The charging cable cannot be unlocked.
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by pearl12970, Dec 13, 2018.
  1. pearl12970
    pearl12970 New Member
    Fremont,CA
    2018 Prius Prime
    I plugged in the charging cable at home to charge my Prius as usual . Had no resistance while plugging it in. When it was fully charged, I tried to remove the cable but it won't budge. I can't seem to unlock the charging cable. It won't let go! Anyone else had this issue? What is the solution?
  2. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    Did you inadvertently press the oval lock button when you plugged it in? It’s the one with the blue LED.
    Is your Key Fob working?
    If yes it should allow you to unlock that button manually when nearby.
