The end of 3G cellular
Discussion in 'Prime Technical Discussion' started by Old Bear, Dec 23, 2021.
  1. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    If that bandwidth test takes as much data as Ookla does on my home Internet, just running that test once on my phone would consume half of my monthly data cap. I don't understand what people are doing with a phone that needs any kind of speed. You can't even see an improvement in video beyond 480p on a 6-inch device, so you can stream sharp, detailed video at a half of 3G speeds. What's the utility in minimizing the number of seconds it takes to reach your data cap or throttle point?
    Gokhan likes this.
  2. fuzzy1
    10,699
    Did you convert between bits and bytes? I don't recall seeing any (modern) data caps expressed in bits.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    That's beyond impressive. I just checked and my down and up speeds on 5G are both 12 Mbps. Apparently Verizon's 5G is pretty puny around here. I keep it turned off and use LTE since I can't see a real world performance issue and 5G is such a battery eater.
    Gokhan likes this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Haha, I have yet to experience 5G on my phone. I don't think there is a single tower in my nearby areas that is covered by 5G. I don't even get 4G all the time. I don't know what happens to my phone when 3G is finished. I do get some areas with only HPSA service now. Then again, it is not rare that I am in an area with no cell signal including my own house, so not having 3G for data is not going to be a problem.
    TGrracie, Gokhan and jerrymildred like this.
  5. privilege
    privilege Active Member
    659
    169
    Birmingham
    I've seen insanely fast speeds when the little doo hickey displays a good 5g signal. normally lte of the 4th generation variety will be about 1/10-1/4 the speed of 5th gen stuff.
    the battery life is pretty good, but this is a huge brick of a battery Kyocera tough phone.
    more than likely I'll upgrade to an iPhone to gain that tof3d sensor next. this phone has dtof but it's poorly implemented.
  6. jerrymildred
    11,517
    14,167
    Tampa, FL
    I've seen those recommendations, too. My iPhone 13 Pro has three options for 5G; Off, Auto, and On. Auto was the default, but I just turned it off since I'm not downloading huge files.
    I'm beginning to get the impression that they truck in your daylight on a logging road. :LOL: The nature nut in me would love that, but the geek part of me would go bonkers. :ROFLMAO:
    Salamander_King likes this.
  7. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Anyone have Xfinity cell phone service? I'm thinking of switching from Verizon. I have my phone set to use the Xfinity hotspots and find them to be much faster than Verizon 5g and sometimes get service with that when my Verizon signal is week.
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    When you have XFinity cellular service, the phone is configured to use Xfinity hotspots if available, otherwise use Verizon 4 or 5G for cellular service. If you have service directly with Verizon, you can configure your phone to use the Xfinity hotspots if you have Xfinity Internet service. The only functional difference is that when you get service from Xfinity, the phone is pre-configured to prefer the Xfinity hotspots. And the monthly cost may make one or the other preferable.
  9. Gokhan
    Gokhan Senior Member
    6,713
    2,661
    Paramount CA
    LOL Yes, that's why I am very afraid of running a speed test on 5G. I do it very rarely. Speedtest used 1.14 GB in that single test I did, which lasted for only a few seconds. I still have 8 GB/10 GB left on my $20 a month Mint Mobile plan with seven days to go; so, I am good.
  10. Gokhan
    6,713
    2,661
    Paramount CA
    Speedtest used 1.14 GB (gigabyte) in that single test.
    TGrracie and Salamander_King like this.
  11. Gokhan
    6,713
    2,661
    Paramount CA
    You live in the nature like the hippies. You don't even need a phone. ;)
    Salamander_King and jerrymildred like this.
  12. Gokhan
    6,713
    2,661
    Paramount CA
    That's because T-Mobile (or its mobile virtual network operator (MVNO) Mint Mobile) is the only carrier that has true 5G in the US. AT&T and Verizon only have pseudo 5G, as they don't have the proper frequency bands, which are in the mid-spectrum, to implement practical and efficient 5G.
    #32 Gokhan, Dec 31, 2021
  13. Salamander_King
    11,024
    8,978
    New England
    I rarely use my phone as a phone. My plan is $10 every three months prepaid SIM, I pay each call, text, and data (mb) as I go. I can top off any time, but I have never topped off my plan during the service period. Unused money carries over, but I still have to pay at least $10 every 3 months. I have accumulated over $100 on my plan so far since I only use ~$2 worth of service every three months.
    I don't mind digital detoxing for a while even now, but my work requires a constant connection to the server. Internet connection is a must. When I retire, I plan to build a tiny house with no connectivity to live completely off-grid. Yeah, then I may toss all my IoT gadgets, including computers and phones.
    I am glad I did not test my cellular data connection speed on my Pay-as-you-go phone. At the $0.10/mb rate I pay for Data on my pre-paid SIM, the test would have cost me $114!:eek:
    #33 Salamander_King, Dec 31, 2021
    Gokhan likes this.
  14. Rmay635703
    Rmay635703 Senior Member
    2,694
    1,726
    Somewhere in Wisconsin
    2013 Chevy Volt
    Honestly, the test doesn’t need to be over a meg to have pretty good accuracy, no idea why they don’t let you set the sample size
  15. PiPLosAngeles
    1,551
    724
    That's more than my data cap.
    Gokhan likes this.
  16. Gokhan
    6,713
    2,661
    Paramount CA
    You wouldn't have such a low data cap if you had 5G service.
  17. PiPLosAngeles
    1,551
    724
    Maybe, but my Verizon cellular bill wouldn't be $35.
  18. Gokhan
    6,713
    2,661
    Paramount CA
    That's your problem right there. You shouldn't be with Verizon or AT&T to begin with. With Mint Mobile, which is a T-Mobile MVNO, you get 4/10/15/unlimited GB for $15/20/25/30 a month, respectively, and 5G and better service as well.
    Cell Phone Plans with Unlimited Talk, Text & Data | Mint Mobile Plan Sale
  19. PiPLosAngeles
    1,551
    724
    TMobile's coverage around here is trash. Don't believe their maps, believe people with actual TMobile phones visiting your home/office. The also don't support my Pixel XL phone.
  20. Gokhan
    6,713
    2,661
    Paramount CA
    Any network will have coverage issues in certain pockets, depending on where their towers are. T-Mobile still has the best overall coverage. Always make sure that you have coverage at home and in the office. You can always try and switch back if it doesn't work out.
