The Hybrid Convertible Project Prius v
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Aug 8, 2014.
Thread Status:
Not open for further replies.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    I'm sure you are doing a better job than Ford did with the 72 pinto.
    #861 Beachbummm, Apr 14, 2017
  2. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Oh, right. Sorry. Having an Engineer moment there. Things got a bit jumbled when I went off on that tangent. I'll try to stay on topic now that I can work out in the garage again.
    Bill the Engineer
    Beachbummm and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Staying on topic:rolleyes:
    And an engineer moment is better than a senior moment;).
    Bill the Engineer likes this.
  4. Bill the Engineer
    1,048
    2,278
    467
    Day off from work for Good Friday holiday. I'm glad it was sunny and in the low 70's degF. Got a decent amount done in the afternoon.
    Front bumper bracket parts filed, drilled and fitted to be welded tomorrow.
    Initial cut-out of the old Firebird radiator support got to the point I could hang it on the car over the radiator. I need to make adjustments here and there once the front bumper is back on.
    Bill the Engineer
  5. ChefShawn
    ChefShawn New Member
    Sonoma County California
    2017 Tesla Model S
    YOU ARE AWESOME
  6. Bill the Engineer
    1,048
    2,278
    467
    Another good day in the garage. I welded the front bumper brackets into their new configuration and ground down the rough spots. I then mounted the brackets onto the front of the car.
    Then I mounted the front bumper assembly back onto the front of the car. So far so good.
    The new configuration is going to look much nicer, having chopped 6 inches out of the extra length. It is only 4.5 inches longer than stock now, and things are positioned nicely for the fender supports.
    A very satisfying day!
    Bill the Engineer
  7. bisco
    52,889
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    You got to make great progress in your garage.
    I got to host 40+ people for pre Easter dinner.
    Only 15-20 tomorrow so should be a little less hectic(y).
  9. Bill the Engineer
    1,048
    2,278
    467
    Before and after photo. Much better now.
    Bill the Engineer
  10. redhotz
    redhotz Member
    49
    29
    Cleveland, Oh
    Are you keeping the Prius horns?
  11. Beachbummm
    1,160
    393
    so will this be titled as a firebird or the salvage prius its built on?
    in florida we have to rebuild to original and pass inspection before a rebuilt title and tag will be issued
  12. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    The horns can easily be changed. The ones in the link in my signature below sound very GM.
  13. Bill the Engineer
    1,048
    2,278
    467
    No! I will be using stock 1967 Firebird dual horns.
    It is and always has been titled as the 1967 Firebird under its original VIN. It is considered a street rod / resto-mod.
    Bill the Engineer
    #873 Bill the Engineer, Apr 16, 2017
  14. Bill the Engineer
    1,048
    2,278
    467
    Clean-up weekend while I wait for supplies to arrive. I do love it when the morning sun shines on the car.
    Bill the Engineer
  15. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Are you sure there is a Prius under there;).
    They say patience is a virtue. And the waiting is the hardest part.
  16. Bill the Engineer
    1,048
    2,278
    467
    Nothing very photogenic lately. There is no way to make door glass removal look pretty.
    Working on final prep for the body lift-off later this month. The garage is going to be cramped again while I have the media blaster going. I need to strip off the paint to see what bodywork needs to be done.
    Bill the Engineer
    Montgomery, breakfast, m.wynn and 4 others like this.
  17. Beachbummm
    1,160
    393
    are you going with an fiberglass hood?
  18. Bill the Engineer
    1,048
    2,278
    467
    Nope. I'm using the stock 326 hood with a filler piece made from the second used hood I bought. The fiberglass hoods all have hood scoops, which would just be strange on a hybrid in my opinion.
    Bill the Engineer
  19. Prodigyplace
    12,720
    11,852
    Central Virginia
    With your new logos that should be an HSD hood. :D
  20. Bill the Engineer
    1,048
    2,278
    467
    Finished protecting the windshield inside and out while I could still stand inside the body. One step closer to lifting the body off again.
    Bill the Engineer
    m.wynn, Montgomery, breakfast and 4 others like this.
Thread Status:
