The medieval...whatever you want to call it
Discussion in 'Environmental Discussion' started by tochatihu, Jan 27, 2013.
  1. tochatihu
    tochatihu Senior Member
    9,997
    3,862
    Kunming Yunnan China
    2001 Prius
    We touch on this often in discussing paleoclimates here. I don't mean to pick on AustinGreen particularly, but he has recently voiced the idea that calling it M. Climate Anomaly is a disingenuous change from M Warm Period. I think this is quite important to think about, and its 'mirror' the Little Ice Age (LIA; which no one has thought to rename yet :) )
    Free link to a review paper well worth a look:
    http://blog.lib.umn.edu/stgeorge/geog5426/Diaz%20Bulletin%20of%20the%20American%20Meteorological%20Society%202011.pdf
    Even though the hated Mann is among the authors, I would suggest that it is a comprehensive overview of the studies that have attempted quantifying the thing. Can't be bothered to read? Then you are stuck with my summary. It was warm and dry some places, and cold and dry in some others. Both M... and LIA were quite unusual states, to the extent those can be known from paleo records. Diaz' review (and others) suggest that oceans act differently to redistribute heat sometimes.
    I don't see that as flailing or 'we can't think of any other cause'. It is simply a reflection that oceans have massive heat-sink and heat-transfer capabilities, far greater than the atmosphere. But when the ocean will choose to exercise those capabilities in the future, I guess we haven't a clue.
    Here's how I think all this relates to anticipating climate for the rest of this century. Do these past anomalies mean that more IR-absorbing gases in the atmosphere don't absorb IR? absolutely not; that is pure physics and it happens above the oceans. Increase the IR-trapping and you increase the total energy of the system. It can't be waved away.
    BUT, where does that heat go? Not much to the atmosphere where it can be easily seen as temperature increases. Mostly to Davy Jone's locker. But that apportioning can change. Heat flow changed in the Medieval, and it changed a different way in the LIA. Thus it changes on the 1000 to 100 year time scale. Also, looking at the shorter instrumental air-T global record, we see two 'pauses' in air-T increase since 1850. Thus it changes on the 100 to 10 year time scale as well, and I have talked about them here before.
    In this way, I think that climate prediction/projection models are whacked. Because we haven't a clue as to how the oceans will handle added heat in 21st century. The models present a smooth upward T, which follows from an assumption that the ocean sloshes won't change.
    The elephant is in the room, and we are missing it. If the oceans decide to sink a lot more heat, we could get much less than 3 oC per CO2 doubling in air T. That would be great. Or, if they choose the other, we could get more on this time scale. The elephant is in the room, and it doesn't matter whether you get your facts from Henry Diaz (above) or from Sallie Baliunas.
    The climate models in IPCC AR4 were wonderful, and no doubt those in AR5 will be even more so. But I believe that they all miss the elephant. I believe that we are flying blind into our temperature future. It could be mild (+ or -), or highly disruptive.
    This is why the precautionary principle is so often invoked. Trim added atmospheric energy absorption (CO2 burn) down as quickly as possible, within economic and political constraints. It's not like we can't burn it all later, if that looks like the best plan.
    What does anyone else think that we can learn from the Medieval?
  2. bwilson4web
    16,549
    With a density two orders of magnitude greater that air, the oceans are a significant heat sink/source. However, my understanding is the maximum density is 39F and this temperature is reached fairly quickly as one descends, well below the upper mixing layers. So I'm thinking heat transfer to lower depths, this massive body of 39F water is not terribly fast.
    I tend to give it and other paleo-analysis less weight compared to modern metrics based on thermometers. I don't want to sound like 'selecting my data' but too often the paleo record looks like a secondary record. They seem to be isolated to those environments where someone has looked and/or a paleo-record environment existed.
    In contrast, modern metrics are an embarrassment of riches with orders of magnitude more detailed in time, broader area coverage, and improving accuracy. Even your work is improving our understanding of flora carbon processes which would be impossible to even investigate beyond a couple of centuries ago.
    The paleo-records were useful because they postulated the hypothesis of carbon-based, man induced global warming. Nothing in the updated paleo-records can ever extinguish that hypothesis which is now testable using modern methods.
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Would it? Why? It is not at all clear to me that detrimental climate effects are linked only to changes in air temperature. Warmer water should, from my understanding, increase ice melting in polar regions. Warmer water causes sea level rise on its own. Warmer water may change salinity and affect ocean currents. All of those would have profound impacts on climate.
    This is, for me, the key point in all of this. Flying blind in a mountainous region is just stupid. Having people in crying 'faster, faster.' is just insane.
    hyo silver likes this.
  4. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    Not a comprehensive overview ,rather yet another cherrypicking extravaganza.
    Seems your side is myopic when it comes to showing the truth about climate.
    The medieval warm period was NOT limited to Europe or even the Northern hemisphere.
    Peruse these studies from Asia, South America ,Indonesia etc.
    C3: ? Are Modern Temperatures Unprecedented
  5. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    LOL testable using what ?
    Computer models.
    There is no proof that CO2 has ever caused climate change.
    Richard C Alley
    "We dont know what causes climate change ,so it must be CO2"
    Is about the dumbest statement Ive ever heard from anyone over the age of 5 years old.
  6. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Here is my one and only point about the renaming and repurposing of paleo climate, by the claim that the medeaval warm period was small and regional and not global. The data was not there to make this claim. It said, the only way we get warm is ghg, ghg wasn't there, therefore it must have not been a warm period.
    That is the exact opposite of how science should work. If you hypothesis is that it is regional, then you get the global data, and show that it was regional. Mann and collegues, threw away the regional data by throwing out multi-proxies and choosing a single proxy, that now we have learned is not so good. Mann seems to have gotten the message that you do need to go multi proxy- and actually look, instead of claiming its all ghg from later papers. These proxies show that there was a warm period, and it seems that the hockey stick shape in global termperatures now properely has been reconstructed to include this warm period.
    As to the name and reimaginging past knowledge. Its rather offensive to me to call it the MCA, without a public apology on the part of those that wished to claim it was only local and regional. Let them do their mea culpas and tell us that you need to actually look at the data and not just your model before erasing scientific knowledge. Then I don't care about the name. But if the name is continued to be sold as a fact that we have a small group only allowed to be peer reviewed by people they select, that can erase knowledge, I'm against it. So will MR. Mann now come forth and tell us that he was wrong?
    Mr. Mann should note that some places are colder than they were 100 years ago, someone could cherry pick those and call this the modern climate anomaly.
  7. austingreen
    13,714
    4,232
    Austin, TX, USA
    Which gets us to the sciency part of the discussion. It was really cold n the ice age, then it got much warmer, then it got a little colder again in the little ice age, now it is getting warmer again. We have theories but not much is generally accepted on why it got colder after the middle ages - what ever you call the temperature - and then why is it getting warmer again after the LIA. Just claiming ghg doesn't get there, but maybe ghg plus solar radiation, plus some x factor in the ocean oscillations will get us close.
    I would say incomplete. You may say they are lacking so much that they have very little predictive power.
    Is that sarcasm?
    This is where we depart the science and enter the politics of it all. When I was growing up I thought people talked about renewables because the fuel was going to get expensive and they reduced unhealthy pollution. Now we have people against renewables because they think it will just raise taxes which the government will redistribute to people paying for the new tax law. Or they hate coal and the oil sands because the world will end if we use another lump or drop. We probably could get back to the attitude we had when I was growing up if the government would actually put out a plan without those special giveaways.
  8. bwilson4web
    16,549
    Not TRUE!
    Source:
    Richard H. Calley Obituary: View Richard Calley's Obituary by Union Leader
    Since he died, I contacted Richard using the our Ouija board and he said you're wrong.
  9. austingreen
    13,714
    4,232
    Austin, TX, USA
    lol. I think mojo meant this Alley that studies the ice, and puts together talks explaining paleo evidence of ghg based warming. He estimates the coefficient is 2.8 degrees C for doubling, most time the CO2 lags temperature, sometimes it leads.
    Richard Alley Back with More on How to Talk to an Ostrich – “It Stopped Warming in 1998″ « Climate Denial Crock of the Week
  10. bwilson4web
    16,549
    What? What! There are two of them?
    I'm dumbfounded that our anonymous 'mojo' might have posted an ambiguous name. You aren't sure which one he actually meant?
  11. tochatihu
    9,997
    3,862
    2001 Prius
    No, I was not being sarcastic about wonderful AR4 AR5 models. I think it is wonderful that they include so many processes at so many scales. I am not sure what other types of giant models might compare - computational fluid dynamics?
    But I think they are not complete in the sense that they appear to exclude changes in the patterns of ocean heat uptake and re-distribution. It would be difficult to include those things, because it seems to me we don't have the mechanisms worked out.
    I'd be more than pleased to be wrong about that. As it stands, I think that the oceans could suppress or enhance the 3 oC per CO2 doubling, on time scales of their choosing. Clearly not in human hands. The part that is in human hands is to control the rate of CO2 increase.
    Corwyn, I completely agree that the heat goes somewhere. But with vast heat capacity, the ocean T does not increase nearly as fast as air T, per megajoule added. The big impacts on steric sea-level rise and enhanced ice melt are probably on >100 year time scale, when (maybe) we will be better able to adapt. I really can't say much more than that, except reduced ocean pH may sooner hit some groups of marine life. Outside the scope here though.
    Mojo adds some to our reading list, which is all to the good. As far as cherry picking (which I'd rather call selective citation), here's the test I'd use: Which cites only examples of warming? which cites examples of both warming and cooling? See how simple that is? You don't even have to care about the authors' names or whether the list came from an affinity website or whatever.
    'Cause in graduate level courses (like this one here), we don't care. We just see who's got the data, the strong analysis. Or who fumbled the ball on the 3-yard line.
    I really feel that I am sticking my neck out here, but telling climate scientists how they ought to think about things. Because I am sure I don't know all the things that they do. I'll just but some unconventional ideas forth and ask you to hit the books.
  12. tochatihu
    9,997
    3,862
    2001 Prius
    double post
  13. austingreen
    13,714
    4,232
    Austin, TX, USA
    Your next line seemed to be that they were not predictive. A wonderful model is predictive. The closest thing to the IPCC models are econometric models. These also are not very predictive to what the economy will do.
    You can say they are evolving and have improved. I don't think these models are bad, but they are hardly wonderful.
    Now we are at the stage of making a model with incomplete data, even with incomplete mechanisms. Normally in engineering we try to back test these models against data, but.... the models were created with the data, so they will always back test.
    Alley chose the most naïve model - a straight correlation with lots of data and came up with 2.8. A good sensitivity model doesn't have to even know about all the feedback mechanisms, but it should have modeled how fast these take place. Some of the high sensitivity models seem to look at very small amounts of noisy data, and come up numbers that do not back test. They would have wiped out the medeval period and had extra ice ags.
    Global temperature only measures surface temperature - it does not measure temperature of the earth - its cooling but not linearly.
    That's one of the problems isn't it. I would consider you a climate scientist because you are measuring ghg sequestration. Others would call politicians climate scientists because they are friends with some, and they agree with the results. I would call watts a blogging weatherman. Occasionally he may hit on some real science but he is not looking for it.
  14. tochatihu
    9,997
    3,862
    2001 Prius
    In my real life, I look for what makes soil accumulate C or blow it off as CO2. The findings are quite different from mainstream literature, and I'd be well advised to focus on them rather than PriusChat. Is tying me down here your real goal, mojo? :)
    Climate (modeling) scientists have only the faintest idea of what soils 'do' and not even the faintest of the microbes that cause it. If, in the next 10 years, we can bring that in, then I might become a climate scientist by way of contributing to climate modeling.
    But mostly here lately, I have been questioning matters far outside my expertise, what the oceans do with heat and when. It is not my area, but I set aside the strong voices from both sides and just ask, what might the oceans do?
    I do not ask this because PC readers will find the missing truth. Rather, because I want them to somehow get interested in reading the lit. At least the review papers. It is a transparent ploy on my part, only justified because I want y'all to know what's happening. Work by you would be required for this.
    The alternative is sheep-mode, where we all trust the warming advocates and deniers and policy makers to somehow choose the best, low-regrets future. It is only the fear of that, that keeps me bothering y'all here.
    Because all of them suck at planning our future.
    austingreen likes this.
  15. tochatihu
    9,997
    3,862
    2001 Prius
    AG@13 "Alley chose the most naïve model"
    What other options were available? please tell.
  16. tochatihu
    9,997
    3,862
    2001 Prius
    Anyway, I am very happy that mojo has led us to
    C3
    because that site links to published papers (at least a chosen subset). Y'all should read them. Whether you accept the interpretations posted in front is up to you. Not for me to call.
    Gaps between what papers say, how they are spun in press releases, and how they are respun at affinity websites and in the media is, well, a problem. But there may be no cure other than reading enough, and thinking enough, to sort it out on your own.
  17. austingreen
    13,714
    4,232
    Austin, TX, USA
    I like the fact that he made no over reaching assumptions, it gives a base line. If we just choose the best fit over very long periods of time, what is the number. Alley says its 2.8 degrees Celsius for doubling of ghg concentration.
    Hansen on the other hand has chosen to try to guess what natures feedback is going on Unfortunately many have pointed out this leads to the angry universe scenario, there is run away feedback that should have caused many more ice ages than have happened if the very high levels of feedback really were in effect. There are a number of natures feedback that are quite non-linear though - tipping points. That would suggest that sensitivity is a function of temperature.
    If we think in terms of tipping points in terms of T (Temperature) then a lower sensitivity to ghg would, then change to gap at certain time and temperature points. Unfortunately models are weak on this temperature feedback for temperature. Data from past interglacials seems to imply that we have already reached a tipping point of temperature and ghg, and if ghg stay constant sea levels will rise a great deal over the next 1000 years. If we image that we are at or near a tipping point, then hansen's high numbers work a little better, but they really are not sensitivity. If we have passed the tipping point, we don't have very good data on how fast it will happen. Therefore the best strategy might be mitigation, shifting of crops, moving people away from rising sea levels, building sea walls. It can't hurt to reduce rising ghg, but if the tipping point has already been breached it won't really help either. Since we don't know so many things other than that fossil fuels will get more expensive in the future, it seems prudent to use less of them.
    Corwyn likes this.
  18. tochatihu
    9,997
    3,862
    2001 Prius
    “Using data to attribute episodes of warming and cooling in instrumental records”
    Ka-Kit Tung and Jiansong Zhou
    PNAS in press, doi:10.1073/pnas.1212471110
    This paper so related to my ‘the ocean sloshing is a big player in air-T trends’, that some might suppose I took it as inspiration. I just found it this morning, honest. I think we are going to be hearing a lot about it, so why not start here. First a quote from the summary:
    “The observed global-warming rate has been non-uniform, and the cause of each episode of slowing in the expected warming rate is the subject of intense debate. To explain this, non-recurrent events have commonly been invoked for each episode separately. After reviewing evidence in both the latest global data (HadCRUT4) and the longest instrumental record, Central England Temperature, a revised picture is emerging that gives a consistent attribution for each multidecadal episode of warming and cooling in recent history, and suggests that the anthropogenic global warming trends might have been overestimated by a factor of two in the second half of the 20th century. A recurrent multidecadal oscillation is found to extend to the preindustrial era in the 353-y Central England Temperature and is likely an internal variability related to the Atlantic Multidecadal Oscillation (AMO)…” (emphasis added by me)
    We see that they used HadCRUT4, and the (tightly regional) CET. Did not use BEST, and I assume that was because it has not yet been peer-reviewed published. It should be on their to-do list.
    The AMO record they use is longer than I was aware of. I guess this record comes from comparing barometric pressures at low-and high-latitude sites (That’s how ENSO is done, but there it’s east and west). Mercury column barometers have been around for a long time, and are very accurate if used carefully. So, fine there as well.
    Tung and Zhou used wavelet analysis to separate signals of different timescales. I cannot explain that technique at all, so perhaps someone else here could help?
    Beyond what I highlighted in the quote above, the authors also assert that AMO going negative could lead to slowed air-T increases in coming decades. That total solar irradiance (even though only varying from 1365 to 1366.5 watts/m2) is in synch with the long-term T trends, to which they attach meaning, although a mechanism to amplify that still eludes us. I think you can see why I expect these ideas will ‘stimulate lots of discussion’. All climate watchers here ought to read the thing. Your pirated copy is only a ‘private message’ away.
    Dr. Judith Curry, on the climate etc. website, has lamented that PNAS has lost all credibility by publishing any tattered thing that supports the warmist team. We might be looking soon for a retraction (restatement) of that.
    Meanwhile, I would not hope that anyone here thinks that a long-term T sensitivity to CO2 doubling of 3 oC only comes from Alley’s best guess. There are many such analyses from different ‘paleo records’ by different authors. AustinGreen certainly knows them, but has been slow to reveal. Mojo may not want to know them; it doesn’t matter to me.
  19. austingreen
    13,714
    4,232
    Austin, TX, USA
    [quote="tochatihu, post: 1730989, member: 1392
    Meanwhile, I would not hope that anyone here thinks that a long-term T sensitivity to CO2 doubling of 3 oC only comes from Alley’s best guess. There are many such analyses from different ‘paleo records’ by different authors. AustinGreen certainly knows them, but has been slow to reveal. Mojo may not want to know them; it doesn’t matter to me.[/quote]
    Since I've been called out, I figure you want a response.
    Alley's 2.8 sensitivity doesn't come from a guess. It comes from a naïve or black box model that takes the best temperature estimates and ghg estimates and finds the mathematical best fit over very long periods of time. The long periods of time should remove most sources of natural variability but has a strong assumption that the historical record is accurate and that sensitivity is a single number.
    The IPCC 2-4.5 with a best estimate of 3 comes from looking at the accepted models in the IPCC universe. These models have been back tested with shorter run temperature estimates. We have higher confidence that these estimates are accurate since we have direct thermometer instead of indirect proxies. The sensitivity also does not need to be assumed constant for long periods of time. The shorter time period does though leave open many possible sources of error, especially not correctly modeling ocean oscillations or polltants may greatly change the sensitivity figure. It makes you want to throw up your hands and just take that black box 2.8 figure.
    Further complicating sensitivity is items in the paleo record where temperature abruptly clanged in the paleo record, mainly through ice samples. These tipping points seem to break the rules significantly on sensitivity. Since they are not well understood they can not be modeled well.
    I believe the last paper we discussed outside this thread pegged sensitivity at approximately 2.2 degrees C/doubling. That number is consistent will alley if you assume that tipping points caused the other 0.6 degrees and agrees with the IPCC range. The most likely tipping point that we may have already passed has to do with artic ice. If we have melted enough artic ice then the artic will become less reflective and heat up more. This will melt more ice, and release methane trapped in the ice. That methane release will heat up the artic more. When the methan breaks down, some of the forcing will diminish and we will go back to normal heating but at a higher temperature ghg balance.
  20. tochatihu
    9,997
    3,862
    2001 Prius
    It would take little effort for anyone here to find the many papers using paleo proxies to constrain the CO2 doubling to 3 oC, They don't all say 3, and the range may be of some interest. That is why I called back to AustinG, because Alley is often not an author and none of them are guesses. They are somebody's best informed shot. And I think that AustinG knows of them. We highly value here his reasoned assessments of carbon and energy policies, so we don't want him to fall off the cart.
    More to the point is dynamics; how fast things happen. This has been my topic recently. Paleo-analyses, by anybody, are poorly poised to help us with that. We care about that because we want to know the T trends for the next 2 decades. Probably less so, for the following 6 decades, and much less for the century after. So we have 3 oC per doubling, and it is +/- a lot, but we want to know how fast it comes to us.
    Paleo doesn't say. Climate models, driven by radiative transfer, say they do, but I think they are poor with the ocean. I thought they failed with the instrumental-T records, and Tung and Zhou (above) may have put a finer point on that. But still, nobody is able to tell us how the ocean may mitigate IR-heat trapping in the near future. NOBODY, and I think that puts us in a poor position.
    So, what's the plan? Do more energy conservation that will save money regardless of CO2 and T? It is amazing to me that we are not. Do more renewable E that looks costly now, but might look very wise in a future where CO2 and T begin to bite? Sounds 'precautionary', but global economics are sluggish just now. It would require strong leadership.
    I think that there is a fair chance that the oceans could suck it down and make the next 2 decades T increase slow. The intentionally self-misinformed may take that as proof that CO2 does not absorb energy. Even more exciting, the oceans could suck down even more and ruin my 'every decade warmer than the previous' idea. More important, it would make the IPCC models look stupid. It would challenge us all, very severely, to plan a good CO2 path going forward.
    Because as the oceans have stored heat in the past, later they have released it. On any time scale you might care to look. So if we get some slower warming soon, we will get faster later. Could cause problems.
    Which reminds me, I should trouble you all someday with a thread here that 'Gaia is whacked'. Plants on earth are evolving on a suicide mission to create an environment where they cannot ultimately survive (4 big evolutionary jumps since the oxygen revolution). Volcanoes (we should say plate tectonics) oppose that, in a complicated way, but neither could possibly 'care' about the other. Meanwhile, Milankovich cycles just continue, and the oceans follow thermodynamics as well as they can within flow limitations. None of these care about the others. Briefly, there is no Gaia, and we are all just damn lucky to be on a planet where several amazing coincidences have prevailed.
    You wanna massively mess with that, by quickly putting fossil C back in the atmosphere? Good idea? Are you SURE? What makes you sure?
    Corwyn likes this.
