The one and only Prius Plug-in FAQ!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by lensovet, Nov 24, 2012.
  1. most of us have gotten a spare and stored it somewhere. Search: spare, doughnut, quite a few threads already in archives. You can pretend that 3000 people are talking to you.
  2. Adam Leibovitch
    498
    102
    Where is the entune microphone located?
  3. lensovet
    2,615
    496
    Burlington, NJ
    Where the map lights and interior light switch (off/on/door) is located
  4. Jonas Studebaker
    Jonas Studebaker Junior Member
    93
    Maine
    Good effort, Len. Perhaps some winter-related FAQs will emerge. The other day, after six weeks of driving my new PIP, I discovered what the "B" position on the gear shifter does. I never got a tutorial from the dealer on how the batteries regenerate.
  5. lensovet
    2,615
    496
    Burlington, NJ
    Your comment makes me concerned: what do you now believe the B position does?
  6. Jonas Studebaker
    93
    Maine
    I understand it to be a simple old fashioned "jake brake" whose only benefit is to prolong brake pad life. I had been under the impression that it was a coasting-charger on steroids. Is neither accurate?
  7. lensovet
    2,615
    496
    Burlington, NJ
    I had to look up that term. For the most part, that's correct, but obviously in EV mode that isn't the most apt analogy since there is no engine running.
    I will update the FAQ shortly with a fuller explanation.
  8. lensovet
    2,615
    496
    Burlington, NJ
    i have added an explanation for the B gear along with a note about timer usage
  9. lensovet
    2,615
    496
    Burlington, NJ
    also expanded the "defog without ICE" answer to clarify that temperature must be set to LO ahead of time since this keeps coming up for some strange reason
  10. Jonas Studebaker
    93
    Maine
    As I am still in discovery mode, I might think of more for you. This is very helpful stuff, thanks. I think "jake brake" might be a Northeast term. Entering some rural towns one might see a sign for truckers" NO JAKE BRAKES." I hope I don't get busted!!
  11. John H
    John H Senior Member
    2,208
    558
    In my locale it is refered to as "engine braking" and is often restricted within municipalities for a number of reasons, one of which is the lack of a brake light warning for other drivers.
  12. lensovet
    2,615
    496
    Burlington, NJ
    Pretty sure it's always been about the noise
  13. CharlesH
    2,798
    1,166
    Roseville, CA
    I read the FAQ, and it something is not clear to me. First, there are actually three kinds of braking in the PiP: Regeneration, engine braking, friction brakes. And it is not trivial to figure out when each is applicable. When going downhill, if you engage cruise control, then the system seems to aggressively use regeneration to keep you speed at the set point, without the driver needing to engage B. And with the larger battery, it can handle a lot more hill than can the standard Prius. I think engine braking is only used if the battery is full, but I defer to others on this point. I don't think that applying the brake pedal will ever engage engine braking; it will use only regeneration and friction brakes.
  14. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    I read that there is a federal law that requires all vehicles to have an engine brake. I think it is useless/redundant in the PiP. I have not encountered any icy downhill slopes yet. I used to use the low gears in my old 1987 Buick Regal whenever the roads were icy.
  15. lensovet
    2,615
    496
    Burlington, NJ
    okay, i have updated the answer to address this.
    btw, pressing the brake pedal does seem to engage ICE in EV mode if the battery is too full. This is being discussed on the last pages of this thread: ICE in EV Mode … Again
  16. bisco
    52,780
    i think there may be a difference between engine braking (b mode) and engine burning off excess charge. i'm not sure it acts as a brake in the latter?
  17. lensovet
    2,615
    496
    Burlington, NJ
    It does indirectly, but I guess you are right. Blah, why is this so complicated lol
  18. bisco
    52,780
    complicated, but interesting!
  19. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    compleresting or intercomplicated! :)
