The Hybrid Convertible Project Prius v
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Aug 8, 2014.
Thread Status:
Not open for further replies.
  1. bisco
    52,891
    is the battery the same as lift back, or larger?
    Bill the Engineer likes this.
  2. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Same. Only the air ducts are shaped a bit differently.
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    it will never float with all those holes in it...you are doing the james bond option package aren't you?
  4. Bill the Engineer
    1,048
    2,278
    467
    Welding has begun!
    Bill the Engineer
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Sweet
    iPhone ?
  6. bisco
    52,891
    yay, man with tools again! yahoo!:p
  7. Bill the Engineer
    1,048
    2,278
    467
    Brace yourselves...
    Sunday was one of those days that you dream about. It was the middle day of the 3-day Labor Day weekend, there weren't any home chores to do and the weather was perfect. The day started with finishing the welding and grinding on the front bumper adapter brackets.
    Then I mounted the brackets onto the Prius v Chassis in place of the cardboard mock-ups that had been there. These brackets simulate the ends of the former frame on the original Firebird chassis.
    Then I mounted the Firebird radiator support to the brackets. (It is the part that holds the front of the fenders in place, and where the hood latch parts are mounted.)
    Next I mounted the original Firebird front bumper brackets to the new adapter brackets.
    And finally, I mounted the Firebird front bumper assembly onto the Prius v chassis.
    It was an EXCELLENT DAY!!!
    Bill the Engineer
  8. ChapmanF
    19,055
    I love the part of a project where you start to see it coming together.
    -Chap
  9. bisco
    52,891
    wow. can we go for a spin?
  10. Beachbummm
    1,160
    393
    are you mounting the battery pack behind the rear seat like in the gen one or flat in the trunk?
    breakfast and Bill the Engineer like this.
  11. Bill the Engineer
    1,048
    2,278
    467
    It will be under the rear seat in a drip-proof enclosure. The cooling ducting will also be made drip-proof. The trunk area and under the rear window in a 1960's GM convertible body can become wet in a downpour, even when in pristine condition. The rear seat platform will be elevated because of that, but I plan to use a thinner lower cushion to partially compensate.
    Bill the Engineer
    jeff652, breakfast and bisco like this.
  12. Beachbummm
    1,160
    393
    I always wondered if putting the battery in an aluminum vented box would help displace heat faster
  13. Bill the Engineer
    1,048
    2,278
    467
    Mostly a clean up weekend so I could walk through the garage without tripping on anything.
    I'm still uneasy about the added length to the nose, but I don't see any way around it since the bumper brackets are already only an inch away from the frame lifting points on the Prius v.
    Bill the Engineer
  14. bisco
    52,891
    do you think hard core pontiac fanboys will notice?
  15. Bill the Engineer
    1,048
    2,278
    467
    Without a doubt, but then mine will still look more stock than a lot of others I have seen.
    Bill the Engineer.
  16. bisco
    52,891
    retromod.
  17. Michael Leary
    Michael Leary Junior Member
    39
    22
    Kansas, U.S.
    On computers the legal words were "look and feel" of the original. In this, that's what you want. Cheering you on Bill. And by the way--No zaps with the power system.
  18. gafortiby
    gafortiby Member
    98
    58
    Colorado
    Bill,
    What a great thread. I read all 31 pages of it over the last week and I am truly inspired. I have an engineering degree but don't have the guts to pull of what you are doing. Are you a P.E.? I never got mine and now I don't work as an engineer anyway.
  19. gafortiby
    gafortiby Member
    98
    58
    Colorado
    I must not be seeing something here. Base on these pictures, it looks like you can cut the top of the firebird radiator support off and weld it onto the Prius radiator support. This would give you the hood latching mechanism and the top fender mounting points at points closer in length to the original firebird. Then, you can shorten the firebrid bumper support that you custom made. What is in the way making that not possible?
  20. Bill the Engineer
    1,048
    2,278
    467
    I looked at that early on. There would have been a lot of creative cutting and welding to keep the length of the fenders and hood the same. Even then the Firebird's grill would have to be made almost flush with the bumper due to the Prius condenser, and the headlight buckets would be interfering with Prius frame parts. The hoof latching mechanism would also have needed a redesign because of the location of the Prius condenser. The lower condenser support frame would also protrude out of the Firebird front valence. Some of these points were mentioned in earlier posts.
    Last night my wife brought up a good point. Everything on the front of the car is bolted on, so it can be removed and reworked if I end up not liking what it looks like. I have decided to proceed with the current plan to keep things moving along and decide if I like how the front end is coming together at a later point.
    Bill the Engineer
    m.wynn, breakfast, gafortiby and 2 others like this.
Thread Status:
