the gas bladder: exposed!
Discussion in 'Gen 2 Prius Technical Discussion' started by galaxee, Apr 6, 2007.
  1. Dan-Wolfe
    Dan-Wolfe Member
    166
    31
    North Canton, Stark, Ohio, USA
    <div class='quotetop'>QUOTE(Bill Merchant @ Apr 7 2007, 01:32 AM) [snapback]419229[/snapback]</div>
    $1,000 is about what I paid to have the fuel bladder/tank assembly replaced when I received a tank of contaminated gas from a Navy Exchange gas station. Fortunately, Citgo, the Navy contractor who confirmed supplying the contaminated gas, paid for the repair lock, stock and bladder. I was lucky.
    Dan
    golfmk681 likes this.
  2. hill
    9,039
    <div class='quotetop'>QUOTE(aaf709 @ Apr 7 2007, 03:16 AM) [snapback]419276[/snapback]</div>
    No Kidding! Very Bitchin. would have liked to have been there.
  3. RonH
    RonH Member
    556
    <div class='quotetop'>QUOTE(Oxo @ Apr 7 2007, 12:35 PM) [snapback]419418[/snapback]</div>
    Now we know why the over-designed Prius is so much more life-cycle costly than the Hummer with its tin can tank!
  4. adam1991
    adam1991 New Member
    218
    More info on the fuel and EVAP system:
    http://www.autoshop101.com/forms/Hybrid13.pdf
    Please note the admonition to use 87 octane gas, and only 87 octane gas, in the Prius.
    No, America--bigger numbers aren't better. More isn't better. I know y'all want so desperately to believe that more is better, but it isn't. More is just more.
  5. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    <div class='quotetop'>QUOTE(bwilson4web @ Apr 7 2007, 04:20 AM) [snapback]419307[/snapback]</div>
    one hole contains the vapor pressure sensor and the other contains the trap.
    don't have to take out the rear axle to remove the tank. just the center exhaust pipe.
    <div class='quotetop'>QUOTE(hobbit @ Apr 7 2007, 09:55 AM) [snapback]419349[/snapback]</div>
    haha, not quite.
    couple points.
    the overfill fuel goes through the check valve and runs into the charcoal canister. from there if there's still gas running in there it can also get into the space between the bladder and the tank through the evap lines.
    as far as serviceability goes, the bladder is the complication here with the sealing of everything and all that. for the non-bladder car you can drop in a new fuel pump/sending unit assy no problem. don't know how they work it for the sealed metal tanks in the hycam and hihy.
    <div class='quotetop'>QUOTE(bwilson4web @ Apr 7 2007, 11:39 AM) [snapback]419385[/snapback]</div>
    tank won't come out through the cabin in any car. and thanks, given the current funding climate i'm not holding my breath but it's good experience.
    nope, you guys don't have to deal with the bladder thing. DH has never seen a prius non-bladder tank so we couldn't tell ya. over here they all have them.
  6. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    <div class='quotetop'>QUOTE(galaxee @ Apr 7 2007, 08:06 PM) [snapback]419632[/snapback]</div>
    Thanks. So this raises the question of why the bladder is there anyway. I think this has been explained on PC before but I can't remember the answer although I think it's some sort of safety measure. Perhaps it's a requirement of US legislation?
    Incidentally I find the filler opening a bit too small for the nozzle when I fill up. It shuts off if I put it in as far as it will go so I have to hold it much nearer the opening and even then it shuts off after taking a gallon or so and I have to withdraw the nozzle a bit further.
  7. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    WOW Galaxee, thats entirely cool!!! Bet it was a lot of work though....
    Oh, and good luck on the grant writing!! B)
  8. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    <div class='quotetop'>QUOTE(Oxo @ Apr 8 2007, 04:25 AM) [snapback]419766[/snapback]</div>
    The bladder reduces evaporative losses even more, allowing the (I can't remember the correct term, so UBER Environmentally friendly) rating for the car. ;)
  9. 8AA
    8AA Active Member
    550
    62
    Maryland
    Galaxee,
    Thanks for taking the time to post the pictures and the explanations. And please pass on my thanks to "DH" for taking the time to perform the arduous disassembly.
  10. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    <div class='quotetop'>QUOTE(Oxo @ Apr 8 2007, 03:25 AM) [snapback]419766[/snapback]</div>
    The bladder helps meet [partial] zero emission standards on the US west coast (and BC Canada) and some New England states in the north east US. It is not for US Federal standards, but to meet State standards, since the Federal government refuses to lead and has been denying its ability to regulate tail-pipe emissions. It would be better if ALL Prius had the bladder tank. I'm somewhat surprised that the EU isn't more on top of this since they seem to love regulation.
    [Edited for clarity. The goal is to reduce emissions and green house gasses as much as possible. The Prius IS a zero emissions car, when the ICE isn't running.]
  11. darelldd
    6,059
    389
    Northern CA
    I don't think I've ever been more happy to be driving a car with no fuel tank. :D
  12. adam1991
    adam1991 New Member
    218
    But the Prius isn't a zero emissions car, so why does that matter?
  13. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(adam1991 @ Apr 9 2007, 05:14 AM) [snapback]420180[/snapback]</div>
    It's a PZEV and helps meet that standard...Bill mistyped a little.
  14. larkinmj
    larkinmj New Member
    1,996
    <div class='quotetop'>QUOTE(Dan-Wolfe @ Apr 7 2007, 01:45 PM) [snapback]419423[/snapback]</div>
    Dan,
    Was that an isolated incident, or was there a major problem with the supplier? I usually get my gas at a Citgo station on the Navy base in Newport, RI.
  15. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(efusco @ Apr 9 2007, 05:56 AM) [snapback]420214[/snapback]</div>
    Indeed. PARTIAL Zero Emission Vehicle. Almost as non-sensical as "Super Ultra Low Emission Vehicle." These guys just crack me up.
  16. Mr.Vanvandenburg
    1,361
    664
    2020 Prius Prime
    Is this a rigid plastic tank (like most cars have) within a metal tank, or a "bladder?" It looks like a good device, and I can understand why we pay a little more for the Prius. That was a lot of work. It would be interesting to see a Toyota oil flter's innards to see if it is as special as they claim.
  17. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(Mr.Vanvandenburg @ Apr 9 2007, 03:13 PM) [snapback]420415[/snapback]</div>
    Unless I misunderstood your question:
    Yep, it's a bladder. It's flexible and collapses as it's emptied.
    Dave M.
  18. adam1991
    adam1991 New Member
    218
    <div class='quotetop'>QUOTE(darelldd @ Apr 9 2007, 12:33 PM) [snapback]420313[/snapback]</div>
    I'm with you. Orwellian language strikes again!
    Carlin nailed this one 30+ years ago: semi-boneless ham? JUMBO shrimp? And now we have partial zero emissions? What part of zero are they missing?
    From the guy who edits Games magazine: a driver saw a license plate on the road that said 1DIV0. What kind of car was it on?
  19. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(adam1991 @ Apr 9 2007, 03:59 PM) [snapback]420453[/snapback]</div>
    Is there actually a car named "Infinity"?
    It does seem I've heard of one.
    Dave M.
    P.S. Is that its fuel consumption? Sorry. Couldn't resist.
  20. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(dmckinstry @ Apr 9 2007, 07:30 PM) [snapback]420582[/snapback]</div>
    Close, it is spelled with four i's and no y's.
