the gas bladder: exposed!
Discussion in 'Gen 2 Prius Technical Discussion' started by galaxee, Apr 6, 2007.
  1. bisco
    52,863
    i'm sure someone must have thought about it
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    In theory, possible... BUT you have to cut open the metal tank and the plastic fuel pump sump. Then find a "correct" pump, install it and seal everything up with absolutely no leaks.
    No shop would touch that because of the liability of having the tank cut open and "patched" (might not do so good in a collision). Plus any leak inside or out will trigger the check engine light.
    Crappy design but that's what we have to live with.
