The dreaded dealer diagnostics
Discussion in 'Newbie Forum' started by Turbodaddy, May 2, 2017.
  1. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Better watch out. I caught a ration of crap for suggesting that in circumstances like this.
    In this case, the shop even said it was bad.
    But there is no way that can cause false trouble codes to be set...... or can it ??
    Sorry, I couldn't resist.
  2. Turbodaddy
    Turbodaddy Junior Member
    Orleans, MA
    Thanks everyone, Ericbecky, I may give you a call. My home computer will not let me onto this forum, so I can only reply when at work. I hope I'll have a chance to take a closer look over the weekend (which is Sun and Mon for me). We've been running around in a cheapo Nissan Versa we rented for $107/wk. This is how people without resources live.. they can't scrounge up enough for a down payment so they end up renting. Next we'll be using taxis!
    RCO and bisco like this.
    52,662
    but at least you live in the land of milk and honey.;)
  4. Turbodaddy
    Orleans, MA
    So, today I checked the 12v aux battery (11.4 v after sitting for a week). 14.3v with engine running, so that seemed OK.
    - Next accessed the hybrid battery and checked voltage at each cell with car shut off. Numbered from passenger side...all were @ 8.04v to 8.07v except #1 @7.8v, #22 @6.8v, and # 28 @ 7.76v.
    -Removed all terminal connectors and cleaned all buss bars and fasteners and replaced. Checked voltage again and all pretty much same as 1st time.
    -Had to disconnect and reconnect auxillary battery a couple times before I could get the car to start, but it did, with all the bloody warning lights on. I decided to just try driving to see what would happen. Went about 20 miles, mostly highway at 40 to 60mph before the hybrid battery fan came on (had all the covers off, so felt top of pack...just slightly warm to the touch.) So I kept driving and everything seemed fine except for the stupid lights and the cooling fan.
    -I went about 32 miles in about an hour. Computer said I averaged 43mpg. The energy monitor looked as if everything was working too.
    -Also, the coolant control valve seems to be working since the heat works and the engine overheating light does NOT come on.
    - Checked voltage again after the drive and all cells were just about .5 volts higher (engine off) than before I drove it.
    Tired now, so I'm going home. Will see if any of you have comments later.
    Thanks.
    RCO likes this.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,450
    3,358
    Madison, Wisconsin
    I hope you do call. There are some clarifications that might be easier to do over the phone.
    Two strikes.
    First....
    11.4 v at rest after sitting a week is not so good. Maybe if the car was in accessory mode, foot on brake, headlights in high, and fan running - then I might be OK with 11.4v.
    Second...
    One module at 6.8v while the rest are at ~8.0v? Also not good.
    Rather than ignoring the problem and driving blind, you might be better off getting a cheap OBDII Bluetooth scanner and the Torque app. Then you could see some of the data live while driving.
    In any case the problem(s) need to be dealt with before more damage occurs.
    The coolant control valve generally will not affect the heat in your car.
    Here is a thread that describes how to fix it. P1121 - Coolant Control Valve Replacement (with pics) | PriusChat
    If you are short in cash, I'd skip the coolant valve issued or now and deal with the battery issue(s) first. The battery issues will make the car inoperable.
    RCO and Raytheeagle like this.
  6. Sam Spade
    2,036
    1,024
    2017 Prius c
    NO, likely wrong conclusion.
    With the engine running, you are measuring the CHARGING voltage, not the battery.
    11.4 is WAY low. The only way that might be "normal" is if it was driven on several short trips before being put away for the week.
    We could talk about a few possible things that could be causing excessive drain while it is OFF.......but the most likely culprit is the battery itself. It will "self discharge"; a tiny bit when new and much more as it gets older.
  7. Turbodaddy
    Orleans, MA
    This morning I realized that last night when I posted, I was thinking that it read 12.4...checked again today and it really was 11.4 which obviously is bad. Tried putting a charger on it today, waited till it read 14 volts, did the disconnect and reconnect thing and started it, no lights, drove about 18 miles and they did come back on.
    I've seen posts by people who have replaced one or two modules in the hybrid pack, looks pretty straight forward. Do you think that and a new 12v auxiliary might take care of it?
  8. ericbecky
    4,450
    3,358
    Madison, Wisconsin
    Hard to say.
    But a bad 12v battery can make the car present false codes.
    That's why I suggest checking the 12v first.
  9. Sam Spade
    2,036
    1,024
    2017 Prius c
    It should take care of PART of the problem.
    But it won't magically fix the weak cells in the HV pack.
    It might give you some time to think about what to do with the HV pack when it actually fails though.
    In my opinion, changing individual modules is a waste of time......because others are likely to fail soon.......and then others......might as well do them all, one way or another.
    This is a classic case of: Should I really invest more $$$ in fixing the car than it is worth, only with a slightly different face.
  10. Turbodaddy
    Orleans, MA
    Thanks again, there is a reason I am kinda determined to try and get some more life out of the car that I didn't mention in the beginning. About 2 weeks before this, after researching the expected life of the Prius (ex. Yellow Cab in San Francisco only uses them, and retires them at 300K miles). I made the decision to spend $800 to replace rear struts...car rides so nicely now!
  11. ericbecky
    4,450
    3,358
    Madison, Wisconsin
    They may get 300k miles, but I bet could do that they do that in less than 3 years.
    So in that respect the pack in you car has already lasted much longer than theirs.
    RCO likes this.
  12. Turbodaddy
    Orleans, MA
    So here we are, about 6 weeks later. I finally decided to go with a guy I found on C-list who is a Toyota technician who replaces hybrid batteries as a side business. He brings a reconditioned battery to you, exchanges it for your old one and puts it all back together again in about an hour. Then he connects his laptop and you go for a drive. If everything seems ok you pay him $650. He'll replace it if it fails within 2 months. We've put over 1000 miles and the car runs like new. It is so nice that I gave it a thorough detailing and am even thinking about having a dent fixed and replacing the cracked front bumper. My wife loves her car again!
    Dealer flat out lied about needing computers replaced, wrongly told my wife that the reason the hybrid battery failed (could have been) because the 3 way coolant valve was faulty ( it isn't, but a sensor is.) causing the battery to overheat!
    RCO likes this.
  13. Sam Spade
    2,036
    1,024
    2017 Prius c
    Did you ever ASK him what his "reconditioning" process actually does ??
    IF......he replaced only the weak modules, your happiness might be short lived.
    The two month warranty tends to indicate that the rebuild was not a complete exchange.
    RCO likes this.
  14. ericbecky
    4,450
    3,358
    Madison, Wisconsin
    Glad to hear it go your Prius back on the road for now.
    Plan on spend the same amount of money within the next 6 months. This is not a long term fix.
    RCO likes this.
