The Killer Plugin 4th Gen Prius
Discussion in 'Gen 4 Prius Main Forum' started by inferno, Apr 17, 2015.
  1. inferno
    inferno Senior Member
    1,072
    405
    • 15-20miles EV
    • 60 mpg hybrid mode
    • Now the reason I created this thread...
    • 25 lb overlays of batteries that can be easily managed, is safe and can be plugin.
    How many times do we travel with the trunk empty? How neat would it be that our PiP can go from 15-20 miles EV to 60-80 miles EV at a whime (spending maybe a couple thousand than 10-20 minutes of labor). Suddenly we're talking about a vehicle that could almost compete with Leafs...
    And if Toyota concentrates on EV efficiency...Well, then I believe Toyota would leapfrog their competition which would take another 5-7 years to catch up (whereas now, they are just nipping at their heels)
    jdonalds and bertoncini like this.
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    If you are talking about offering 2 battery capacity size options in the Plug-in, Great idea!
  3. inferno
    1,072
    405
    Even better. A ton of configuration. Offer one PiP configuration with the ability for us consumers to 'add-on' and upgrade easily. Take out the battery pack when we need more room. Put in the battery pack easily when we want more EV, fill it to the top even if we have no passengers and put groceries or stuff in the back. It brings us back to the old days of modding the Gen 2, but making it easier and putting the power of upgraded EV range in the consumer's hands.
    Much like upgrading RAM on your PC, HD to SSD etc...Open up EV upgrades. Then you'll have consumers flocking by $1k battery packs - I'm sure of it! And the key factor is, Toyota might gain drivers from Tesla and Leafs and Energis!
    52,863
    is this coming direct from toyota???(y)
  5. bisco
    52,863
    how many tenths of a mile would 25 lbs of batteries produce?(n)
  6. inferno
    1,072
    405
    What ~ 150 pounds for the current PiP battery pack? 4 layers of 25 lbs could yield ~22 miles EV? I only say 25 lbs to make it manageable :p I'm imagining a flat flexible layer of Li-Ion cells (or any battery tech) that can go on top of the cargo area. With tech today, 25 lbs could mean an extra 3 miles EV or so.
    What would be super awesome and SunPower adds a solar roof to the Prius which has the ability to focus more sunlight, has an efficiency of 25%+ and is able to charge a 3.3 KWh battery in a day.
  7. Sergiospl
    3,938
    1,351
    28
    I like the 15-20miles EV/60 mpg hybrid mode.
    Read somewhere the current solar roof weighs about 66 lbs. The plug-in probably will not have it because of weight, but would be nice if the PV can charge the regular hybrid battery while in the parking lot or when driving. I wish!
  8. zebekias
    zebekias Member
    101
    35
    Greece
    Photovoltaic paint already exists, at some point we will see it on cars :) maybe sooner than we think! Just like regen braking, it will contribute to the battery charge!
  9. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Toyota, and most other car makers, mass produce cars for the masses.
    There are some compromises involved .........to appeal to the widest market, keep prices down and profits up.
    If you want a custom electric car, go talk to Tesla; and have about a hundred grand in hand.
  10. inferno
    1,072
    405
    But Toyota can disrupt the industry with this add-on concept, allowing consumers to buy extra packs and load their car with energy. As long as Toyota stays on the forefront of efficiency (EV mode and Gas/Hybrid mode) they'll be untouchable. Tesla only *wants* to be this way but they haven't done it yet. The first one that allows the most flexibility in the consumer's hands win. Boy would I love to buy some 25 lb battery stacks right now and increase my PiP range by 50% or so...maybe 100%!
  11. bisco
    52,863
    i agree, if it were possible to add packs as easily and safely as a computer battery etc., you'd blow away the competition. and, it wold appeal to many more people. they can pick the range that works best for them instead of being locked into a single range. and, they could change it downstream if their driving pattern changed.
  12. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    I like this idea. We take about 2 1,000 mile trips a year, plus a 300 mile trip once a month or less. All other trips are less than 30 miles round trip. For the 1,000 and 300 mile trips we would depend on the Prius' hybrid features. For the short trips around town we would install the extra battery and could run on EV most of the time. So for us we could install an EV battery and on average drive it about 30 days with that battery installed. We'd only remove it for long trips where we'd need the extra trunk space.
    The trick would be for the extra battery installation to be painless. Also to have that battery charge when out of the car would be a big plus. I could see having even more than one exchangeable battery so one could be charging while the car is out being driven on the other.
    I can't imagine how the battery would be either light enough to man handle, or some other easy and quick method would be provided to change a heavy battery though.
  13. bisco
    52,863
    how much does the lift back 1-2 mile battery weigh?
  14. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    You mean something like this:
    Green Car Congress: FEV showcasing liquid-cooled, high performance battery for PHEV applications at SAE World Congress
  15. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    About 29 kilos or about 64lbs.
  16. bisco
    52,863
    thanks, that's not too bad.i guess with lithium, 25 lbs should take you a little way.
  17. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Currently our 4.4 kWh battery pack weighs 168 lbs (76 kilos) so you theoretically could get 1 kWh out of about 38 lbs. Remember this is 2011 technology, so with newer technology 1 kWh would weigh less and according to Volt specs it should be 20% less or a little over 30 lbs. Probably won't be too long before 1 kWh will weigh 25 lbs.
  18. bisco
    52,863
    that would be 2-3 miles?
  19. Sergiospl
    3,938
    1,351
    28
    Question is how much battery can you add to get it rated at 15 ev without affecting the 55mpg.
  20. bisco
    52,863
    if it's rated at 11 now, 15 should be easy with current battery tech.
