the gas bladder: exposed!
Discussion in 'Gen 2 Prius Technical Discussion' started by galaxee, Apr 6, 2007.
  1. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    Wow, amazing. Please thank your husband. He loves you sooooooooooooooooooooooooo much!
    Good luck with the grant, I know that drill all too well. It was probably a good activity for him to stay away while you were writing (maybe it was a survival thing for him as well as a loving gesture). Most everyone I know stay clear of me while I'm in grant writing mode!
  2. kiwiruss
    kiwiruss New Member
    29
    Great job on the pics and disecting of the tank.
    better you than me.
  3. tochatihu
    tochatihu Senior Member
    9,987
    3,854
    Kunming Yunnan China
    2001 Prius
    Wow! hope he wore earplugs during the cutting open.
    We usta talk about using compressed air (or similar) to get 'kinks' out of the bladder if it presented reduced capacity. But seeing the pictures, it seems unlikely that such an effort would help.
  4. KTPhil
    KTPhil Active Member
    1,379
    22
    Do I understand the photos right in observing that inside a sealed metal container (the "tank") are a bunch of clamped rubber hoses and plastic parts? I hate to think what happens after 10 years or so, as most rubber deteriorates during that time. No way to access any of it, so the whole assembly gets replaced, assuming that parts are even available. You had to cut it open to see any of this, right, so it's all sealed inside?
  5. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    KTPhil,
    don't worry too much about the hoses. they're not exposed to the elements (well, heat and cold, yes) like other rubber hoses that deteriorate.
  6. bwilson4web
    16,537
    Could the extra gas found in the tank be drained and purged without disassembly of the tank?
    I'm wondering if the tank were turned upside down, could the spilled gas collect close enough to the two holes to be swabbed out? Then perhaps, safely, air be blown in one hole and exhausted out the other to get the last of the fumes?
    I'm thinking in terms of avoiding the $1,000 tank replacement. It might take a little time and safety would be a concern. However, it might salvage a tank. Of course a salvage tank might be a faster answer.
    Any ideas on how one might get a salvage tank? No, I don't have a bad tank but it is an avoidable but real risk . . . stuff happens.
    Thanks,
  7. SunnyvalePrius
    SunnyvalePrius New Member
    107
    <div class='quotetop'>QUOTE(bwilson4web @ Apr 13 2007, 08:24 AM) [snapback]422629[/snapback]</div>
    Perhaps running a water and detergent solution through the tank would also help coax out the extra gas.
  8. galaxee
    9,810
    471
    MD
    the space between the bladder and metal tank is really only meant to handle small amounts of vapor. i mean, i suppose that one could go about doing that and get a bit of it but i'd imagine the cost of labor to do that would exceed the cost of new tank + labor to remove/reinstall.
    to even get gas in there you've got to have some major damage anyway... in this case it ran through the charcoal canister.
  9. bwilson4web
    16,537
    <div class='quotetop'>QUOTE(galaxee @ Apr 13 2007, 10:48 AM) [snapback]422668[/snapback]</div>
    Like most things in life, there is a trade-off. It would not make sense for a repair shop but for an individual with more time than money . . .
    On the charcoal canister, I thought it was external to the tank. I agree that a gasoline soaked canister had pretty much reached the end of its design life.
  10. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    In my experience, even if you fill the canister with liquid fuel, it will still be fine once you remove the fuel. Usually they will clean themselves out by evaporation, though it will take time. The cars systems will not be "happy" (mil light and trouble code) while that is going on, if they can detect it.
  11. Mr.Vanvandenburg
    1,361
    664
    2020 Prius Prime
    I was thinking the same thing about the internal hoses, but saw the fuel tank is covered under the 15/150000 emissions defect warranty in CA states. I shouldn't have to worry how to put gas in my car. If mine gets this problem, it is going to the dealer. I only put gas in once so far and it showed full without any problems. I assume this occurs only with extreme cases of topping off. Anyway all cars have rubber hoses to the tank and they seem to last nearly forever.
  12. bwilson4web
    16,537
    As I was adding a gallon to the tank from my spare gas can, I noticed the gurgling and realized that the bladder means we don't have gasoline saturated air coming from the tank. If every USA car had a bladder tank, we wouldn't need those dang 'fume traps' and seals that never seem to really work right.
  13. galaxee
    9,810
    471
    MD
    <div class='quotetop'>QUOTE(David Beale @ Apr 13 2007, 12:50 PM) [snapback]422724[/snapback]</div>
    the prius has an exceptionally small charcoal canister. once inundated with fuel, it's ruined and it has to be replaced.
  14. bwilson4web
    16,537
    I wonder if you'll be reporting any more details about the small, white plastic pump-tank assembly?
    The reason is I have been performing gasoline energy tests and have been running my NHW11 03 Prius tank dry, to engine fuel starvation. So far, I've gone, 130, 70 and 80 miles under the "blinking" low fuel indicator with an MFD display of ~55 MPG. This suggests there is about 1.4-1.5 gallons remaining after the low fuel indicator comes on. Knowing the capacity of the small, white tank might give some insights as to how that mechanism works.
    In particular, I'd like to know if the the level of the bladder tank is the same as the white tank or is the fuel 'pumped' from the bladder into the white tank and then pumped to the injectors?
    In aviation and motorcycles, we have a concept of a 'pony tank' or a small amount of fuel that is the absolute last in the system. Once we're into that quantity, that is it, prepare for engine stoppage in a fairly short time period.
    It also relates to use of fuel for pump cooling. If the the white 'pony' tank is mostly full because it first pumps in from the bladder, then there would be plenty of gas for cooling until the very last 1/4 gallon.
    BTW, if you lose interest in the little tank, let me know and we might be able to 'do a deal.'
    Thanks,
  15. galaxee
    9,810
    471
    MD
    Bob,
    check the OP again, i did add in pics of the sub-assy after he took it apart. i should have made that more clear.
  16. bwilson4web
    16,537
    <div class='quotetop'>QUOTE(galaxee @ Apr 25 2007, 10:38 AM) [snapback]429782[/snapback]</div>
    Thanks!!
    It looks like the bottom of the 'all in one' box is gravity fed from the bottom of the bladder. This means the 'unusable fuel' would be what pools around the side and doesn't drain into the 'all in one box' and reach the fuel pump pickup port.
    Could you hazard a guess about the relative height of the fuel pump take up port and the bottoms of the 'all in one box' and the bladder? I'm trying to figure out where any residual gasoline might reside and rough order volume.
    Any possibility of another photo or two with a ruler so we can figure out the rough dimensions?
    Also, if you would, please measure the minimum and maximum resistance of the two variable resistance arrays. There were some early reports about the voltages measured from the sending units and the step functions were consistent with the resistance array shown in the photo. Knowing the resistance ranges gives us insights about the actual circuit including the fixed resistor and likely drive voltages.
    Can you tell if the fuel pump motor has brushes or is it a brushless design (only because I'm curious.)
    Thanks,
    ps. Sorry I missed the update. Great photos!
  17. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    Very nice! :blink: OMG! So much for thinking its just a standard gas tank like the older cars.....
    Theres alot of stuff inside of the metal covers...... :mellow:
  18. galaxee
    9,810
    471
    MD
    <div class='quotetop'>QUOTE(bwilson4web @ Apr 25 2007, 01:27 PM) [snapback]429912[/snapback]</div>
    maybe a cup or so of gas could reside in the box given the height of the fuel pump intake, as far as what's left in the bladder there are some expansion bellows that may keep the last bit of gas in the bladder once the bellows return to near-collapsed position.
    unfortunately everything but the resin bladder is gone at this point :(
    pretty sure it's a brush motor design.
  19. ozyran
    ozyran New Member
    695
    Thanks for the educational trip through...the gas tank (dun dun da!)
    Seriously, though, that looked like it tool a long time to disassemble and compile. Your efforts are commendable.
  20. wyounger
    wyounger New Member
    69
    Atlanta, GA USA
    <div class='quotetop'>QUOTE(Oxo @ Apr 7 2007, 12:35 PM) [snapback]419418[/snapback]</div>
    The bladder is fitted in US models in order to qualify for the PZEV emissions rating in California and the handful of US states that have adopted the California emissions standards. They could have made the bladder just for those states, but elected to just put them in all Priuses. The Prius is not the only car that has a bladder-type fuel tank now, either; offhand I am aware of PZEV models of the Camry, Focus, Subaru Legacy, Nissan Sentra...
    The reason they all are adopting the bladders is that the PZEV standard prescribes, on top of hydrocarbon, NOx, etc., limits, a specification of ZERO evaporative emissions while the car is parked. In most cars, even with an evaporative canister, some fuel still manages to evaporate out of the tank. By adopting the bladder, the fuel doesn't ever have an air space around it and no evaporation can occur.
    I have no firsthand experience of it but I have read that the bladder is not included in Prii sent elsewhere in the world. I don't know what you might find in a Canadian model, either.
