The good, the bad, the ugly (or my 18 months with a GIII)
Discussion in 'Gen 3 Prius Main Forum' started by dhs, Jan 1, 2011.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I agree, a backup camera is a very good thing to buy in a Prius. I tried backing up to a car without one, forget it. I can't get within about 4 or 5 ft without thinking I'm just about going to hit.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I'm going to strongly disagree with the "better off with an efficient conventional car". The conventional ICE car is going also get crap mileage (almost certainly worse than the Prius) while warming up. It just may not be apparent as it may not have a trip computer that tells you mileage in intervals like Prius.
    On my 350Z (which I avoid taking into stop and go traffic), due to very short city trips and a fair amount of idling, I see mileage in the 13.x-16.x mpg range. :(
    Regarding the mirror adjustment, see Car Talk | How to Avoid the Blind Spot. I had to do this when I got my 350Z as the blind spots are HUGE on that car. I now use this technique on all the cars I drive.
    As for backup camera, agreed. It's helpful. I like the fact that I have it on my 06 as well.
    51,893
    sube is a great car, but, one inch of snow? guess they should not sell pri anywhere north of the m/d line?
  4. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Nice review - and I believe accurate...
    I had an accident (my fault - kids yelling - I was looking back), car flipped end over end (45 MPH car is low - in rain, hit low median - toppled, turned - landed upside down).
    4 kids and me. All kids safe, I got 2nd degree burns (airbag), looking at the accident, you'd think people were killed...
    Insurance (after a month of back and forth) came in above my purchase + additions (leather etc).
    I have much respect for airbags (they all blew), and the car's safety in general.
    Bought another Prius the day the check came in.
    Went skiing last week at Mammoth (3' snow + ice), was very glad I took the 4wd SUV - saw one Gen III parked (under 2" of snow) - was very glad I didn't drive the thing (yes - I have chains for it).
    It's all relative....
  5. Tideland Prius
    16,553
    You make it sound like a regular car doesn't need to warm up its engine. It's no different. A series of 10 minute trips in an efficient conventional car will still be worse. They don't have the advantage of the atkinson cycle and the exhaust heat recovery system to help reduce fuel consumption and emissions.
    I would say a PHEV or an EV would be a better solution for short trips.
  6. dhs
    dhs New Member
    121
    Virginia, USA
    There is a difference: the regular car might be down 30%, the ice in the Prius is down 30% while warming up. The difference is when the Prius warms up, the HSD can further increase efficiency. I should ave said, with a series of ten minute trips, you can find conventional cars that will do as well as the Prius during the warmup phase.
  7. dhs
    dhs New Member
    121
    Virginia, USA
    One inch of snow means icy with minimal traction
  8. Sneezy
    Sneezy Member
    185
    Upstate NY
    My wife & I have not had any problems in the snow. We live much farther north of the OP.
  9. dhs
    dhs New Member
    121
    Virginia, USA
    If you read my original post, you will see that snow was a minor issue. A couple of things: the accident was a hit and run in the snow. The problem was that got me into a slight skid, which vsc kept me recovering from. I would have made it home with minimal problems without it.
    I was reporting what happened after I was pushed. The other driver did not want to wait for cars that stopped for a school bus and passed on the wrong side if a road. Outside of the aggressive vsc, the only problems with the Prius are ground clearance and oem tires. Latter can be fixed,
    And where in upstate? I lived in Binghamton for 8 years, and learned to drive in the snow there.
  10. Sneezy
    Sneezy Member
    185
    Upstate NY
    I live in Binghamton! Been here since '77.
    I had an 05 Legacy GT that came with summer tires. It would not go in the snow. Our Prius's go better even with OEM tires. If I had it my way, I wouldn't get traction control on any FWD car, it's useless. Now on my trans am......it's very handy but still not required!
    To each their own in the end.
  11. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    I doubt your last statement. Do you have any independent tests that show multiple conventional ICE cars (currently sold or sold during the same time frame as the 2nd or 3rd gen Prius) getting just as good mileage than the Prius in such conditions?
    At least on the 2nd gen Prius, the ICE can shut down well before coolant temp reaches 145 F which to me is WAY before it's warmed up. It also can recapture and re-purpose some kinetic energy that'd otherwise be lost as heat and brake dust. After driving a long time, coolant temp is usually at 17x - 18x degrees F.
    Unfortunately, I don't know of published mileage tests which are just 10 minute drives but if you look at Best & worst cars review, best city/highway mpg and the best city mileages, out of the 10 listed, the 3rd gen Prius is on top (2nd gen got 35 mpg in the CR city test), 2 gasoline non-hybrids and two TDIs. Of the 4, 3 have manuals and 1 has a crappy manumactic/automated manual transmission. The last page of http://www.consumersunion.org/Oct_CR_Fuel_Economy.pdf briefly talks about their city test.
  12. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Huh ? Does the Prius change the law of physics as well ?
    Of course , the bigger ICE in the Subaru will warm the cabin faster.
  13. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    How high was the median to flip a vehicle at 45mph ?
  14. dhs
    dhs New Member
    121
    Virginia, USA
    My point was not subaru for economy....A mini cooper, for example, might do better in the warm up stages than the Prius. Or perhaps a Toyota Yaris. Small cars with only ICE engines. If one is never really getting the ICE warm, my initial statement is the Prius might not be optimal. A Yaris, or several other types of cars could get as good if not better economy than the Prius for the first 5 minutes of a trip. The Subaru is a much bigger car, and will not get better mileage under any conditions
  15. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    I'm not trying to tell you it's a bad choice, I'm not a Prius Evangelical. :) We're just having a discussion here.
    My hypothesis is that it's all relative. Nether one is reaching their peak efficiency on that short commute, so I'm guessing that if they both hit 70% efficiency the Prius is still going to be delivering more mpg over that span. I could certainly be wrong.
    My previous vehicle, with it's 4.7L V8 gave me warm cabin air at pretty much the same landmark on my commute as the Prius does.
  16. ETC(SS)
    7,139
    Hey Coach!
    Got any of that popcorn left?
  17. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi tp..,
    Last time I checked, the thermal mass of a bigger engine is more than a smaller engine. And since warming implies a difference in temperature, the goal is to get the engine water temp to a higher heat the quickest. So, the smaller engine will warm the cabin faster, as it will get hotter faster, while providing the same power output profile. And being hotter faster, it will transfer more heat to the cabin faster.
    And then, the 2010 Prius has the heat recovery system, which puts it in a league of its own in cabin warm-up speed....
  18. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    The Atkinson engine in the Prius is designed for efficiency, therefore for the same amount of fuel, less energy is generated as heat.
    Combine this fact with the tiny engine in the Prius, you are talking about a 200% difference between the Prius and the Subaru in heat generation.
    Both models use about 7qt of coolant so the thermal masses are comparable.
  19. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    It takes a long time to heat up that 15qt of coolant. Water has 10X the heat capacity of iron.
  20. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi tpfun,
    Thanks for the clarification of your comment. SO, your original comment about engine size was worng. And you believe Suburu engine does heat up the cabin faster, as its wastes the fuel energy more readily. Even though the Suburu engine has to heat up SO MUCH more aluminum and coolant , is so much more wasteful, that you believe it heats up the cabin faster.
    I do not have experience with a Suburu, but a 3rd Gen Prius warms up the cabin very quick. Its recovering the exhaust gas heat as well as the block heat both.
    An Otto engine is typically 12 % efficient at low power (low speed warmup driving), leaving 88 % of the heat as waste. If I remember right, its 80 % of the waste heat going out the exhuast and 20 % into the coolant. So, of the .88 times .20 gives 17.6% of the fuel energy into the coolant.
    The Prius engine is like 25 % efficient at low power (Argonne National Labs Tests). The coolant energy is then .75 times .20 or 10 % of fuel energy. Say the 3rd Gen Prius exhaust heat recovery is 50 % efficient, an not unreasonable efficiency for a heat exchanger. So, that means the energy recoverd in the exhaust is .75 times .80 or 60 % of fuel burned energy. So, the total energy available in the 3rd Gen Prius coolant availabile for heating the cabin is 10 + 60, or 70 % of fuel burned energy.
    Now as you say the Prius is allot more effienct. So, we can assume the Prius burns half the fuel during this warm up period as the Suburu. .5 times .7 is 35 % of the fuel burned in the Suburu, available as heat in the Prius coolant.
    Last time I checked, 35% is about twice 17.6 % . The 3rd Generation Prius should heat up twice as fast as a Suburu.
    This might be why the Finish car magazine picked the 3rd Gen Prius as one of the top three winter cars for 2010.
