The hybrid battery fan not working !!
Discussion in 'Gen 3 Prius Technical Discussion' started by MSF1344, Nov 8, 2019.
  1. MSF1344
    MSF1344 Junior Member
    61
    UK
    Active
    Hi , I recently bought my 2013 prius but I have never noticed the hv battery fan working . when the car was in ready mode i opened the back door and put my ear on vent but nothing hear . I live in cold climate area is it because of that or the fan should work all the time ? never had a warning light .
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    The fan runs at whatever speed (from 0-6, iirc) necessary to maintain a safe battery temperature. In cool weather, I would not only not expect to hear it, but I would be concerned if I did. There are lots of OBDII dongles and phone apps you can get that will inexpensively monitor all sorts of stuff including fan speeds and battery temperatures if you're curious. Or just drive it hard with lots of hard acceleration and regenerative braking for 10 minutes or so to heat up the battery and then dangle some tissue paper in front of the vent to check for air flow.
    Or, just drive it. In the unlikely event that the fan isn't working, the car will tell you if the battery gets too warm. It will put a light on the dash and you can read the specific code with a code reader.
    But those are unusual circumstances. In your climate, the battery fan has the easiest job in the world. :D
    Longinus876 and Montgomery like this.
  3. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    I usually just reach back and put my hand next to the vent during hot weather to feel if the fan is on or not. Never been able to actually hear it when it does run...
  4. jerrymildred
    11,517
    14,167
    Tampa, FL
    I've heard it in the Gen 2 on really hot days, but just barely. I often hear the two fans on my Prime here in FL, but only when stopped and usually after extended EV driving. The fans are radial which makes them quieter than typical propeller fans.
    Longinus876 likes this.
  5. MSF1344
    61
    UK
    Active
    Thanks for your answer @jerrymildred , probably get an obd2 dongle for peace of mind .
    jerrymildred likes this.
  6. bisco
    52,814
    i've never heard the fan in 15 years of driving prius, and not even with my new hearing aids.
    i did put a tissue on the grille in hot weather once to confirm it was working
  7. PriusCamper
    PriusCamper Senior Member
    13,438
    5,425
    Pacific Northwest, USA
    Hybrid Assistant app has the best fan controller, but it's super slow to activate/latency... Dr. Prius App fan control is even more problematic...
    Most of all for every one OBD2 reader you can buy online that works, there's 5 that will be dead on arrival... Learn more here about difference between real and junk here: Hybrid battery diagnostic and repair tool for Toyota and Lexus
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Turn the heater on, let the hv bat soak up the heat. It will spin up to speed 1 when bat is 96 F. 102 F is speed 2.
    Free test, not require to buy a obd2 Bluetooth thing
  9. George W
    George W Senior Member
    939
    520
    San Antonio
    Opening the back passenger door will automatically turn the fan off, in a Gen 2.
  10. bisco
    52,814
    you don't say
  11. PriusCamper
    13,438
    5,425
    Really? Usually whenever I try to open the back door all my fans try to get in the car?
    Montgomery likes this.
  12. Mendel Leisk
    42,313
    I've never heard the fan. I used to have a scangauge connected, occasionally monitoring fan speed, and saw it stepping through the various stages. But yeah, it would be reassuring to hear it. I believe if it's badly clogged and/or not working, there's a warning on the dash??
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    :ROFLMAO:
  14. Walter Jasulevich
    Walter Jasulevich Junior Member
    Mentor ,Ohio 44060
    I purchased the Dr Prius app and it let's you adjust the temp that the fan comes on at , I heard and felt the fan running . Now that the car is turning 13 years old , I decided to check for dust build up on the fan , no filter ! The was the lightest coating of dust on the fan after 150,000 miles , I had to hear it run , thought that it never worked !
