The gas cap is...
Discussion in 'Gen 2 Prius Main Forum' started by jmann, Dec 9, 2005.
  1. on the correct side.
    0 vote(s)
    0.0%
  2. on the wrong side.
    100.0%
  1. zapranoth
    zapranoth New Member
    251
    Olympia, WA
    Is there any way you can damage a Prius (I almost said "hurt") by driving it when it's out of gas? I seem to recall that you can. (damage it.)
  2. Panther87
    Panther87 Junior Member
    S.E. South Dakota
    Yes, driving just on the battery can cause damage to the battery. It has been said that doing so drains the battery to very low levels. So much so that it might inhibit the battery cells from recharging all the way back. If done too much, also could limit how well the batery cells hold a charge. Back to topic, I have a Saturn and it fills on the right side.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    The gas cap is on the correct side because it is on the side in which they installed it. Now, if the gas cap had moved to the side opposiste the one in which they installed it then certainly it would be on the wrong side.
  4. KTPhil
    KTPhil Active Member
    1,379
    22
    "Yea, why DON'T they put the gas cap in the middle.
    Then you can glide up to either side of the gas pumps."
    This is unsafe in rear-ender accidents.
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i cant remember the last car i had ( that is IF i have ever had one that had the gas cap on the passenger side. i did have a few old 60's era beaters that had them in the back and that SUCKED.
    besides, i can easily see too many people either running into the pumps or parking too far away from them if they were on the other side.
  6. TorontoSusan
    TorontoSusan New Member
    44
    Toronto, Ontario CANADA
    My old 96 VW Golf had the gas tank on the right side - VW said that they did it deliberately so that if you ran out of gas on the road and pulled over, you weren't in traffic when you refilled it with the gascan.
    I thought that was smart ... and after almost 20 years of VW, it's a major effort to remember where the damn cap is every time I pull into a gas station! I didn't know it was a Euro-US thing.
  7. daniel
    14,487
    1,519
    Spokane, WA
    I like it on the driver's side. I'm lazy. This way I don't have to walk around the car to get to the pump.
    I once had a long argument (aboard a tall ship) with a brit who insisted that Americans drive on the wrong side of the street. His reasoning involved medieval knights and the French revolution. It wasn't really an argument. He was the chief of my watch, and a really cool guy, and I learned a lot about sailing from him. But he had this thing about driving directions.
  8. jimgraffam
    jimgraffam New Member
    131
    Sterling, MA
    Impossible to argue this logic. :lol: PLUS: I'd hate to offset the shorter fill-up time after trading in my SUV and by now having to navigate around to the other side of the car... and back again. Sheesh.
  9. KMO
    KMO Senior Member
    2,009
    731
    Finland
    2023 Prius Prime
    What does it matter when you only fill up once a month. :rolleyes:
  10. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    "american side" - that's ignorant. it's either left or right, americans don't own any side.
    and are you the one who determines which side is the correct one and which one is the wrong side? As far as I am concerned either side is correct on any vehicle if that's where the manufacturer installed it.
  11. jimgraffam
    131
    Sterling, MA
    After much consideration, while one cannot argue Tony's original logic, I believe it to be incomplete.
    The correct side is more generally... The OUTside. ;)
  12. BeachDriver
    BeachDriver New Member
    My 1965 VW Bug had the gas cap inside the front trunk. So, if you wanted to load or unload some baggage, and check the spare tire pressure all at the same time, you could! B)
  13. aaf709
    3,862
    2022 Prius Prime
    Interestingly, I saw a tricked-out Prius on Sunday that had four exhaust pipes, two on each side (chrome of course). A pipe was run from the regular exhaust which connected to them.
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    interesting to see a Prius with 4 exhaust pipes when it doesnt even provide enough exhaust to rust one pipe
  15. daniel
    14,487
    1,519
    Spokane, WA
    I'm surprised nobody has said this yet:
    The gas cap is on the correct side because it's on the side with the gas filler pipe. If the cap was on the side opposite the filler pipe then gas would slosh out of the tank while you drove, and we'd lose that PZEV rating.
  16. olcorral
    olcorral New Member
    97
    Bay Area, CA
  17. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    Ahhh, I see a new Prius. You will eventually have to put gas in it. :lol: :lol: :lol:
  18. aaf709
    3,862
    2022 Prius Prime
    Sure, that's why you have that little arrow to the left of the pump symbol. Otherwise you'd forget which side it was on. :D
  19. Paul R. Haller
    285
    43
    Walnut Creek
    I also own 4 other cars and I can't remember which side they are on. I have come to look for the arrow. My 70 Pontiac GTO has it under the rear licence plate... I like it there.
    -Paul R. Haller- :)
  20. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Compliments to Toyota to figuring things out and providing ergonomic logic: 1) Indicator on dash as to where the fuel port is (driver's side) and 2) release for fuel port (left of driver's seat).
    Obtaining fuel these days can be bizarre as one is never quite sure where the fuel port is (left, rear or right). Toyota recognizes "form follows function." Thank you!
