The Garage just got Crowded
Discussion in 'Prime Main Forum (2017-2022)' started by Raytheeagle, Apr 14, 2019.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    I have seen here some reported >40 miles on GOM, but my best has been ~35 miles only during very brief summer months. I am still waiting for a warmer temp. This morning low was 25F.:cry:
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    83 and sunny out here yesterday ;).
    Perfect weather for extending the distance traveled on electricity :).
    The best part is the amount of gas consumed as this was 300 miles this week and all I used was less than 1/8 of a tank. It makes the guys on “Silverado Row” think a bit(y).
    m.wynn, mikey_t and Salamander_King like this.
  3. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    So I've been reading that the ICE in the Prime will NOT initially start for a short period to 'warm up the catalytic converter' like it does in the Gen3's and presumably non-Prime Gen4's. It seems to me that it would need to to the same 'catalytic converter warming' in anticipation of the ICE starting at some point. What magic does the Prime do to avoid this?
  4. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    From what I can tell, after you deplete the charge, it appears that the Prime still has room in the pack as if it were a normal Prius. So when the meter goes to 0%, there is charge in the pack to continue operation.
    But it is nice not to have the warmup penalty(y).
    Arctic_White likes this.
  5. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I know that the P.Prime does run the cooling water past “the cat” (at least on the 2017 model). Of course the reason for this is not to cool the catalytic converter, but to warm up the engine quickly — to shorten that ever-annoying warm-up cycle.
    Of course the other thing that shortens the warm-up cycle is turning down the cabin-temperature setting. If the cabin temperature is set high, it will warm up the engine, not just to a bare minimum, but to where it can warm the cabin to that temperature.
    Annoyingly, it will do that even if you’ve since told it to switch back to EV mode! It will continue burning gas to go well above the minimum temperature needed, and only then shut it off and go to EV operation!
  6. farmecologist
    1,960
    1,801
    Southern MN
    Ok so there is a cat warmup phase. I was hoping the Prime warmed the car electrically or something...
  7. mr88cet
    2,313
    1,335
    Austin, TX
    So, when you’re in EV mode, it will use its heat pump to warm the cabin, which is indeed strictly electrically-powered. However, if anything switches it over to HV operation, it will promptly turn off the heat pump and switch over to engine warming.
    The point of course is that “the cat” warms up really quickly, and to a quite-high temperatures, due to the chemical reactions going on in it.
    kevin.c and jerrymildred like this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    When the Prime's battery is down to where it's out of EV range if I remember right, it still has more energy stored than the regular hatchback when it's at 80%.
    m.wynn, padroo and Raytheeagle like this.
  9. mr88cet
    2,313
    1,335
    Austin, TX
    I suspect that’s why it gets slightly higher MPG in HV mode: It can postpone firing up the engine longer, until it’s confident that it can drive a higher efficiency. That, plus, with its sprague clutch, it can electrically dive higher torques without having to fire up the ICE.
    jerrymildred likes this.
  10. kevin.c
    kevin.c Member
    98
    76
    sf bay area
    Also the power split device has 3 planet gears instead of 4, and the body has less drag
  11. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    You ever get a Prime :whistle:?
    Concord Toyota gave me a good deal if still looking(y).
    kevin.c likes this.
  12. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Whoever gets your 2010 will get the best maintained gen 3 on the planet. Anything special that you will do to maintain the Prime?
    We were lucky to get the first 2019 Rav4 hybrid in southern Colorado two weeks ago, happened to come in equipped exactly as we wanted and they gave us a fair deal despite the scarcity, a Limited trim with weather and tech packages. We are indeed getting over 40 mpg (displayed) despite challenging conditions (lots of altitude changes, some short trips, etc.). 500 miles on the first tank. I'm keeping my Prius, so we are a two hybrid family. I'll post a review in the "other cars" section soon.
    #72 royrose, Apr 20, 2019
  13. Tideland Prius
    16,683
    Congrats @royrose on the RAV4 Hybrid! 40 mpg is fantastic. Looking forward to your review.
  14. padroo
    padroo Senior Member
    2,763
    2,253
    Toyota leads, others follow.:)
  15. kevin.c
    kevin.c Member
    98
    76
    sf bay area
    Sitting in the dealership right now thanks to Costco auto referral! Thought I’d check out the deal but the “2020 tidbits” thread is giving me pause.
    jerrymildred and Raytheeagle like this.
  16. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Meh, remember this when that urge to wait occurs:
    1D9EE1A3-9C78-4C32-8A01-6E5E053D3DC5.jpeg 4087DBD4-09B4-4811-97F6-DE5F374252DD.jpeg
    That’ll help ease the conversion (y).
    padroo and kevin.c like this.
  17. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    The gentleman that will be buying our 2010 feels fortunate ;).
    For the Prime, I’ll be doing a trans axle fluid drain and fill along with an oil change at the 5k mileage mark. And @The Critic and I will put it up on the lift at some point to take a peek underneath :).
    But the oil may not see much use by the 5k mileage mark, given how infrequent gas is consumed (I’ve only used 1/16th of a tank during a normal commuting week). But I’ll take that(y).
  18. jerrymildred
    11,517
    14,171
    Tampa, FL
    They let me take a look when I got my tires yesterday. Really not much to see. Almost all the hardware is behind the Tupperware. :D
  19. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Oh we’ll get all of that off;).
    Then We’ll get a true lay of the land view (y).
  20. jerrymildred
    11,517
    14,171
    Tampa, FL
    I was mainly interested in looking at the condition of the covers and getting my eyes on that front floor jack point.
