The one and only Prius Plug-in FAQ!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by lensovet, Nov 24, 2012.
  1. bisco
    52,888
    yes, we're up to 8 years now and a couple hundred thousand miles experience here at priuschat. lifetime? unlikely
    LAHIRU GUNASEKARA likes this.
  2. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Sure it will last a lifetime. Just unsure of whose life.
    So far 8 years and 3 months for my PIP's battery -- actually batteries. 12v is still original too.
    Mike
  3. hill
    9,041
    Yea . . . but the thing is . . . . when the capacity begins to diminish - your ICE kicks in - so many won't even notice. After all gas is inexpensive & many don't pay attention to lost capacity on an OCD level. So the question may better be framed .... how MUCH capacity will be lost - in how much time .... and in different climates. After all cooler - more temperate climates are much easier on a traction pack, than hot places are. Problem is - MOST buyers are in areas that get LOTS of summer heat - & the Prius is air cooled.
    52,888
    you will notice with a plug in, as range diminishes
  5. bisco
    52,888
    wow! i replaced my 12v a year ago, but i attribute it to sitting for two months every winter while i was in florida
    3PriusMike likes this.
  6. LAHIRU GUNASEKARA
    LAHIRU GUNASEKARA Junior Member
    Srilanka
    I have also 2012 plug-in last month I serviced it & checked the HV battery status service dealer says that I’m still having a 99.9%. Of a battery. I don’t how is going to end up the battery life.
  7. bisco
    52,888
    that's excelent! (y) i didn't even know dealers could do that
  8. hill
    9,041
    must admit - my snifOmeter did go off when I read that. Especially after all of the other Oddball things that the service centers have told me.
  9. bisco
    52,888
    1/10th of one percent per 8 years, that battery will outlive all of us put together
  10. LAHIRU GUNASEKARA
    Srilanka
    Hope long life for our Li ion batteries
  11. buta17
    buta17 Junior Member
    38
    wilminton
    2012 Aqua
    I
    I think YES!
    question: are HV and EV batteries located together? or separately ? hv near the seat, EV in cargo
  12. buta17
    38
    wilminton
    2012 Aqua
    I
    Is it possible to replace regular prius hv batteries with Plug-in's batteries?
  13. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    There is only 1 battery. It is divided by capacity.
    13% to 84% is reserved for EV.
    8% to 12% is reserved for HV.
    Above 84% and below 8% is reserved for longevity.
    buta17 likes this.
  14. buta17
    38
    wilminton
    2012 Aqua
    I
    Thank you Sir!
    PriusPiP likes this.
  15. bisco
    52,888
    no,
    there used to be some kit, but since the plug in is so cheap, they all went out of business
  16. Robert Schlitz
    Robert Schlitz Junior Member
    PA
    Would love to hear how it’s doing now in 2025? I am thinking about buying a 2014 plug in ( currently driving a gen 2 2006 with 208,000 miles. BUT i can’t plug in every day, will be a way from home for weeks. Can I drive this car as a regular hybrid and if so does it cause the battery extra wear and tear ?
  17. hill
    9,041
    Still waiting for that cheap Factor to happen to other manufacturers traction packs
  18. bisco
    52,888
    yes, you can drive it like a hybrid no problem. your biggest worry is the head gasket, followed by the brake actuator.
    i traded mine for a bolt 2 years ago because the engine was running rough, and i think the egr may have been clogged at 87,000 miles.
    do your diligence before moving ahead, all the best!
    Robert Schlitz likes this.
  19. bisco
    52,888
    what cheap factor is that?
  20. hill
    9,041
    Cheap as in compared to the Prius traction pack
