The Little Fins Under The Car
Discussion in 'Gen 3 Prius Main Forum' started by El Dobro, May 18, 2013.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That is the older brace design. It's not my picture or car. :)
    During on of the technical sessions at To Go Before, one of the Toyota Accessories specialists talked about the Performance Plus Package and how they used addititional fins on the ground effects package to smooth out airflow at the rear of the car. In stock form there is a small pocket of turbulent air directly behind the car. The rear ground effects help smooth out the flow. He had some interesting graphic displays. I'll see if I can find them.
    WE0H likes this.
  2. El Dobro
    El Dobro A Member
    7,088
    3,270
    Fins or air-benders?
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    More of a set of fins than air benders.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The bottom of the rear skirt of the Performance Plus package.
    WE0H likes this.
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    You're talking about those little nobs on the bottom of the bumper-cover extension? Sorry, those would do nothing!
    Here's a question. Does the "performance package" get better rated mileage than the standard Prius? If not it's mental performance not real performance.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    David, I'm going off of reports from Toyota. They ran the design through CFD simulation by SimTech ANSYS. This was repeated by one of the Toyota Accessory specialists during last weekend's technical sessions which included the simulation videos.
    WE0H likes this.
  7. WE0H
    WE0H Senior Member
    3,247
    528
    I am pretty sure I read that the Plus Perf body kit was designed to reduce wind drag over stock :)
    Mike
    Mobile on my SGH-i717
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    We know the Performance Plus package will reduce FE vs. a standard Prius Two, Three or Four. The Prius Five also suffers reduced FE but Toyota didn't submit a change in EPA rating for it. So what you are asking for is not relevant to reality.
    Aerodynamics could be enhanced but the resulting FE is still lower than a standard Prius because of the wheels, tires, sway bar etc.. I think the engineers were simply trying to reduce the FE hit in any way they could without costing an arm and a leg. This is how it was explained to us.
    WE0H likes this.
  9. El Dobro
    El Dobro A Member
    7,088
    3,270
    They should use more air-benders. :p
    WE0H likes this.
  10. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    I got under the car with my camera .... this is a 2012 Prius II so it may different from others but I can see two air bender little stuff I am really sceptical what this can do .. .BUT would Toyota put them there for nothing ???
    not sure any comments
    oh yes the pictures are up side down ... that is the way I could put the camera and the flash under ..
    WE0H likes this.
  11. szgabor
    994
    175
    Oceanside NY
    No question those are not just random pieces .....
  12. El Dobro
    El Dobro A Member
    7,088
    3,270
    The attached articles from Lexus show how small they are and according to them, they work.
  13. szgabor
    994
    175
    Oceanside NY
    well "they work" OK what exactly that means and how ??
    I am sure Toyota will not waste that pieces for nothing.
  14. El Dobro
    El Dobro A Member
    7,088
    3,270
    Link on post#9 Little Miracles.
  15. szgabor
    994
    175
    Oceanside NY
    That says NOTHING how and why this should work COOL sure but WHAT those thingies DO ???
    sorry
  16. szgabor
    994
    175
    Oceanside NY
    I read that it doesn't say how and why it works one sentence "These fins streamline the airflow under the car, boosting grip and reducing wind noise" ... sure generally it has something to do with airflow but gives NO explanation or test numbers "boosting" grip from what to what at what speed ???
    Sure we can believe lexus magic and also sure they wouldn't put even that much plastic there for nothing.
    WE0H likes this.
  17. El Dobro
    El Dobro A Member
    7,088
    3,270
    I guess they just didn't want to get too technical since it's only a magazine article and it's geared towards Lexus owners. The articles also say that the air-bender design is also incorporated into the mirrors, but doesn't say exactly how.
  18. Tideland Prius
    16,559
    They're there to make the air flow exiting under the vehicle more laminar.
  19. WE0H
    WE0H Senior Member
    3,247
    528
    Does that mean smoother airflow? :)
    Mike
  20. David Beale
    5,963
    1,989
    Edmonton Alberta
    Laminar flow means minimal turbulence, which most would consider "smoother".
    But I still think those tiny fins would have very little effect at any air speed you could drive a Prius at. Just look at how big rear "spoilers" have to be to have an effect at legal speeds!
    But the Prius is at the 99th percentile level re aero effects, so I guess the engineers would be happy with 1-2%.
