The Car Care Nut's Lexus CT200h engine rebuild
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Georgina Rudkus, Jun 18, 2023.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    Lexus Head Gasket Replacement Turns into a $6500 Engine Job. Was It Worth It?
    Interesting because it is basically a Gen 3 Prius engine.
  2. PriusCamper
    PriusCamper Senior Member
    13,449
    5,430
    Pacific Northwest, USA
    Seems like engine rebuilds are fast becoming obsolete with newer cars... Engine swaps are way cheaper these days. It didn't use to be like that. But as one dude on here who was going to rebuild his Gen3 himself found out, finding gasket kits for rebuilds ain't easy if not impossible.
  3. working1
    working1 Active Member
    121
    112
    Overall a really good video showing what is involved when, not if, this happens to the early gen 3's. My DYI replacement with a used 2014 w/80K was ~$3,500 in parts and 40 hours over 2 weeks. This likely has already been answered, but,
    - which model year starting using the new solid head gasket?
    - which software update reprogrammed the EGR?
    PriusCamper likes this.
  4. PriusCamper
    13,449
    5,430
    2015
  5. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    As he stated, frequent oil and coolant changes could extend the life of even early Gen 3 engines.
    Doug McC likes this.
  6. PriusCamper
    13,449
    5,430
    Makes sense... Of course coolant change in a Gen3 isn't so easy. I know lots of really talented mechanics who have worked on cars all their life who prefer to have it done at the stealership.
  7. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    Easy if you use the UView vacuum coolant refill system. Even Harbor Freight sells a clone.
    Cooling System Test and Refill Kit
    Takes only 20 minutes. No starting and restarting the car and setting it into inspection mode.
  8. PriusCamper
    13,449
    5,430
    I wonder if anyone has done a youtube video about doing it?
  9. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
  10. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    You realize that you are stating the obvious to folks that ignore the facts, right? ;)
  11. PriusCamper
    13,449
    5,430
    Capitalism would die a swift and horrible death if everyone was unwilling to ignore the facts...
  12. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    REALLY?????. Apparently you haven’t taken a realistic look at the situation in the United States.
