The overtight oil filter catridge cap......It's not the dealer's fault.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Georgina Rudkus, Sep 18, 2018.
  1. ASRDogman
    ASRDogman Senior Member
    7,592
    3,916
    Doesn't matter what the manual says. There is a BETTER tool, and correct one. Toyota does make mistakes. Like all of us.
    Correct tool for the job....
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,465
    2,429
    Taylors, SC
    Still, I'll stick with Toyota. How many oil changes have you done as opposed to Toyota dealers?
    It's like those who put 40 weight oil in a car designed for 20 weight. They think they know better. Old 1960's technologies engines had greater clearances as opposed to current engines with tighter clearances. 40 weight oil flows slower meaning that it has trouble flowing through tighter passages. Slower flow means less heat is carried away, more oil varnish and sludge.
    I'll stick with Toyota. Sure, they had the unintended consequence of the "swelling" filter cap. That's why they considered their long term findings and are addressing it by replacing the cartridge with the spin on filter element.
    #22 Georgina Rudkus, Sep 19, 2018
  3. ASRDogman
    7,592
    3,916
    30 or 40, not on mine though, but on other Toyota's.
    The guy next to me was fighting with it with his "Toyota" tool, but eventually got it off.
    So our service manager went to Toyota and asked them about the tool. And they told him about other tool.
    It was so much easier and I never had a problem removing a housing. I did have to use a 3/4 inch breaker bar a
    few time because someone over tightened it.
    You need to remove the tap that clicks into place that is supposed to keep the housing from unthreading.
    Then the tool fits good. The tool "should" press it out of the way, but it just doesn't seem to work very well.
    It's easy to remove it then re-install it after installing the housing.
    Everyone is free to use whatever tool and/or means they choose to remove the housing.
    I prefer to use the easiest and simplest way, and the correct tool for the job. :)
    jzchen likes this.
  4. Georgina Rudkus
    3,465
    2,429
    Taylors, SC
    Toyota's design with an unintended consequence with the plastic rivets holding the trailing edge of the oil change door in the Gen 3 resulted in the use of threaded bolts used to hold the oil change panel in the Gen 4. They do listen.
    I'm switching to the spin on oil filter and adapter on my next oil change.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    ASRDogman, thank you so much for sharing that it conflicts with the metal piece. I do not know how to remove it. Manual does note not to tamper with it/remove it.
    I would have switched to spin on, except the iQ can’t be switched as far as I can tell. (It looks different). And then I’d need two different tools and different filters. (I just installed a Fram Ultra for the Prius v into the iQ)....
    #25 jzchen, Sep 19, 2018
  6. ETC(SS)
    7,159
    Keep posting and the privileges will come!!
    [sarcasm font] I think that it was the hair in the photo that led to your trouble. [/sarcasm font]
    Good info on the G3's oil cartridge foibles.
    So just to be clear on this, there currently is NOT a canister filter that will fit the G3???
    How close is the one for the G4?
    'My' G3 is a work car, so for all I know it might still have the OEM filter after 145,000 miles but I'm keeping my knowledge on the XW30 as up-to-date as possible given the likelihood that I might be forced back into the world of hyper-commuting.
    The G1 Pips are a real bargain in the used car world and with everybody clubbing up to Primes and BEVs they're on sale.
    PERFECT candidate for a beater/project car!!!
  7. Georgina Rudkus
    3,465
    2,429
    Taylors, SC
    I love my dog, notwithstanding the errant hair.
  8. ASRDogman
    7,592
    3,916
    I had forgotten they put that clip on it. And I had a hard time laying on my back trying to get the tool on.
    If you tighten the housing to the correct torque, it won't come off.
    If I had a lift and the car was in the air, I'm certain it would be a lot easier.
    Next time I change my oil I'll try to remember to take a photo or video and post it. Unless someone else does it sooner.
  9. Mendel Leisk
    41,457
    I'm using a Honda oil filter socket, nothing fancy, no extensions down onto the stiffeners. It's the standard Honda automotive oil filter size. Careful measurement with a caliper, I get 64.4 mm, inside face-to-face (14 flute).
    You can use it with a 3/8" ratchet wrench (which I do), or with a 17mm socket or wrench.They used to use a larger diameter filter, and this small one was for their motorcycles. Then they went to the same filter size.
    It works fine, does not touch the little clip, I guess because it does not extend down that far. I've actually forgotten that clip is even there: it does nothing. The Honda socket is a snug fit when you push it on, can be a little reluctant to pry off. Unfortunately does not have a little opening to help pry it off. I find just levering it a bit with an extension on it, it usually comes loose.
    The last time I took off the oil filter, the O-ring had jumped the groove, was down to the end. A first for me. Still nothing leaked. I'll be checking it at next oil change, in two~three weeks. I will be very vigilant this time around. I've just noted this in the oil change instruction, not sure how much it effects, but yeah:
    Maybe that "90 degrees" matters, who knows: I will try to do that next time. And not sure what they mean by "temporarily". The instruction to make sure the O-ring does not get caught betwee the parts seems the best plan. That and ensure the O-ring is not twisted, has lots of fresh oil.
    As far as "effort" to remove or install the filter: I've done all the oil changes myself (about 15, every 6 months basically), since factory, and have always torqued to 18 foot/pounds (spec). It always takes a bit of oomph to get it started unscrewing, and continues to resist until the O-ring finally screws out of the barrel. I'm using an extra long wrench, maybe 18", and that makes it pretty easy.
    #29 Mendel Leisk, Sep 19, 2018
  10. Georgina Rudkus
    3,465
    2,429
    Taylors, SC
    I have also the Honda wrench that you specify. My husband tried it on the swollen oil cap. It was hard to fit and went on the same depth as the Toyota SST.
    When I did remove the swollen cap using the Toyota SST, I had to hammer it on. Because I was using ramps under the car, I couldn't use my 24 inch long 1/2 drive extension. I used a 1/2 inch drive Craftsman ratchet with a 3/8 drive adapter but still couldn't wrench off the cap. Not successful, I placed a foot long 1 inch aluminum cheater pipe on the end of the ratchet. That work like a charm. I could "telescope" down the assembled length to clear the concrete driveway.
    In reinstallation, I left the cap wrench on the plastic filter cap. After torqueing to 18 ft.lbs., I had to grip the hex of the cap wrench and wiggle it off with some difficulty.
    This was the method I used with the old cap. The wrench went on the new cap effortlessly during the last oil change.
    Next oil change? I'll convert to the spin on shown in the Armstrong Family blog.
  11. Mendel Leisk
    41,457
    Who put the filter on the time before, and did they do 18 foot/pound torque?
    I'm toying with the conversion to cannister oil filter, but think I'll hold off. I've never had an issue breaking it loose. However I am concerned if the O-ring continues to get mispositioned during install. I should check what the parts for conversion would cost locally through a dealership; I'll be in there in a week or two. Not sure I want to know...
    What I do like about the current filter-only setup: much easier on the recycle stream. The cannister filters are a complicated mess of metal, rubber, paper, used oil, not so good.
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    It's been quite easy for me to remove and reinstall oil filter consistently. Method is screw the oil filter back on with hand, then use 3/8" ratchet. Slowly turn oil filter until it actually comes to a stop. Before filter physically stop turning, you will hear some friction sliding. When oil filter stops turning, that's tight enough. No torque wrench needed.
    No oil leaks when I do that, and removing filter never fails with my $4.99 oil filter removal cap from China.
    RMB, Raytheeagle and xerox6135 like this.
  13. Georgina Rudkus
    3,465
    2,429
    Taylors, SC
    I did; and I torqued it to 18 ft.lbs.
  14. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    A few things, three from Mendel’s post (thank you for posting the excerpt)!
    1. Remove the old o-ring by hand, no tool that can possibly damage the cap.
    2. Clean the areas well, both engine and cap side
    3. Oil the new o-ring before installing into groove on cap
    4. Re-oil o-ring before installing the filter into the engine
    5. Temporarily hand tighten the cap until it bottoms out, but do not concurrently/immediately tighten it to spec.
    6. Take torque wrench to tighten to 25 Nm or 18 ft lbs. I was going to crack a joke that you’re all off using 18 ft lbs as this is a Japanese car that uses metric units, but I go by Nm personally....
    Every canister type filter I work with where the entire cap screws in has spec of the form XX + Y Nm, meaning you first torque to XX, then XX + Y. Here it notes hand tighten temporarily and then to 25 Nm. I’m a weakling and need a wrench to get the filter housing to bottom out, so I use a wrench. Then I switch to a torque wrench and torque it down. (Torque wrench is inconveniently long to turn to bottom out anyways).
    #34 jzchen, Sep 19, 2018
  15. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Did I mention I installed the Toyota alarm on the Prius v myself? And did I also mention that the instructions are so detailed that they include specific locations on where to install the wire ties?
    Yes, I’ll try to follow their FSM instructions to a “T”....
  16. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Dorman products makes an aluminum replacement Toyota filter cap. 917-036 I believe is the part number. That would cure the expansion of the OE phenolic cap. I’m waiting on Frankenstein’s oil change to change mine over. That should happen the end of next month, just before the cold sets in.
  17. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    cnc97, the thread does not look quite the same between the Prius’ plastic and the iQ’s metal. I do not think they are interchangeable. Is this a Prius specific replacement?
    Thanks for sharing!
  18. Mendel Leisk
    41,457
    I've tried without success to do that, lol. I just use a small, flat-blade screwdriver, very carefully.
  19. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Funny, on the iQ there is a little cut out section on the ridge, specifically for you to be able to grasp the gasket with your fingers, but on the Prius I see no reference to such a gap. I believe one time I did use some tool and risked damaging the cap. Last time I think I pulled off the nitrile glove from my hand. (I’ll let you guys know if it wasn’t worth it if I get skin cancer on my fingers/hands).
  20. Elektroingenieur
    2,515
    3,284
    Three Touring
    Indeed. The photos kindly posted by @ASRDogman show what appears to be a copy of the Kyoto Tool Co. AVSA-R64A wrench, which has slots to fit over the ribs on the outside of the filter cap. It’s described at the bottom of page 393 (PDF, in Japanese) of KTC’s Catalog No. 39 and in an instruction manual (PDF, also in Japanese). Mutsuura Honten Co., Ltd., offers them on Rakuten for ¥4633 plus shipping.
    Readers of this thread may also be interested in my notes on the recent filter design change.
