The Official Prius SSC50P Campaign Doc
Discussion in 'Gen 2 Prius Main Forum' started by naterprius, Oct 14, 2005.
  1. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Okay, at this point there are like 5 parallel threads on this same topic...
    http://priuschat.com/index.php?showtopic=11470
    http://priuschat.com/index.php?showtopic=11419
    http://priuschat.com/index.php?showtopic=11435
    http://priuschat.com/index.php?showtopic=11450
    http://priuschat.com/index.php?showtopic=11480
    and I've already confused myself as to which one I'd posted in previously,
    and fired a followup into a different one. I suggest we pick ONE of
    the above to continue discussion, and let the others terminate here.
    How about the first of these, entitled "The Official Prius SSC50P
    Campaign Doc", which seems to have the most hard info about it?
    That's http://priuschat.com/index.php?showtopic=11470
    _H*
  2. DanP
    DanP Member
    256
    Thanks for the info. It would seem I will be getting a letter within the next two weeks or so. I called my local dealer, and, of course, they knew nothing about it. Guess I'll just wait for the letter.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Just use the last 7 digits.
  4. seasalsa
    1,278
    Kent, WA
    The info just came in to the dealers today on the west coast. I was at a dealers this morning, mentioned it to the Tech and he said that they had not heard anything yet. Pulled it up on his computer and it had just came in. Mine is included tho I have had no problem as yet.
  5. jeromep
    jeromep Member
    827
    Eastern Washington State
    I'll be devil's advocate. I'm pretty sure that you might loose a few MPG with this update. However, I'm under the impression that the computer system is adaptive. Meaning that you might be able to regain the MPG loss with driving as the computer's new programming gets accostumed to being used and learns how everything interacts and how it is to best manage all the parts and pieces of the system.
    Somebody please correct me if I'm wrong.
  6. Fredatgolf
    Fredatgolf New Member
    339
    Pinehurst
    Exact same results. hope that means we have no recall.
  7. Liam
    Liam New Member
    96
    My car is not in the listed range but it did have the stalling problem and it has already had the software update. The VIN number did come up valid.
  8. mehrenst
    mehrenst Member
    439
    San Jose, CA
    I get the same thing. I think this public site is hosed. :p
  9. Sid
    Sid New Member
    284
    Pennsylvania
    My VIN is also listed a invalid.
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    for anyone worried about it... i wouldnt fix something that aint broke. if you aint having a problem...
  11. MadHungarian
    MadHungarian Member
    139
    Atlanta and Miami Beach
    My car doesn't exit--when I enter the VIN (re-checked and re-entered several times), I receive a message saying I have entered an invalid VIN. Why might that be?
  12. MadHungarian
    MadHungarian Member
    139
    Sorry for the redundancy--the lesson learned is that one should read thru the entire thread before responding.
  13. DOC
    DOC Junior Member
    San Jose, California
    http://www.greencarcongress.com/2005/10/toyota_extends_.html
    Toyota Extends Prius Recall Globally to 160,000
    14 October 2005
    Toyota is extending its recall of 75,000 Prius hybrid in the US (earlier post) worldwide, affecting a total of 160,000 cars.
    A software malfunction in the engine control module (ECM) system in models manufactured from August 2003 through February 2005 can cause the engine to stall while driving. Limited operation via the electric motor is still possible, and the electrically-powered brake and steering operation will continue to function.
    The recall covers 70,000 Prius cars in Japan; 15,000 in Europe, Australia and other markets; and the 75,000 in the US.
  14. losaltosprius
    losaltosprius Junior Member
    You really do need 9 CHARACTERS, not digits, after the "JTDKB20U" or "JTDKB22U" in the pull down menu. Mine has a leading "X4" before the seven DIGIT number that follows which seems to correspond to the numbers in the SSC 50P pdf file.
    I made the same mistake that I suspect you made and only included numbers. When I included the complete remaining characters after the leading characters in the pull down menu, it worked fine.
    Unfortunately, I need the Engine ECM reflash, the HV ECM reflash, and the connector grease.
    Note: seasalsa was wrong when seasalsa suggested just using the last 7 digits!
  15. rogerSC
    rogerSC Member
    170
    I believe that seasalsa was referring to the initial poster's .pdf document, not the website. The document that the original poster included only allowed for 7 digits. The web site requires 9 characters. My VIN is not in the ranges listed in the document, and it is an "invalid VIN" on the website. I just did this for interest, given that it is for 2004 and early 2005. My Prius was made in June of this year, so I didn't expect to be on the list. However, "invalid VIN" is not the right message for customers.
    I might guess that they don't update the list of VIN's until they have recalls or required service for them, resulting in later VIN's "not existing".
    -Roger
  16. hobbit
    4,089
    468
    Bahstahn
    Okay, I took a look at my M5 connector today [the one that's supposed
    to get dielectric-greased as part of SSC-50P]. Presumably this is
    to help keep water out, even though it's already a "weatherproof"
    type of connector with gaskets. What I want to know is, why are the
    other, similar, and nearby connectors [M9 and M10] left un-greased?
    What's so special about M5? Any Toyota techs wanna kick this back
    to FTS and *insist* on the real answer, please?
    _H*
