The father of Prius to become the next Chairman
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by usbseawolf2000, Jan 21, 2013.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    BTW, EPA said it takes 12.9 kWh to charge 2010 Volt rated for 35 miles. I am sure it'll take more to charge 38 miles in 2013 Volt.
    You can power your car, house or anything with electricity from wind, solar, geo thermal. At the end of the day, renewable makes up only 13% of all the electricity.
    Should we divert renewable electricity only to plugin cars and run everything else with fossil and nuclear electricity?
    Toyota's goal of the ultimate eco car is with respect to the environment, not for individual bragging rights.
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Volt is not a BEV, therefore not every "38 miles are done with 12kwh".
    When using Volt ICE, bear in mind you throw away lots of energy just becausethere is as answer to (in your own words...) "Why spend any additional money on a more efficient ICE?"
  3. John H
    John H Senior Member
    2,208
    558
    I am about 85% electric, with a 43 mile daily commute. I typically go for weeks as a BEV without the ICE, like many Volt drivers. The Volt is a BEV with a Range Extender.
    When the Volt is being used in the Range Extender mode, it is about the same fuel consumption as a Prius V.
    You didn't want to answer the question?
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Hey my PiP is BEV too then. I use it as BEV in the weekdays and use some gas in the weekend if I go out far.
    Usage has nothing to do with EV or not. It has two engines and two fuel tanks. That makes it a hybrid, the type that plugs in.
    Why spend any additional money on a more efficient EV operation of PiP? People won't put that many miles on it anyway. How about just throw in larger heavier battery to get maximum tax credit.
    Well, that's not Prius is about. Prius is about maximum efficiency and minimum emission in a practical affordable package. PiP retains those.
  5. John H
    2,208
    558
    usb, I think you are confusing "dual fuel" with "hybrid". would you call a vehicle that uses both propane and gasoline a hybrid?
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    If it has two separate engines, it is a hybrid. If it has two fuel tanks and one engine, it is dual fuel.
    The official SAE definition of a hybrid is "two or more energy storage systems both of which must provide propulsion power, either together or independently".
    The fact that you use both electricity and gasoline to propel your Volt makes it a hybrid. They don't need to propel with them together. They can be done independently at different time.
  7. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    USB is correct the volt is a hybrid, is an EREV which is a subclass of PHEV, which is a subclass of both Hybrid Vehicles and a subclass of Electric vehicles.
    The PiP is not a BEV, as it uses an ICE for propulsion. Its not an EREV as it does not have full performance in EV mode. Its just a mild PHEV.
  8. telmo744
    2,181
    769
    Portugal
    Efficiency is a measure of transformation from one energy to another.
    If electricity is produced in a thermal plant, noone can say 50mi out of a gallon can't be more efficient.
  9. John H
    2,208
    558
    Here is an EPA label for a 2011 Volt.
  10. austingreen
    austingreen Senior Member
    13,675
    4,213
    Austin, TX, USA
    I think we have gone far afield here. This is a thread about the guy that managed the prius project getting a promotion.
    There are other threads about the volt and energy switching. Why don't we have the the pissing match over on one of those.
  11. John H
    2,208
    558
    I think this is where the thread decided to take a journey.
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    As pointed out before, Volt neither has a full performance in EV mode.
    PiP is a plugin based on a full hybrid. 40 kW from the battery and 73 kW from the gas engine. 62 mph EV top speed. 114 mph top speed with gas. That sure looks like a full PHEV to me.
  13. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It makes you wonder about the team that worked on the Volt. Most of them are no longer working for GM. Interesting perspective.
    bwilson4web likes this.
  14. bwilson4web
    16,217
    No problem, especially if they are your privately owned wind farm. Same is true for micro-hydro, solar array, or home-distilled grain alcohol. These are all excellent sources. Just in the grand scheme of things, I don't think Volts are sold with an option to install these alternate sources of power.
  15. bwilson4web
    16,217
    I wonder how many former EV1 customers have become Volt adopters?
    But you are right, I sure see a lot of well trained and experienced GM EV and hybrid engineers working in other companies.
  16. John H
    2,208
    558
    Do you have a reference?
    If they are being recruited away, then one has to assume that the recruiter was happy with their performance at GM. I know a few were recruited by Tesla.
  17. austingreen
    13,675
    4,213
    Austin, TX, USA
    Somehow we should remember that GM went through bankruptcy while the volt project was in progress.
    Lutz was on the volt team - no longer at GM because he helped bankrupt the company. Good reason to get rid of him in spite of the volt.
    The rest of the folks that left got better positions at other companies with more money. Bankrupt companies often can not compete well for top talent. That seems to be a positive for the volt design, but a negative for GM.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  19. John H
    2,208
    558
    A handfull of people doesn't seem to equate to "most of them", unless you are proposing that the Volt was the product of a dozen individuals.
    Denise Gray is an interesting story, and RPI graduate !
    Posawatz goes from a director position at GM to CEO at Fisker, must be considered a bit of a success, albeit a bit risky.
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I meant most of the important players are gone. It seems they weren't promoted so they left. It doesn't appear to be the case with Prius and Toyota.
