The grim reaper has finally arrived
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2005prius, Jan 31, 2026.
  1. 2005prius
    2005prius Junior Member
    New York
    Three Touring
    car was bought off the showroom floor in 2005. Never been apart.
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    After asking others more knowledgeable than me about OBD2 readers it appears that my original blame on corrosion was not accurate because too many systems are giving bad data and problem is with a bad OBD2 reader. However, the corrosion needs to be addressed as well, so OP's concern with addressing that is valid.
    2005prius likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,686
    1,073
    South Central PA, USA
    A little corrosion on the bussbars and nuts does not need to be addressed. If there is corrosion on the voltage sensing wires orange connector that plugs into the battery ECU, then that does need to be addressed, but I do not think that is the case based on the screenshot in post #13. What needs to be addressed in the OP's situation is the bad module in block #6.
  4. 2005prius
    New York
    Three Touring
    so my next step is to replace the 2 cells for module 6. Is there a source of reliable cells?
    I found this on eBay that has good feedback
    https://ebay.us/m/Us4Kto
  5. PriusCamper
    13,465
    5,431
    I wouldn't trust those modules... What's more you only have one bad module not two and a common mistake people make is replacing both modules in a block when only one module is bad. This is a problem if your replacement module doesn't match your existing modules in age and capacity and if you replace both of those modules in the same block you're doubling down on the level of hassle you might create for yourself.
    In my opinion professor Joe sells the highest quality replacement module because he's spent tens of thousands on lab grade testing gear several times over the past couple decades: Oregon's Trusted Hybrid Battery Supplier: 2nd Life Story
    2005prius and Brian1954 like this.
  6. PriusCamper
    13,465
    5,431
    It might not hurt but its the source of corrosion that eventually ends up in the ECU and buying a new wiring harness with the link in my signature, will last way longer than just cleaning the corrosion in the ECU.
  7. 2005prius
    New York
    Three Touring
    Latest update:
    I replaced modules 11 and 12 (block 6). Still getting a low voltage on that block.
    I broke the temperature sensor, so I have to replace that harness to get rid of that code first.
    Do the modules have to go through a few cycles to level out?
    #27 2005prius, Feb 27, 2026
  8. PriusCamper
    13,465
    5,431
    Usually there's only one bad module in a block and when you replace that module with one that doesn't match the modules in the pack you have a problem like the one you're having. And if you replace both modules in a block you double the likelihood of having a problem. So only replace the module that has tested as bad.
    As for getting all modules to have the same voltage and near same capacity that's called balancing and you can do that with a high voltage trickle charger sold by Maxx Volts or HybridAutomotive... OR build your own, or buy a variable DC power supply online that has at least 250v at 1/3 of an amp. All the information on the HybridAutomotive websited will teach how to do it.
    Another method, which is less effective for this battery type is to connect all the battery terminals together in parallel, as in connect all the positives together on one wire and all the negative together on another wire and hook up a multitester and should read 7 something volts and that votage will equalize to all modules after a while, but the modules capacity might be a bit off compared to the other method.
    Brian1954 likes this.
  9. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    @2005prius, This idea, called equalization, is not less effective, it is totally ineffective. Don't waste your time on this.
    Equalization is not the same as balancing. If you want the modules to be at the same voltage as the others, use a RC charger to charge it up to the voltage of the others. However, you should still balance the battery pack by grid charging after it assembled.
    Instead, focus on the first two paragraphs in PriusCamper's post.
  10. PriusCamper
    13,465
    5,431
    Yeah... I used to agree with you, but have seen so many people use that method, even certified mechanics that I'm no longer going to joust with that particular windmill. As in, not enough people saying it didn't work for me to argue anymore.
    Main point is each battery chemistry has a different method to balance the pack and if we were talking about lithium chemistry and all cells were drained down to very last charge level, just before voltage falls off a cliff then wiring the pack up in parallel would be the correct way to balance, also known as balancing from below. Whereas for a regular OEM battery that's Nickel Metal Hydride you want to balance from above at max volt and 1/3 of an amp or lower using a fan to dissipate the excess charge as heat.
  11. dolj
    dolj Senior Member
    8,646
    4,397
    You are free to believe what you want, but the physics and chemistry says otherwise. If enough people do the wrong thing, it is just a lot of people doing the wrong thing. The point I was making is that equalization is not a process to be used, as getting the voltage the same is not the target, but should be the end point after doing proper capacity matching and (proper) balancing.
    What is good practice for one chemistry does not hold sway for another chemistry. Lets just give good advice for NiMH chemistry, which is what is in the Gen 2 Prius.
  12. PriusCamper
    13,465
    5,431
    It's more fun to add lots of extra erroneous information... That's what social media is all about.
    I was actually hoping we'd start arguing at length about best practices for balancing lithium packs and their history on Priuschat because getting off subject is fun. :)
    #32 PriusCamper, Mar 1, 2026
  13. 2005prius
    New York
    Three Touring
    Just an update. Changed both modules in the bad block. It’s been working fine for 500+ miles/2 months.
    Thank you everyone for your input.
  14. Brian1954
    2,686
    1,073
    Thank you for coming back and closing out this thread with what you did to fix the problem. The majority of threads in this forum are open-ended because the OP does not come back and report that the problem was fixed.
    Enjoy driving your Prius hopefully for many more years. I hit a deer in January with my 2011 Prius, and the insurance company totaled it. I now have a new two week old 2026 Camrt LE.
  15. 2005prius
    New York
    Three Touring
    I’m eyeing up the new gen 23? and up AWD Prius. Hoping to retire in 4 years and get a low miles used one to replace my 2005.
  16. bisco
    52,855
    hard to believe it's been around that long. prices might drop a little when the next gen is introduced
