The noise
Discussion in 'Gen 3 Prius Main Forum' started by Scott jacobson, May 15, 2022.
  1. Scott jacobson
    Scott jacobson Junior Member
    The noise I have while driving
    Will go away in accelerating or braking any checks that I can do would be appreciated
    2010 145k
    All new brakes 135k
  2. Eddie25
    Eddie25 Active Member
    503
    212
    MI
    Will need way more detail.
    Where does it sound like it's coming from?
    What does it sound like?
    Does it happen only while moving?
    Engine running and/or not running?
    ..as a start
  3. Scott jacobson
    Sounds like coming from passenger front
    Only while moving will go away with the a Touch Of accelerater or brake
    only hear when moving any speed
    Best way to discribe is like having blizak snow tires on kind of a constant noise
    52,578
    maybe a wheel bearing
  5. Eddie25
    503
    212
    MI
    If it were me, I'd pop the front passenger wheel off and do a visual inspection. Also check for play in the wheel and rotate it (before taking it off) to see if anything seems off. It sure does sound like a wheel bearing issue (I have very little experience with wheel bearing issues though). Go on youtube and search wheel bearing diagnosis videos and maybe there's something with a similar sound or you can get some info on how to test it.
  6. CR94
    CR94 Senior Member
    2,783
    1,221
    Northwestern S.C.
    Maybe, but wheel bearing noise is more typically affected by cornering than by braking or acceleration---both of which S.J. says stop the noise.
