The first scratches
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jaredy, Nov 1, 2012.
  1. jaredy
    jaredy Member
    162
    SoCal
    I just got the first scratches under the right corner of front bumper :(
    Is there any way which I can fix it by myself.
    :cry:
  2. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    You have learned how low the bumper is compared to curbs, I would not do anyhting till your used to low level damage. My 2012 has its share, but I'm not ready to replace the entire front end cover for a few dings, tears and scrapes.
  3. David Barton
    David Barton Junior Member
    29
    Bremerton, Washington
    Thats all the way down to the bumper, the only way to cover it up is to get touch up paint and paint over it but your still going to have the texture of the scratched bumper behind it. Only real way to fix it is to have it repainted, especially bc its pearl white.
  4. jaredy
    jaredy Member
    162
    SoCal
    The driveway steep has hurt my heart. It was on the bottom of front bumper. Actually nobody will see it unless I tell t and someone also would have his knees down.
  5. Mendel Leisk
    42,157
    ^ There you go then. With something like that, on plastic, only visible if you crouch down, I just leave them be (we have some similar "curb rash").
  6. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    And, unless you move, it's bound to happen again sooner or later. I vote leave it alone.
    I take steep driveways very slowly, and at an angle if I can.
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    This ought to fix it. Prob won't get 50MPG tho.
    jaredy likes this.
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I'd forget about it. Short of a professional repair (not cheap), even a DIY repair with touch up paint likely won't look much better, and since you have to go out of your way to see it, I wouldn't bother.
    Entering/exiting the driveway slowly at a 45 degree would also be my advice going forward. It's worked for me with cars with much worse front clearance.
  9. jaredy
    jaredy Member
    162
    SoCal
    This is the great solution I was looking for, but it will just ruin my MPG indeed.
