind is how the exhaust steam made it back to the very steam cleaned cylinders? He speculated it was late closing Atkinson cycle exhaust valves scavenging exhaust/steam; I wonder if it is not the gen4 egr_valve with its pickup after the cats?
    #25 rjparker, Jan 17, 2024
  6. Doug McC
    1,079
    416
    Midwest
    2022 Prius
    Perhaps a little of both. But once again, an ounce of prevention is worth a pound of cure. Rust and rust failure in a coolant system can easily be prevented.
  7. ChapmanF
    18,146
    I kind of wonder, if you say "whoa, look at this piston, it's been steam cleaned", and you end up saying that about all the pistons in the engine, were they maybe just clean?
