The miracles of Traction control
Discussion in 'Prius v Main Forum' started by Stevevee, Dec 12, 2013.
  1. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I think where the Prius TCS tends to drop the ball is when the car stops moving. Of course it can be argued that the car would stop moving in the same situation without TSC too, it would just be busier while not moving.
  2. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Test # 1: In very light fluffy snow-covered rods, no issue. As I always due in a new car, I "Tested" it out ;)
    Nice turning and bite from the General Alti-Max Arctics. No sway or drift in corners, stopped in a dead straight line. Absolutely no issue getting going on an incline after green light. I floored it, and it clawed its way up with no fuss.
    38.9 mpg on a snowy night doing my testing ritual at 10 degrees. Defroster had to be blasted all the way.
    Had fun, and the handling was reassuring.
  3. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    Is there absolutely no way to turn off Traction Control on the Prius v? I tried the procedure that supposedly worked on the older Prius and that did not work.
    I realize now that we were fortunate that our Prius v wasn't needed during periods last winter when we had multiple 12 inch snow storms. I certainly never thought about this "feature" on the warm August 2012 day we bought the car.
    It seems odd that traction control can be turned off on some front wheel drive hybrids made by Toyota (e.g. Lexus ES300h) and not on others but maybe their drive systems are sturdier. We've had traction control on other vehicles from Toyota and all have had off buttons.
  4. Flying White Dutchman
    4,376
    314
    o_O energy crisis over :p
  5. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    I got it turned off using procedure from this thread: Disabling traction control | PriusChat
    step 3 gave me the most problems.
    Remember to press brake (and have parking brake on just in case) when you move gear switch lever to Neutral and hold it until an lights up on instrument panel for step 3.
    Good luck.
  6. Offline
    646
    240
    Lenexa, Kansas
    to
    Nope, the instructions at the link you provided did not work on our Prius v Five with ATP. I had already found similar and identical instructions outside the Priuschat forum and they didn't work either.
    If you have been successful, would you please create instructions that are specifically for a Prius v which does not have an ignition switch to turn and which has a Park button instead of a Park position on the gear shift?
    Thanks!
  7. Makaru
    Makaru Junior Member
    51
    2013 Prius v wagon
    I tested it out to see if it could be done. I don't plan on using it (unless in the most dire of emergency situations) as I don't want any expensive transaxle repairs, so use at your own risk.
  8. Air_Boss
    Air_Boss Senior Member
    4,261
    1,197
    New Yawk
    But why would spinning wheels create transaxle damage? Isn't the purpose of getting out of traction control to spin the wheels?​
    As you can see, users are not supposed to defeat traction control, that is why it is not in the manual, and is ridiculously complicated, they hope you never use it to spin the wheels. The mode is there for mechanics, who may need to defeat Traction Control during repairs.
    Do not expect warranty service if you defeat the Traction Control and break the $5000 transaxle. (I am guessing there is a 0% chance that it is not logged in memory)
    Read more: http://priuschat.com/threads/disabling-traction-control.99926/#ixzz2oDBz1oKA
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
  9. Stevevee
    821
    224
    Vermont
    There's lots to learn in the Prius world.
  10. Air_Boss
    4,261
    1,197
    New Yawk
    Lots to inadvertently damage, too.
  11. Stevevee
    821
    224
    Vermont
    Mine is pretty decent with four new snows in the snow. But the Camry Hybrid with the same snows is more stable, better traction on the ice, less TC meddling.
    Today is interesting, both vehicles have about 3/4 inch of ice on them. The big tractor across the street just got stuck, and they're putting chains on now:( Nothing will do very well out there today until it warms a bit.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Won't defeating the traction control in this way store a fault code in memory that the dealer can read later ?
    Possible void warranty ?
  13. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Just to clarify, there's no such thing as "voiding a warranty". The laws are very clear on that. In order to deny a warranty claim the dealer has to demonstrate that the failure resulted from the owner's actions. So in this case, if you destroy your drive train while having TC disabled, yes the dealer might balk at fixing it. (and rightly they should). But having TC disabled is not in and of itself a reason for a dealer to deny warranty coverage of any issue.
    That said, I still don't think anyone has yet posted a scenario where disabling TC will necessarily be a good or even helpful thing to do.
  14. Makaru
    51
    2013 Prius v wagon
    Dealer try to put all they can as warranty claims. It's the manufacture (who really is the one paying for it) who balks and may deny the claim
  15. Stevevee
    821
    224
    Vermont
    So while all of this is going on today, I had to get two Toyota hybrids out of our driveway, which unfortunately, has an incline. My Prius first had to go through ice extraction. Every last square inch of the car,m including the tires, was covered in a sheet of ice. Almost a full inch of ice in the rear, and there was a full foot of snow, hardened sleet and ice on the hood. The Camry hybrid wasn't as bad, since it hadn't sat there for 3 days.
    Both cars have this marvelous traction control, neither has a button to turn it off. They both finally made it out, after chopping, rocking, praying, swearing. My neighbor got his 2001 VW Beetle out on the first try.
  16. Stevevee
    821
    224
    Vermont
    It's an extremely important and helpful thing if your front tires are on ice. One of the reasons they tweaked the over-agressive Prius TC way back when. It's embarrassing when you car can't get out of its driveway, it really is. Not much of a problem in New Mexico, but it is here.
  17. Makaru
    51
    2013 Prius v wagon
    We had major freezing rain storm last night. Kept one car in the garage but the Prius V was out all night. Decided to put a tarp over it that covered the windshield and the drivers door and window. Just used something to weigh it down an bit on the roof and the ice did the rest. Made one heck of a difference in the morning. Instead of chopping through a ton of ice had a nice clear windshield and door opened perfecty
  18. Stevevee
    821
    224
    Vermont
    I wish I hadn't used my tarp for another purpose, lucky you. Great idea. Took me about 30 minutes to open the door. I turned the temp up to 80 so the hybrid wouldn't fight against me too much.
  19. fuzzy1
    10,723
    Maybe that 30 minutes of work might convince you that just one tarp is not enough.
    Stevevee likes this.
  20. Offline
    646
    240
    Lenexa, Kansas
    Thank you for the instructions! But they still do not work to turn traction control off on our U.S. spec Prius v Five/ATP.
    I'm glad this issue came up. I verified that the 2014 Toyota Highlander Hybrid Limited we are buying has a button that can turn traction control off, let VSC continue to operate with TRAC off or turn both TRAC and VSC off.
    I guess I will be shuttling my wife when there is heavy snow.
    As I said before, it seems odd that there is no button for turning Traction Control off like there is on other Toyota and Lexus hybrid vehicles. Maybe it was a cost saving move or maybe the Prius drivetrain is more fragile than that on other Toyota/Lexus hybrids.
