The external system is not connected
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nbojaxhiu, Dec 8, 2016.
  1. nbojaxhiu
    nbojaxhiu New Member
    24
    kosovo
    Hi There,
    I have a 2004 Prius gen 2. Everything runs well thnx God! I have a problem with my MFD as mo0st of times it gives me message " The external system is not connected" and therefore I cant use the features of the MFD.
    I checked (diagnosed) the 12 V Auxiliary battery and it shows 14.1V which seems to be healthy.
    Any of you have any idea why cant connect the external system??
    Sometimes it works well and I can use the features and even make phone calla and use Navigation system.
    Thanks in advance!
  2. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Sorry I can't help with your communication error, but I will suggest you check the 12V battery in two other modes; 1) system off, 2) IG ON. If everything else is working, it's not likely to be a 12V error, but it's good to keep an eye on the battery. Your 14.1V reading is in "Ready" and it's charging from the hybrid system, which appears to be working.
    #2 andrewclaus, Dec 8, 2016
    nbojaxhiu likes this.
  3. nbojaxhiu
    24
    kosovo
    Thnx for the reply, i will follow up your advice and come back to you.
  4. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    Push the driver's seat all the way back and then check that the 2 (or 3) plugs on the front of the black box on the floor under the driver's seat have not been accidentally dislodged. It might pay to unplug and then plug each one back in to confirm that they are all connected properly.
    #4 dolj, Dec 9, 2016
  5. nbojaxhiu
    24
    kosovo
    i pushed the drivers seat and unplugged all plugs and plugged them back but situation remains the same. anyway thanks for the advise
  6. dolj
    dolj Senior Member
    8,633
    4,387
    Incidentally, was your Prius originally supplied new in your country or imported?
    If imported, from which country was it imported?
  7. nbojaxhiu
    24
    kosovo
  8. nbojaxhiu
    24
    kosovo
    can you confirm please if this battery is the proper one for prius 2004. thnx foto attached
  9. nbojaxhiu
    24
    kosovo
    Today it happened as usuall MFD did work but after 10 km drive everything came on working perfect with all features and didnt stop until i reached the destination. Again when started the trip didnt work MFD but after 10 km everything started working. can this be the battery issue or what could that be??? thnx
  10. andrewclaus
    993
    326
    Golden, CO
    At first glance probably not. I think the terminals are reversed, for one thing, and the vent hole is not visible.
  11. nbojaxhiu
    24
    kosovo
    Finally decided to change the 12V battery and got it with a good price. Varta B33, 45 AH compatible for Prius. the paid proce is 49.50 Euro. Can anyone advise if l should consider something when replacing it? Thnx
  12. andrewclaus
    993
    326
    Golden, CO
    If you don't have a repair manual, search online for instructions. You have to do some minor disassembly (cooling air duct and electrical modules) to replace the battery. Some fasteners may be hidden. There's also a vent tube for the battery itself. Electrically, it's very easy if the battery is compatible.
  13. nbojaxhiu
    24
    kosovo
    today l have personally changed the 12V battery as the old one was showing 9.2 V when vehicle on acc mode. But still even the battery changed i get the message " the external system not connected" means l have innoperative MFD. I thought the battery was the reason.
    I have put a Varta B33 which also has a vent hole but the hole seems to be smaller so l will install a smaller adapter to adjust the tube. Any ide why l this mesage come up and sometimes on a longer trip everything works well.thnx
  14. nbojaxhiu
    24
    kosovo
    Hi there, recently l have reported about MFD not beeing operative. I have studied a lot from experiences of others and removed MFD and went to a technician who did a resoldering of connectors and finally everything works perfect.
  15. shanoan Anderson
    shanoan Anderson New Member
    new york
    what does it mean when external system is not connected? my prius is saying that now
  16. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    See the post above yours.
    You might contact these folks also, as their specialty is the Prius. They carry parts from salvaged vehicles which will cost less if you have to get another MFD.
    Prius hybrids sales and service Scottsburg Indiana
