The Little Fins Under The Car
Discussion in 'Gen 3 Prius Main Forum' started by El Dobro, May 18, 2013.
  1. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    They are right next to the wheels and the coils of the suspension which is creating a "tiny little bit" of turbulence ... so these things would "smooth" the airflow at most in the middle third at best.
    Again surely they do something I am just skeptical about the real effect your 1-2% is a number 1-2% of what ? ... Do you mean mpg or just air resistance?
  2. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    Air resistance. Would have almost no effect on fuel use. There are too many variables to even measure that!
    szgabor likes this.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The airflow at the rear of any vehicle is important. many piston engine airplanes have a non aerodynamic front but all have aerodynamic tails.
    Race cars are different as they are wanting downforce, not MPG.
    WE0H likes this.
  4. El Dobro
    El Dobro A Member
    7,085
    3,262
    What I was saying is that I don't remember seeing any diffusers on the back bumper, not why would there be any on it.
  5. WE0H
    WE0H Senior Member
    3,247
    528
    The Swagger has fins too :)
    Mike
    Mobile on my SGH-i717
  6. Tideland Prius
    16,540
    Yeah. I recall someone from Japan mentioning that the base models there (S Grade) don't have the underbody covers (front cover and rear skirt.. that tiny sliver of black plastic protruding from the rear bumper) and it's standard on G grades. The extra weight of the plastics apparently offset the gains in smooth air flow. Not sure how the dealer can quantify that. It's possible that Toyota is trying all sorts of methods to minimise back pressure - the longer rear spoiler, the aerocorners for the rear bumper and the underbody fins and rear skirt.
    They've even added little bumps near the mirrors in newer models. I'm sure you've heard it in advertisement for the Camry. They're called "Vortex Generators" and create "controlled" turbulent airflow along the side of the car to increase high speed stability.
  7. El Dobro
    El Dobro A Member
    7,085
    3,262
    Any pics? Lexus said they're putting air-benders on their mirrors, but I can't find a pic.
  8. WE0H
    WE0H Senior Member
    3,247
    528
    The 2013 RAV4 has them on the mirrors. I can say that rain goes perfectly horizontal across the front door windows with no mirror buffeting.
    Mike
  9. Tideland Prius
    16,540
    The fin is located near the top of the black triangle at the base of the mirror.
  10. El Dobro
    El Dobro A Member
    7,085
    3,262
    A tiny little thing, but I guess it's doing its job.
  11. Tideland Prius
    16,540
  12. szgabor
    994
    175
    Oceanside NY
  13. David Beale
    5,963
    1,988
    Edmonton Alberta
    I would have to agree. I'm sure they do -something-, but I'm also confident you (or they) couldn't measure what it is. Think golf balls. Lots, and I repeat, lots of tiny dimples help them fly farther. So one manufacturer made the dimples larger by making them hexagons so they would "nest" closer together. The ball performed "better". That is, it went about 5% farther under the same conditions. Is that "better"? Many golfers think so. They are willing to pay around three times as much for them. I just found the ball went deeper into the woods when I hit it. ;)
    szgabor likes this.
  14. WE0H
    WE0H Senior Member
    3,247
    528
    Wonder if a hailed out vehicle gets better mpg's because of lower wind drag? ;)
    Mike
  15. El Dobro
    El Dobro A Member
    7,085
    3,262
    WE0H likes this.
  16. szgabor
    994
    175
    Oceanside NY
    Yes "couldn't measure what it is." yes this is ONE of my reason to be being skeptical TWO clearly this is nothing to do with the Bernoulli principle ... so WHY bringing this up time and time again ... sure it makes a cool YouTube video but "aribenders" are NOTHING to do with that... I do understand laminar flow and why that is a good thing fighting air resistance ... but please someone should share some test data ... different speeds over drag .. if it is under controlled circumstances .. even better. Laminar flow at the operating speed of prius is a very little factor (I am not an air/flow science engineer though) anyone with those skill please comment
  17. El Dobro
    El Dobro A Member
    7,085
    3,262
    Video was in reply to WEOH's post, not this thread.
  18. WE0H
    WE0H Senior Member
    3,247
    528
    Saweet :) Wonder what a glossy finish car would look like with the dimples? 3+ mpg is a decent gain.
    Mike
  19. El Dobro
    El Dobro A Member
    7,085
    3,262
    Here you go, about 45 seconds into the video.
    retired4999 and WE0H like this.
  20. szgabor
    994
    175
    Oceanside NY
