the heater does not blow hot
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mehmet alb, Nov 28, 2022.
  1. Mehmet alb
    Mehmet alb Junior Member
    77
    Turkey
    The 2007 Toyota Prius. it's not blowing hot from the air conditioner. I'm turning on the air conditioner. I'm turning off the A/C touch screen. It doesn't feel hot from the heater. Thanks for the help
  2. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    It could be that hot coolant is not getting into the heater core or that the little door mechanism (under the dash and very hard to reach) which chooses the air source is stuck. I think either way that should set an error code but not necessarily light up the CEL. So get a decent code reader and have a look.
  3. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Have you already checked the coolant level in the radiator? (not just the white overflow tank)
  4. Mehmet alb
    77
    Turkey
    Yes there are water
    are there picture?
    #4 Mehmet alb, Nov 29, 2022
  5. Mehmet alb
    77
    Turkey
    shouldn't there be a blue socket where I'm pointing? would that cause a problem? isn't the heater blowing hot anyway? thanks
  6. ChapmanF
    19,038
    Was that post meant to include a photo?
  7. Mehmet alb
    77
    Turkey
    Is it mandatory to have a blue socket in the place I marked? does that create a problem? The heater is not blowing hot. could be why ?thanks
  8. bisco
    52,863
    that might be it, or maybe the thermostat is stuck
    Mehmet alb likes this.
  9. ChapmanF
    19,038
    Looking in the picture, I see a socket that is there, but does not have a relay plugged into it.
    Have you looked up what a relay in that position is for? Has that socket always been empty?
  10. PriusCamper
    PriusCamper Senior Member
    13,467
    5,437
    Pacific Northwest, USA
    Every year in Winter we get posts from people who think their heater won't work because they only drive their car short distances and it takes 15 to 20 minutes to get the heater performing at its very best when its super cold out.
  11. Mehmet alb
    77
    Turkey
    how do I know if the thermostat is tight
  12. bisco
    52,863
    there's a proceedure in the service manual i think. when we were kis, we used to put them in boiling water to see if they opened.
    are all the hoses under the hood hot, after the engine has warmed up?
    #12 bisco, Nov 30, 2022
  13. pasadena_commut
    3,069
    956
    Southern California
    If the heater core sprung a leak a former owner might have chosen to bypass it rather than tear apart the dash to fix it. Trace the hoses in that region and see if they are stock. Search in these forums and you will find the diagram for what they should look like.
  14. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    Is the coolant level IN THE RADIATOR full? Is the water pump drive belt on the engine in place?
    That connector may have a relay that is missing, or your car may not need that relay. It should not affect the normal heater function.
  15. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Looks like you're missing a few relays there, try moving the only relay you have and see if something starts working (or fails to work).
    Shouldn't there also be a larger grey relay in the box as well?
  16. ChapmanF
    19,038
    I'd be happier to see somebody look at a diagram of the relays that go there, and comparing to the trim level of the car and what options it has.
  17. Elektroingenieur
    2,515
    3,288
    Three Touring
    No.
    Not necessarily.
    For a 2007 Prius car built for sale in Europe (with model code NHW20L-AHEEBW on the certification label inside the left front door), the Electrical Wiring Diagram (more info) and Electronic Parts Catalog show that there might be only one relay in Engine Room Relay Block No. 2, just as seen in @Mehmet alb's photo: the blue RR FOG (rear fog lamp) relay, in the fifth socket from the left.
    The socket on the left that’s different from the others, and the third and fourth sockets from the left, are indeed for PS HTR, PTC HTR 1, and PTC HTR 2 relays to control the electric PTC heaters, but those heaters and their relays exist only on versions of the car built for sale in the U.S. and in colder areas of Europe and Japan.
    All versions of the car have a traditional heating system that circulates engine coolant. The relays for this are elsewhere on the car: the HTR (blower motor) relay is in the Driver Side Junction Block, and the AC W/P (heater water pump) relay is built in to Unit B (Integration Relay No. 1) of the Engine Room Relay Block.
    For completeness, in Engine Room Relay Block No. 2, the second socket from the left is for the FR FOG (front fog lamp) relay, and the sixth socket from the left is for the CHS W/P (coolant heat storage water pump) relay—again, only if the car has these features. For all versions of the car, the relays in this block, if present, have Toyota part numbers 90987-02025, for the first socket, and 90987-02027, for the others.
    Mehmet alb and SFO like this.
  18. Mehmet alb
    77
    Turkey
