The one and only Prius Plug-in FAQ!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by lensovet, Nov 24, 2012.
  1. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    AirCon on or off?
  2. markabele
    5,084
    1,782
    Nebraska
    I'm a Realtor and home inspectors around here won't check home AC's during the winter because it can be harmful to run them while that cold. This isn't the case with car AC's?
  3. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I believe if it's too cold, to protect itself, the A/C won't even come on.
  4. zzizzy
    zzizzy Junior Member
    The link for downloading the "navigation system manual" (in the first post) doesn't seem to be working. Is this available somewhere else?
  5. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
  6. lensovet
    2,615
    496
    Burlington, NJ
    just updated the wording, is it better now?
  7. lensovet
    2,615
    496
    Burlington, NJ
    when you set vents to windshield+foot, AC turns on automatically. nothing bad will happen in cold weather with it, though you might get frostbite :p
  8. markabele
    5,084
    1,782
    Nebraska
    So you're saying it's not like a home AC where it is bad to run it under about 55 F?
  9. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Every vehicle that I've ever driven that was equipped with A/C wouldn't allow the compressor to operate below a set outside temperature determined by the mfgr, usually in the 35F range. It just won't come on. I'm certain our PHV is the same. The light may be on, but damage to the compressor is almost impossible due to cold temps.
    markabele likes this.
  10. iceobar
    iceobar Junior Member
    16
    I am curious as to the amount of kw to charge a 'normal' depleted battery. Has anyone plugged in a Kill-a-Watt meter during a complete recharge? If the PIP battery is 4.4 kw, is it really only using about 3 kw(+/-) to get its' estimated 11 mile range? Thanks.
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    It's about 2.7 - 2.8 or so to complete charge. The extra battery charge is used when EV mode is depleted and you are on HV like a regular Prius. People have read at meter, but I do not have one, so it's more of a guess for me. I'm sure someone with a meter will chime in.
  12. iceobar
    16
    Thanks!!.....just the data points I was looking for. I have called Toyota directly, multiple dealers and sales folks.....no one knew the answer.... should have come to PriusChat first.....;>)
  13. lensovet
    2,615
    496
    Burlington, NJ
    Retired, I'm not sure what you mean by your second sentence about HV mode? The battery SOC goes between 18 and 23% or so in HV mode. That's a 5% range, not an extra kWh.
    To the original question, around 30-35% I the battery is reserved as a buffer for longevity.
  14. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I believe that 23%-18% or so is going from 6 bars to 2 bars in HV mode. But it can also go up to 8 bars or about 25%.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    I'm not very good at trying to explain things, I just tried to let him know that after all your EV charge is gone the car operates like a regular Prius. Sorry! did not mean to confuse things.
  16. john1701a
    john1701a Prius Guru
    12,824
    5,306
    58
    I posted this back in September...
    The most recent real-world recharge data (fully depleted to 85% capacity) from my ChargePoint history states:
    2.911
    2.656
    2.752
    2.755
    2.872
    2.723
    2.757
    2.627
    2.777
    2.678
    2.926
    2.799
    2.832
    2.716
    2.672
    2.760
    2.787
    2.999
    2.726
    2.819
    That comes to an average of 2.777 kWh per recharge, from an L2 connection including charging losses.
    retired4999 likes this.
  17. john1701a
    12,824
    5,306
    58
    Here's the data since then, October thru the first full week of November:
    2.8
    2.856
    2.729
    2.636
    2.797
    2.78
    2.849
    2.755
    2.802
    2.782
    2.788
    2.838
    2.734
    2.89
    2.843
    2.757
    2.794
    2.796
    2.779
    2.739
    2.822
    2.601
    That comes to an average of 2.780 kWh per recharge.
    Redpoint5 likes this.
  18. john1701a
    12,824
    5,306
    58
    duplicate post
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    This is very interesting.
    Did you have the means to check the 85% full?
    Does Charge Point can give charge duration for each charge?
    Could be that the station stops charging before it is full (due to lower demand by the car charger towards the end)?
  20. john1701a
    12,824
    5,306
    58
    I have a ScanGauge and SOC % is what I routinely monitor.
    ChargePoint only provides duration info for overall connection, not draw times. It does show current draw rate via the app.
    And it is the car itself the stops recharging at 85%. That is not controlled by the charging-station.
