The cost of ChargePoint charging - worth it?
Discussion in 'Prime Plug-in Charging' started by DerekR, Oct 7, 2017.
  1. Pdog808
    Pdog808 Active Member
    431
    287
    Los Angeles
    2018 Prius Prime
    I personally go with a wash, then a Mother's Clay kit, then another wash, a coat of Klasse All-in-One then a final coat of Klasse High Gloss Sealant Glaze :)
  2. MMBH
    MMBH Member
    155
    43
    When he plugged in initially he wasn’t using the app as the courtesy cards came with the Toyota purchase initially so he wasn’t paying it out of pocket, but was noting that at that cost he wouldn’t be using them again in the future...
  3. MMBH
    MMBH Member
    155
    43
    Only able to run the ac and heat remotely if you have the Advanced model as far as I can tell... if I’m wrong please inform me as I’d love,to be able to do that in my Premium Prime!
  4. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    You can do that in the Premium as well.
    TGrracie likes this.
  5. CharlesH
    2,797
    1,163
    Roseville, CA
    But "remote" for the Premium means "within range of the key fob". For the Advanced, you can use the smartphone app anywhere you have cellular service.
  6. Glenn G
    Glenn G Member
    117
    63
    North Andover
    2018 Prius Prime
    That was not my experience. We stayed at a Hampton Inn whilst in RI. I noticed that they had a Charge Point station on the premises.
    ($1.00 for 1 hour but I'm new to this & thought I'd try it).
    The signage was very vague, I kept waiving my Credit Cards over the spot on the post (several cards - all with chips) and no luck. I called the assist number and they told me
    that I had to have an account with them (I think - very hard to hear them) to charge my car. They wanted to keep me on the line while I gave them my info for their card. I was standing off of the interstate with traffic roaring by, and couldn't hear them well, I hung up.
    Why not just accept credit cards?
  7. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    These stations use Near Field Communications. I don't believe you can find a credit card that supports that. Most modern cell phones do. Also you should have received a ChargePoint tag with your Prime. You will need a ChargePoint account with a linked credit card to use this service either with a cellphone app or the card I mentioned. I have been using them for close to a year without any issues. Just used one this afternoon to top my Prime off when I was at a meeting.
    Their app is very nice for locating stations near you and will tell you if there are available. I use my app all of the time.
    Team ChargePoint likes this.
  8. VTBIGDOG
    211
    146
    Some ChargePoint stations are free but you still need an account. I can use the tag I got with my Prime and I don't have a credit card linked to it, and it works fine.
  9. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I had the same question: why won't my credit cards with chips work?
    The answer is that the system uses a radio sensor which works with different technology than the basic credit card chip. You need a card with a NFC (near field communication) embedded device. These cards are identified by a symbol like this:
    As I noted, only my bank ATM/debit card had this symbol -- and it worked easily with ChargePoint.
    There is a more detailed explanation of NFC enabled cards on this web site.
  10. El Dobro
    El Dobro A Member
    7,088
    3,270
    My credit cards used to have that, but not anymore. I'll have to check my bank card.
  11. Dennis_MA
    185
    109
    Amherst, MA
    I would remove the numbers on your credit card on the post for security reasons.
    MMBH likes this.
  12. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    I recently set up a ChargePoint account (never set up the “free” account that came with the 2017 Prime). ChargePoint populated my iphone’s *wallet* with a virtual card. I was able to get a charge by holding my phone to the ChargePoint unit. I don’t know/recall if the unit actually started because of the ChargePoint *card*, or because of the credit card also in my iPhone’s wallet. It was a free unit.
    I found it strange that ChargePoint never asked for my bank, or credit card info. I’ll have to try another unit and pay closer attention to how it was activated.
  13. Team ChargePoint
    Team ChargePoint Active Member
    171
    106
    Campbell, CA
    Sounds like you've got it connected to your Apple Wallet, and if the station you used was a free station, you would not have been charged.
    :) Here's more on the Tap to Charge feature!
    CraigM likes this.
  14. Old Bear
    712
    1,050
    Of course! The image I used was from a Google image search. It is a card which is used for illustrative purposes and not a valid account number.
  15. CharlesH
    2,797
    1,163
    Roseville, CA
    All Visa/MasterCard credit cards in the US now come with the contact chip, bringing the US in sync with the rest of the world, where magnetic stripes long ago fell into disfavor. The main reason for them is security; while copying magnetic stripe cards is cheap and trivial, it is very difficult to "clone" a chip card.
    A few cards also support RFID (contactless, tap-and-pay), which, as noted above, can be identified by the WiFi-like symbol on the card. Interestingly, the Costco-branded Citi Visa card is one such RFID enabled card, which you can use to tap-and-pay at Costco gasoline stations.You can also tap-and-pay with these cards anywhere Apple-Pay/Google-Pay is supported (I have done it), since chip cards, RFID-enabled cards, and Apple/Google Pay all use the same underlying authentication system.
  16. Dennis_MA
    185
    109
    Amherst, MA
    That good to hear. Thanks
  17. My first EV
    My first EV Junior Member
    38
    16
    2018 Prius Prime
    Give it to me, give it to me!
    Oh, you Americans are lucky enough to have a “free card” and you don’t even need nor use!
    I am in Vancouver, Canada dealers don’t give us cards or info about charging, only full charge of my prime on delivery. But luckily most ChargePoint stations I used here are free. Most locations they charged for parking but the EV Charging is free! Had the Prime for 2 and 1/2 month only bought 19 litres (5+ gallons) of gas, and $1 for charging at a business area.
    Now everyone knows your credit card #
    #77 My first EV, Jan 19, 2019
  18. El Dobro
    El Dobro A Member
    7,088
    3,270
    You're just a tad too late. ;)
  19. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Hi Chargepoint,
    There's a new free Chargepoint charger in my town but no way to use it. I don't own any apps and I'm not buying a new phone so I can charge my car. When I go to the Chargepoint website and tell it "I'm new to Chargepoint/Sign up" to ask for a card it just takes me to ChargePoint, which is a blank page. The charger claims to be free but the cables are all locked into the unit. What should I do?
    #79 kenmce, Jan 26, 2019
  20. markabele
    5,084
    1,782
    Nebraska
    They will send you an RFID tag once you find a way to sign up online. But you must have an account to use the station.
