The dealer didn’t find what’s wrong with my prius
Discussion in 'Gen 3 Prius Main Forum' started by Mohammedzayi, Jun 26, 2018.
  1. Mohammedzayi
    Mohammedzayi Junior Member
    45
    Los angeles
    After i hit the car in a pothole i got everything (lights on)
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    So.....,.
    Have you removed the wheel and looked behind it?
    What’s it look like back there?
  3. Mohammedzayi
    45
    Los angeles
    Thers only one cable connected to the root
    And everything seems ok
    You think its the sensor ?
    Why i got always the sign of flat wheel ?
    You think if this is the problem that will cause all thos lights on the dashboard?
    Also the steering wheel light on and its hard to move it
    You think the problem is in the wheel area??
    51,966
    Raytheeagle likes this.
  5. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    If you hit a pothole and all the dash lights lit up, you have reason to believe that an investigation into the cause is warranted.
    I’d have a code reader able to understand the codes so it would reduce the amount of work I would have to do.
    There is a way to have the codes “blink” their cause, particularly for the ABS system.
    But if the speed sensor was damaged, it will affect the driving systems as it would signal that something isn’t right with that wheel and the car will not like that.
    You probably also damaged the TPMS sensor or the air pressure in the tire is low if that light is still in and wasn’t on prior to the pothole incident.
    Mohammedzayi and bisco like this.
  6. bisco
    51,966
    how do you check the air pressure?(n)
    Grit and Raytheeagle like this.
  7. Mohammedzayi
    45
    Los angeles
    You think that air pressure will give all this light on my dashboard??
  8. bisco
    51,966
    not if it's too high.
  9. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    No;).
    Those codes have a cause and will help determine what’s next.
  10. Mohammedzayi
    45
    Los angeles
    U0140
    U0124
    U0073
    U0123
    U0293
    U0126
  11. bisco
    51,966
    i notice they all start with U.(n)
    Mendel Leisk, Grit and Raytheeagle like this.
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    All loses of communication codes;).
    Unfortunately the hard drive on our desktop crashed and I lost all the repair manual downloads I had:(.
    With that many lost communication codes, I’d be looking at wiring and connections;).
  13. Mohammedzayi
    45
    Los angeles
    In what part of the car????!
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I’d start at the rear wheel and work from there;).
    This is where a jack and jack stands come in:).
    Take the wheel that sustained damage off and start looking at all wires and connections. Also look on the rear beam and see if there are any opportunities there.
    If this is above your pay grade, there are several shops around in your area that could help;).
    Good luck (y).
    Mohammedzayi likes this.
  15. Mohammedzayi
    45
    Los angeles
    Can you help me to find a video how
    To check the speed sensor
    And the brake sensor ?
  16. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Start with a visual inspection.
    If you see cracking or wires separated, or even pulled out, you’ve got your cause.
  17. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Does it boot to the login screen? I can try to help troubleshoot.
    SFO and Raytheeagle like this.
  18. Mohammedzayi
    45
    Los angeles
    There’s any cables in the rear bumper?
    If you can please helps to find a video explaining how to chack the 12 v battery too
  19. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    The click is the relays in the HV battery kicking in. It's right that way
    #59 Dxta, Jun 30, 2018
    Raytheeagle and Mohammedzayi like this.
  20. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Hard steering maybe you got a problem with the EPS.
    From your responses here, I think my(or our) suggestions to you, are above your abilities. Y not get that can diagnosed by someone, and you pay em? Saves you lots of stress, and time.
    Raytheeagle and Elektroingenieur like this.
