The "no arrow" display
Discussion in 'Gen 2 Prius Main Forum' started by bcmarks, May 10, 2006.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(darelldd @ May 11 2006, 10:44 PM) [snapback]253930[/snapback]</div>
    Yes, it's from the CAN-View. It varies a little from 5-7 amps for slower speeds and around 12 amps for higher speeds.
    Depending upon what all is turned on (ie. AC, headlights, stereo, etc) the baseline draw when at a full stop is 1.5-3.5 amps, so when in a no-arrows glide there's still another 3-4 amps being sent.....somewhere. I think it's probably to drive the motors, but I really can't say that with certainty.
  2. IFixEm
    IFixEm New Member
    69
    a gallon south of Microsoft
    <div class='quotetop'>QUOTE(efusco @ May 11 2006, 09:10 PM) [snapback]253939[/snapback]</div>
    It is the drive motors (I think) even though there are no arrows.. Try looking at MG1 and MG2 torque +/- numbers, not amps. I'm not sure if can view does that yet. THHS obviously will. I can't miss this opportunity for a plug for the canview. They are nice.
    Regards, mike
  3. darelldd
    6,059
    389
    Northern CA
    Interesting! Thanks guys. So as with other MFD situations, what you see isn't quite what you get. Kinda tempers the nirvana.
    The 1-4A at rest is reassuring. That's the same with an EV depending on the other loads that are on. Lowest is about 1A. Of course that 1A is at almost 400V in my case.
    I would LOVE to have CAN-view... but as far as I know it still isn't available for teh 2006, right?
  4. IFixEm
    IFixEm New Member
    69
    <div class='quotetop'>QUOTE(darelldd @ May 11 2006, 10:12 PM) [snapback]253962[/snapback]</div>
    The thing is, with the light glide portion of P&G you are also scrubbing a "touch of regen" off the top, so to speak. Again the MFD is quiet. Think of the screen as your electrical tachometer. In other cars with factory tachs it is sometimes hard to detect the a/c on, idle up bump because it is only 40 rpm. Factory meters aren't so accurate. Like the prius fuel meter... (ducking and running). I had a bit of an awakening after finally opening one. I have had significant electrical training over the years but I had forgotten one basic fact I learned as a kid. Magnets are strong. It took a significant ammount of finger strength for me to get MG2 to turn by hand. In fact most people reading this would require a full hand grip to get it spinning. Once you have it going you can keep it going fast with the same finger effort as very lightly snapping your fingers. When I stopped feeding it, it did not really want to stop. When it did stop, it rocked in the forward and backward direction in a diminshing 30* arc for nearly 1/2 a second as it fought the approach and departure angles of different magnetic fields. This magnet weighs in at 12-15 pounds (guessing).
    Regards, Mike
  5. vtie
    vtie New Member
    436
    Gent, Belgium
    <div class='quotetop'>QUOTE(darelldd @ May 12 2006, 05:44 AM) [snapback]253930[/snapback]</div>
    Yes, I know. An electric motor can easily have an efficiency of >90%. But, in the Prius, all the energy ultimately comes from the gas engine. So, regardless the efficieny of the electric motor, the cycle gas engine -> dynamo -> batteries -> electric engine -> wheels will always be significantly less efficient than gas engine -> wheels (at constant speeds).
    I agree 100% about the regeneration. I think this is the real beauty of the Prius, and it gives a big advantage for city driving. Also, while accelerating and decellerating, there might be a point in using the regenerator as a regulator to keep it at optimal efficiency.
    But, at constant speeds, why would the engine ever be in an inefficient RPM regime? With my manual 6-speed diesel car, I keep it nicely at 1300-1600 revs/min when I drive at constant speeds for an extended period, the sweet spot for fuel consumption for that engine. I then consistently observe smaller fuel consumptions than with the Prius at the same speed. I understand and appreciate the beauty of the regenerative hybrid system for changing speeds, but I still don't see any advantages for constant speeds, apart from the fact that the manufacturer can put a smaller gas engine in the car and still have adequate acceleration performance.
  6. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(efusco @ May 12 2006, 01:10 PM) [snapback]253939[/snapback]</div>
    [/b][/quote]
    The 5-7 amps observation is another symptom of the simplified MFD function.
    You could see 0 amp if you release the accelerator a little and the MFD still shows no arrow.
    We see about 1 amp when we put in neutral without AC, headlights and others.
    Ken@Japan
    <div class='quotetop'>QUOTE(darelldd @ May 12 2006, 02:12 PM) [snapback]253962[/snapback]</div>
    Prius is also about 1A lowest at about 230V.
    Attila wrote very nice program running on Sharp PDA.
    http://vassfamily.net/ToyotaPrius/CAN/cindex.html
    There are a lot of Japanese users of the program and we enjoy the screen.
    Good thing is we can see the Navi screen on the MFD. You can't see the Navi with the CAN-View screen.
    Ken@Japan
  7. efusco
    19,891
    1,196
    Nixa, MO
    While Ken is correct that it is possible to feather the pedal so that you see only about -1amp it is VERY difficult and basicly impossible to hold it there. Now, at speeds under 30mph I usually see -2 to -3 amps, 30-41mph -6 amps, and 42+ -12 amps. Those are the ranges that it's fairly easy to feather into a 'no-arrows' condition. If you really focus on the display you can feather it back to the -1 to -3 range, but it's not easy and I'd say nearly impossible at any speed above 41mph.
    And yes, it's slick to have the PDA program on a seperate screen, but it's also nice to have everything fully integrated into the touch screen. Switching to the NAV is very simple and back to CAN-View is as well...if you really need the NAV up you don't need to be looking at CAN data anyway.
  8. daniel
    14,487
    1,519
    Spokane, WA
    While I have no way to view the CAN-View and the car's own Energy display simultaneously, I am skeptical of Evan's statement that there are 5 to 7 amps flowing when the MFD shows no arrows. There is plenty of current flowing in stealth mode, as the car is being powered from the battery. Do you have some way of seeing the actual amperage when the MFD is showing the Energy screen so you really know there are no arrows displayed?
    Vtie: On the highway at constant speed there is very little current flowing. As you surmise, in that situation the engine alone can operate efficiently, and in fact it provides essentially all the power. However, at slow (city) speeds no gas engine big enough to power the car is efficient. That's why conventional cars get worse mileage in the city, in spite of the virtually nil wind resistance at slow speeds. That's where it's more efficient to combine electrical and gasoline systems. On the highway, it's the smaller size of the engine that makes it more efficient, and the smaller engine is possible because the electric motors are available when more torque is needed.
  9. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(daniel @ May 12 2006, 10:35 AM) [snapback]254089[/snapback]</div>
    Daniel,
    I have about 35,000 miles of driving and practicing getting into a no arrows glide BEFORE getting the CAN-View and about 8000 miles since getting it so I know exactly how to do it, what it feels like, etc...I can actually feel the car 'give' when I've depressed the pedal enough to disingage the regenerative coasting. Further, there's a brief flash of the Energy screen when one hits the EV button so I can tell when I'm in a no arrows glide before the switch back to the CAN-View. Finally, I've switch to the Energy screen from CAN-View while gliding just to confirm the condition and it has always been as I though--in a no arrows glide. I'm absolutely certain of my numbers and that I am, in fact, in a no arrows glide when I see them.
  10. vtie
    vtie New Member
    436
    Gent, Belgium
    <div class='quotetop'>QUOTE(daniel @ May 12 2006, 05:35 PM) [snapback]254089[/snapback]</div>
    This confirms my suspicion that the electric part was doing little or nothing at constant speeds on the highway, despite the fact that you see the arrows changing all the time. It's a shame that the screen doesn't give you any quantitative measure. At the very least they should make the thickness of the arrows proportional to the strength of the energy flow.
    Anyway, we bought the car for city driving, and the hybrid system really excells here. It's hard to think of any better car for city driving: very silent, reacts quickly with the CVT, very short turning circle, and, best of all: an unbeatable mpg!
  11. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(vtie @ May 13 2006, 12:58 PM) [snapback]254781[/snapback]</div>
    While I completely understand your desire for a more detailed and informative display (thus why I bought the CAN-View, and before that the Dyno-Scan tool) it is simply information that the average driver can't use and would simply be confused by. Worst case they would misinterpret the information and alter their driving style in a way that would result in less efficient driving.
    You sound like you'd really like the more detailed information. I know that CAN-View isn't currently an option for you but many people gained a lot of information with the ScanGage device. Depending upon how technically inclined you are attilla's system to utilize a PDA or computer works perfectly and can capture everything the CAN-View does. I suggest you research those tools to help satisfy your desire for more information.
