The dealer didn’t find what’s wrong with my prius
Discussion in 'Gen 3 Prius Main Forum' started by Mohammedzayi, Jun 26, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,252
    Anytime I see multiple problems like yours I think of grounds. Start with your battery negative ground, was it your right rear wheel you lost in that pothole? There are body grounds all over the car I would look at all wiring close to the wheel that was damaged.
    Another troubleshooting technique when you have multiple problems come up is to pick one problem, the one that is the least complicated to check and try to fix it and it could lead to what is causing all the problems.
    #21 padroo, Jun 27, 2018
  2. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    is the turd gen forum malfunctioning? I keep seeing this thread everywhere, or maybe the pinot noit wine is kicking in now. hopefully its the latter
    m.wynn, bisco and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    There are 3 or 4 threads on the exact same topic :(.
    Not the wine tonight at least (y).
    m.wynn, bisco and Grit like this.
  4. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Dam, wish it was the wine.
    whats worse, multiple posts of the same subject or people just not using the search feature and post redundant threads? #searchfeaturedeletemod :p
  5. Mohammedzayi
    Mohammedzayi Junior Member
    45
    Los angeles
    hello everybody
    I have a prius 2012 pack 3
    170.000 miles
    The story starts when I hit a pothole so badly
    I got at the same moment the message “CHECK HYBRID “ and “P LOCK MALFUNCTION “
    With the yellow triangle of death
    And when i push the brake the hubrid its not charging
    After i got the ABS AND TRACTION lights on
    One week after i got the” STEERING WHEEL “light on , and its hard to turn it
    O yeah also the charging bar for the hybrid in my dashboard blinking and flashing
    Do you guys think its the abs sensor? Or the abs module? Or its the brake sensor? Or its the rack and pinion ? Or its a loose cable?
    Please guys help :(
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    You have posted this several times. Y not just maintain a single thread, and follow the suggestions given you in the other threads you created?
    Johnny Cakes, Grit and Raytheeagle like this.
  7. Mohammedzayi
    45
    Los angeles
    I didnt get any answer
    Thats why
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    The questions asked in the other threads require inspection.
    If you lift the car up and pull the wheel (or have someone else do that), you’ll be able to determine what’s next.
    But in the absence of these inspections, we’ll continue to ask questions.
    m.wynn and ITBland like this.
  9. Mendel Leisk
    41,483
    Just post again in the other thread, say the problem continues. That'll bump the thread to the top of the new posts lists, and alert all the previous responders.
    As it is now, I have to look through your post history. And then, should I post in that thread or this?? It's never a good idea to create a new thread on an ongoing issue. Maybe asked the mods to delete this, and repost in the old thread?
    Johnny Cakes likes this.
  10. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Any rodent evidence?
    Have you disconnected the 12v for five minutes?
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    @Tideland Prius, is there any way you can merge this person's maze of threads about the same problem into one thread so folks can keep track of previous responses? It's splattered all over the place.
    Thanks.
  12. Mohammedzayi
    45
    Los angeles
    Thank you for your answer
    How can i check the ecu in the battery pack area ?
  13. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    IMG-20180130-WA0004.jpg IMG-20180130-WA0005.jpg IMG-20180130-WA0002.jpg You got to open up the battery pack cover, you'd have a full view of the ECU.
    You can also read it up on here on PC.
    PS: where you have the orange cabling, is the location of the battery ECU on the pictures above.
    If you can't handle this job, y not get someone paid to do it for you?
    malmon and Raytheeagle like this.
  14. Mohammedzayi
    45
    Los angeles
    I just opened and everything seems ok and everything is plugged correctly
  15. Mohammedzayi
    45
    Los angeles
    Its normal the i got the steering wheel light on?
    And its hard to turn it ?
  16. Mohammedzayi
    45
    Los angeles
    Here is the ecu area
  17. Mohammedzayi
    45
    Los angeles
    And also I noticed that when i try tu turn the car on
    I hear i click on the hybrid??
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Any pics of the rear wheel that went flat?
    I’d investigate that area and all wiring.
  19. Mohammedzayi
    45
    Los angeles
    I have the flat light on
  20. Mohammedzayi
    45
    Los angeles
    Here
