The dealer didn’t find what’s wrong with my prius
Discussion in 'Gen 3 Prius Main Forum' started by Mohammedzayi, Jun 26, 2018.
  1. Mohammedzayi
    Mohammedzayi Junior Member
    45
    Los angeles
    You mean the relays in this area?
  2. Mohammedzayi
    45
    Los angeles
    I start feeling that this is the problem :)
  3. Mohammedzayi
    45
    Los angeles
    SRMP
    SRMG
    SRMB
  4. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    Yes! The relays seems to be working perfectly.
  5. Mohammedzayi
    45
    Los angeles
    I don’t know
    How can I test em ?
    There’s any relation between thos relay and The lost communication??
    And the red steering wheel light??
  6. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    I think our responses kinda look lime a waste of time here.
    Several PC members and I have e asked you to get someone competent to fix that car, or take it to another dealership. You just not helping matters dude.
    My responses might be harsh, but I think that's what it is.
  7. padroo
    padroo Senior Member
    2,763
    2,252
    There are people who specialize in troubleshooting automotive electrical problems. A lot of independent garage owners use their services because even they don't have the expertise to find what is wrong. They pay these mobile technicians and then once they know what is wrong then they can fix the car. Some dealerships just don't have people who are good at troubleshooting. You might try locating someone in your area.
    10 Best Mobile Mechanics in Los Angeles, CA - Book Online | YourMechanic Repair
    Raytheeagle likes this.
  8. Tideland Prius
    16,534
    Merged the threads.
    jerrymildred likes this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Thanks, @Tideland Prius. At least they are all in one place, even if there's no way to get them in chronological order.
    It's becoming increasingly obvious that the OP doesn't have the background knowledge to even understand the answers to his questions and will never resolve the issue without taking it to a qualified shop. :(
  10. padroo
    2,763
    2,252
    Jerry, I see that a lot here where people don't have the knowledge or money to make expensive repairs and they really need their cars the next day to go to work and I really feel for them.
    A lot of good mechanics aren't electricians either, that is the problem when you go to your local dealer and become parts changers.
  11. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    There's been no progression from the OPs end even after a lot of helpful info and support, I can see this thread closed.
  12. Mohammedzayi
    45
    Los angeles
    I change everything on the car
    I take it to different mechanics to different dealers
    But all of them they don’t have any idea what’s wrong with the car
  13. bisco
    51,732
    frustrating
  14. Mohammedzayi
    45
    Los angeles
    Quick question
    If i have a problem in my steering wheel sensor
    Can that causing a LOST OF COMMUNICATION?
  15. Elektroingenieur
    2,515
    3,282
    Three Touring
    “Loss of communication” is a generic term. It means two or more of the car’s computer modules (electronic control units, ECUs) that were designed to communicate over a CAN or LIN bus were not able to do so. This could be caused by a problem with one or both of the ECUs involved or with a wire or connector.
    If there is a problem with the steering angle sensor or its wiring, then ECUs like the skid control ECU could report diagnostic trouble code U0126, Lost Communication with Steering Angle Sensor Module.
    There are, of course, many other loss of communication problems that don’t involve the steering angle sensor at all. For example, if the engine control module (ECM) were unable to communicate with the hybrid vehicle ECU, then the ECM could report DTC U0293, Lost Communication with HV ECU.
    malmon and Mohammedzayi like this.
  16. Mohammedzayi
    45
    Los angeles
    You right
    I have both codes
    U0126 and u0293
    I was checking right now the cables plugged to ecu (next to fuse box) and bingo the steering wheel is working after 3 weeks of non working
    I don’t know what wire exactly
    But i new problem appear
    When driving the car now its stopped suddenly
    And the sign READY disappear
  17. PokerMunkee
    PokerMunkee Junior Member
    34
    23
    Denver, CO
    Just crash it into a guardrail and have it totaled!
  18. bisco
    51,732
    check the inverter pump.
