The dreaded Check Hybrid System
Discussion in 'Gen 3 Prius Technical Discussion' started by SteveLee, Nov 29, 2017.
  1. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Got the warning, says to place it in park. Tried the 3 times on/off resent. No change. Don't have a battery tester. Did disconnect 12v and placed a charger on it for a few hours. No change. It does start the engine but it doesn't want me to go anywhere. Thoughts?
    amos likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius?
    Did you have the inverter software flash performed?
    Is the hybrid battery fan clean?
    Keep us posted (y).
    amos, bisco and SteveLee like this.
  3. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    You need to get the codes read in order to establish what’s wrong
    2010 Gen 3
    amos, SteveLee and Danny3xd like this.
  4. SteveLee
    645
    180
    North Carolina
    I
    145k miles, have not had inverter software flashed, fan and port are clean.
    Raytheeagle likes this.
  5. SteveLee
    645
    180
    North Carolina
    I
    Also has an OEM battery. I'm guessing the original.
  6. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    There was a recall for the inverter flash. You had the 2010 since new?
    SteveLee likes this.
  7. SteveLee
    645
    180
    North Carolina
    I
    No. Got it about a year 1.5 years ago. I didn't see that recall.
  8. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    It was many years ago.
    Check your VIN in the toyota system and you should see if it was done.
  9. SteveLee
    645
    180
    North Carolina
    I
    SOFTWARE UPDATE FOR MOTOR GENERATOR ECU AND POWER MANAGEMENT ECU ~|~DONE
    Would that be it?
  10. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    That’s it:).
    Do you have Techstream or know someone who does so the codes can be retrieved? That would be my next step ;).
    Keep us posted (y).
  11. SteveLee
    645
    180
    North Carolina
    I
    So could a bad 12v cause this issue? Is that likely with a 3-7 yo battery?
  12. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Did this message occur while in operation or on start-up? If during start-up, it could be the 12v, but if during operation, it could be the inverter.
    Only way to know is to get the codes read ;).
    I have the original 12 v battery in our 2010 Prius II purchased in August 2009 and still going strong:).
    Keep us posted (y).
  13. SteveLee
    645
    180
    North Carolina
    I
    Is there a recommended code reader setup for a smartphone?
  14. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    The Aps for smartphones won’t be able to read the hybrid specific codes you’re dealing with:(. I believe if you have an Android style phone, the Torque Pro app works but might not be able to get the specific codes (only pull the generic ones).
    I have an old laptop with Techstream loaded on it. Bought a $20 J2534 mini VCI cable off of Amazon that allows for pulling codes.
    Hope that helps (y).
  15. Jayw13702
    142
    170
    Plymouth UK
    I’m using obd fusion and that allows me to interrogate the hybrid system, however it was a 9.99 add on to the app, but worth it
    2010 Gen 3
  16. SteveLee
    645
    180
    North Carolina
    I
    It does, thank you. Since it doesn't want me to drive it, tells me to place it in park, I will have to figure out a way to get the codes read. Looking for turbulence in the inverter coolant might be an indication, yes?
  17. SteveLee
    645
    180
    North Carolina
    I
    Added to the Torque Pro app?
    Has anyone used the BlueDriver Bluetooth Professional OBDII Scan Tool?
  18. Jayw13702
    142
    170
    Plymouth UK
    Obd fusion is similar to torque but it’s a different app, available on iOS and Android
    2010 Gen 3
  19. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    That will only tell you if the inverter coolant pump is working. Haven’t heard of very many failures on the Gen3 with this, but it is possible. One symptom though is if you “overheat” the inverter loop, that car shuts down but will allow you to restart once the temps are better.
    Let us know the codes when you get them(y)
    amos likes this.
  20. Mendel Leisk
    40,586
    My first thought: check the hybrid system, lol. Seriously, I'd get the dealership to check for codes.
