The Dreaded P0171
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by joeprius2018sea, Jun 20, 2022.
Tags:
  1. joeprius2018sea
    joeprius2018sea Junior Member
    Seattle
    I think the next step is to replace the fuel pump...just want to make sure.
    Car Info: 2012 Prius 4 175k
    Never took it to a dealer, just had a local mechanic take a look.
    Things I've tried:
    Clean MAF
    Replaced MAF (Denso)
    Smoke test for leaks - None
    Replaced O2 Sensor (Denso)
    Spark plugs done at 100k
    Any ideas, thoughts much appreciated it.
  2. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    MAF Wires and plug look ok? Maybe clean and inspect?
    How many miles and what other kind of maintenance over its lifespan?
  3. joeprius2018sea
    Seattle
    yes, MAF plug looks fine. I cleaned it first, no change, then I replaced it.
    175k miles, I've done all schedule maintenance on the Prius.
    I've had the P0171 code for almost 3 months now. At first, I would clear the code, it didn't come back for weeks. But now, if I clear it, it comes back after 20-30 miles.
  4. Half Vast
    Half Vast Junior Member
    36
    Suffolk, VA
    Have you looked at fuel delivery? Fuel pump, injectors? Found an interesting video which diagnoses it in a Prius. Could be something to check.
    michaud85 likes this.
  5. joeprius2018sea
    Seattle
    Thanks for the link, looks like he came to the same conclusion, replace fuel pump.
  6. Half Vast
    36
    Suffolk, VA
    If you have the ability, I'd perform the same test to see the waveform of the pump. That'll help eliminate the possibility of just blindly throwing parts (and money) at the problem. Good luck with this and post back what the fix is.
    PriusCamper likes this.
  7. PriusCamper
    13,455
    5,430
    Sure would be cool if we had some images or videos of the healthy wave form of various parts that fail on a Prius... That'd be an awesome resource. And for that matter, what's the least expensive way to get a scope that can do this?
  8. ChapmanF
    19,019
    There are pumps that fancy in a Prius, but I don't think the fuel pump is one of them. I think it just has power and ground; it's on or it's off.
  9. Half Vast
    36
    Suffolk, VA
    I have a Hantek 6022BE and find it quite useful. I use it with the same laptop that I have Techstream on. I got mine from Amazon.
  10. Half Vast
    36
    Suffolk, VA
    Found this video which breaks down testing on a lean running Prius engine. Thought it was quite informative.
  11. Half Vast
    36
    Suffolk, VA
    True in one aspect. I believe that since this is a brushless motor, it is commanded "on/off" by pulse code modulation. It is switching DC currents to the windings thereby causing the rotor to turn due to the expanding/collapsing magnetic fields. The waveform, taken from a current probe attached to one of the power leads on the pump gives an indication of the expand/collapse of the magnetic field within the motor.
    While watching the first video, I spotted the current probe attached to the fuel pump and knew exactly what the Tech was looking at.
  12. ChapmanF
    19,019
    I don't think so:
    Simple relay that applies 12 volts across the motor.
    There are other things in the car (engine water pump, inverter pump) that have separate connections for 12 V power and a pulse train input to set the speed. Not this one.
    It probably does have an interesting current waveform, as any motor would, just from the commutation happening inside it (whether that is done electronically or with brushes). That said, you're probably on your own to interpret that waveform, as it isn't one that Toyota mentions in their troubleshooting. They just have you check the motor's resistance, and whether it pumps when 12 volts are applied.
    The fact that a resistance is specified suggests to me that it is a conventional motor with brushes. An electronically-commutated one typically doesn't look much like a simple resistance across the terminals (you'd be trying to measure the 'resistance' of some active electronic circuit).
    Half Vast likes this.
  13. Mendel Leisk
    42,343
    Here's some Repair Manual excerpts. If they're pointing to other pages let me know; I'll try to find them.
  14. joeprius2018sea
    Seattle
    Thanks for all the info!
  15. Half Vast
    36
    Suffolk, VA
    I stand corrected.
    Without a manual nor any true experience with these cars (I've only had mine since March) I had to make some assumptions. I always enjoy reading your posts on the various topics here as I always learn something. I appreciate the detailed explanations.
    Still, I am curious as to the vast difference in the waveform's in the one video. Time for a bit more reading and learning.
    Thanks for posting these. I need to find a manual somewhere for my 3rd Gen.
  16. joeprius2018sea
    Seattle
    FYI - I got the fuel pump replaced. Drove 100 miles so far and the light haven't come back on. MPG is better now too.
    Got the parts from a dealer in CA.
    Fuel pump - 7702047081 $400
    O-ring - 7716906060 $15
    ASRDogman, Half Vast and Mendel Leisk like this.
  17. Half Vast
    36
    Suffolk, VA
    Awesome! Glad to hear you got it running again! Thanks for posting the follow-up. It'll help others down the road.
  18. Prius RT
    Prius RT Member
    131
    So did replacing fuel pump solve p0171 permanently?
  19. BlizzardBuzzard
    BlizzardBuzzard Junior Member
    Montana
    2015 Prius v wagon
    There's so much quality info in this post, I figured I'd reply here rather than start a new one. I assume I have a vacuum leak, but given the above info, maybe there's an issue on the fuel side leading to P0171. I did the EGR service and spark plugs 1000 miles ago and now it's throwing this code on the second sub-freezing morning at idle. The most likely scenario is that I didn't put a hose clamp back properly and there's a vacuum leak. It's 7 weeks to get an appointment. Any other ideas to try first? STFT is better at high RPM, worse at or around idle.
  20. ilovegirls
    ilovegirls Member
    178
    42
    San Diego
    It didn’t for me. Still trying to figure this out.
