The Little Engine That Barely Even Tried
Discussion in 'Gen 2 Prius Technical Discussion' started by Landon51, Sep 30, 2019.
  1. Landon51
    Landon51 Member
    190
    63
    US
    mx Bluetooth.
    currently using CarBit to pull codes. it's beaten torque on numbers pulled. it's also beaten the mx's OBDLink software at pulling codes.
    I've probably tried most of the ones in GooglePlay. CarBit seems the best and most fun.
    Down to what's happening.
    I installed rebuilt injectors and the car just felt better. I had already installed cheapo plugs (new). And finally .... FINALLY when i made a change of coils all heck didn't break loose in my engine. my problem on 4 moved to 3.
    new coils on the way (hopefully). i couldn't afford used denso.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    What are the current DTCs logged/pulled?
  3. Landon51
    Landon51 Member
    190
    63
    US
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Noticed that the "3" were dated August 11th, 2019.
    Noticed that the "15" were dated July 11th, 2019.
    Also noticed a P0400 (among other generic DTCs) in the results dated 7-11-2019, which wouldn't apply to the gen2, and reeks of dubious OBD2 software.
    Please post current DTCs if possible.
    Consider another techstream setup.
    #44 SFO, Nov 8, 2019
  5. dolj
    dolj Senior Member
    8,633
    4,386
    Wellington, New Zealand
    Or the dates are proper :whistle: and are 7 Nov 2019 and 8 Nov 2019.
    dig4dirt likes this.
  6. Landon51
    Landon51 Member
    190
    63
    US
    yeah, i was wondering about that. is there an egr sensor? or does that code get set when certain conditions are met?
    Meaning that a sensor may not set the code but a certain set of conditions w will set it instead.
  7. Landon51
    Landon51 Member
    190
    63
    US
    the c current codes are P0420 And the one for the air fuel sensor that needs to be replaced.
    13.11.19 09:13:29 AM
    Toyota
    Profile: Control
    DTC:4
    P0420 Current
    Catalyst System Efficiency Below Threshold (Bank 1)
    P0420 Pending
    P0104
    Mass or Volume Air flow Circuit Intermittent
    P0131
    O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    current codes:
