The mysterious "B"
Discussion in 'Gen 2 Prius Main Forum' started by lbligh, Oct 18, 2005.
  1. lbligh
    lbligh Member
    137
    24
    Northern Virginia
    Complete truthfulness, and no fair looking it up before you vote!
  2. MBranstein
    MBranstein New Member
    288
    Prospect, KY
    Well, I'm sure that most of us have asked the question at least once....so the poll is a little misleading.
    For me, I called toyota directly because my sales rep told me it was a "backup" switch. I said that was "weird" (nice talk for "stupid") because there was a "R" for reverse already.
  3. LaughingMan
    LaughingMan Active Member
    1,386
    Marlborough, MA
    Engine braking. No regeneration advantage, but helps you keep off the physical brakes.
    That being said, I'm rarely in a situation where I have to use them for anything.
  4. aka007ii
    aka007ii New Member
    482
    Santa Clarita, CA
  5. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    WRONG!!!
    It's for making those tailgaters have to slam on their brakes without the leisure of seeing taillights!! :p
  6. Mystery Squid
    Mystery Squid Junior Member
    Welp, it depends on the time frame.
    When I first bought my Prius, I DID NOT immediately know, until I either thought about it for a while, or found out here. It's not an intuitive thing...
  7. Jaguar88
    Jaguar88 Member
    172
    La Crescenta, CA
    I think there is some regeneration in the 'B' mode. I have two purple bars when I start off in the morning. By the time I get to the freeway I have 8 green bars and I always use 'B' mode so I don't have to use the brakes.
  8. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    It's more or less the equivalent of shifting into the "L" or "2" selection on an ordinary automatic tranny, basically low gear. For coasting down long, steeper inclines without accelerating, or riding the brakes.
  9. Porridge
    Porridge New Member
    91
    The B is an abbreviation for "bugger" which is what you say when your knee hits it and the cruise control setting turns off.
  10. itstwowords
    itstwowords New Member
    30
    Indianapolis
    I live in the Whatalyer mountain range in Indiana, and frequently use B, though it is quite annoying to have the cruise pop off.
    I also have no clue why Toyota would design a car that "forgets" what the cruise speed was set to just because the car temporarily slows below 24 MPH. Most of my driving is in a semi-rural area where the traffic lights / stop signs are one mile apart, and I have to keep setting the cruise to 38 MPH every mile. (38 seems to maximize my EV mode.)
  11. MarkR
    MarkR New Member
    Okay, "B" does give more gegeneration than coasting, use it for slowing down or long downhill runs where you want to keep the speed down.
    As for the cruise control. Toyota designed to to lose its pre-set so that you have to manually accelerate to your desired speed as opposed to just clicking in the resume.
    The thinking behind this is that as a driver you would accelerate slower, the cruise would detect that you have a pre-set of 110kmh and hammer the car to get there.
    Mark
  12. Frank Hudon
    Frank Hudon Senior Member
    4,147
    way too funny...........ur sick! :rolleyes:
  13. Jerry W
    Jerry W Junior Member
    35
    Linton, nr Maidstone, Kent, England
    Hi Mark
    B mode does give more regeneration than coasting with the brakes off; but it gives less regeneration than gentle braking does. This was clearly established long ago by Wayne Brown, who in fact produced a table showing the amount of regeneration (in Ahr) produced by B, coasting and several levels of braking. I no longer have the table, and all I can remember is that gentle braking (50mph to 0 in about 30seconds) was most efficient of all. Hard braking was worst, followed by B, then coasting...
    Your theory about Toyota's thinking re cruise control is presumably just that - a theory. My own theory is that there are just too many circumstances in which accelerating from a very low speed or zero, no under driver control, would be potentially dangerous. It is a safety, or "anti-litigation" measure...
    Jerry
  14. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Was his table on the Classic, or the 2G? 2G changed the braking system quite a bit, which may also affect B. Classic used some friction brakes at all times when applied, where 2G waits until actually needed.
  15. ColdWhiteMilk
    ColdWhiteMilk New Member
    While I know it is a ower gear for battery recharge on steep declines without the brakes, I enjoy telling people that when I move it into "B", that a booger flicks out the back of my Prius and onto the windshield of the tailgater behind me.
  16. Rocketeir
    Rocketeir New Member
    28
    Edgewater, Florida
    That's good, but I think I will tell people that D is for Drive, B is for Backup and R is for Race.
    That is if I get my Super White 06/06 Monday from DeLand (FL) Toyota as promised!
    Regards,
    Steve
  17. benighted
    benighted New Member
    530
    Westport, WA
    You are going to let them drive it after you tell them that, right? :lol:
  18. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    "Whatalyer mountain range in Indiana" Inteesting! I grew up in Ohio and drove all over the Mid West when young and had a chance to see Indiana, Michigan, Ohio mountains. I even skied on a few. Then I moved west. That was then this is now. I have to say I have never seen a "mountain" range in Ohio, Indiana, Michigan and Illinois. No disrespect but everything is relative, and a mountain has snow on it 24-7- 365.
