The overtight oil filter catridge cap......It's not the dealer's fault.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Georgina Rudkus, Sep 18, 2018.
  1. DPri
    DPri Junior Member
    40
    Earth
    For many Spin-on conversion won't be foolproof either ..
    Grit likes this.
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I bumped into this listing. Knowing the significant difference in applying torque to the nut vs maybe less than a cm further out, this flat top will likely ease removal.
    I currently have a newish Dorman cap and it doesn’t seem to get stuck as much to the SST.
    Tool Guy Republic Forged Chrome Vanadium Oil Filter Wrench Socket for Toyota, Lexus, Scion, Type Oil Filter Housings - 64mm 14 Flats https://a.co/d/ccitP85
  3. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    That’s still not the dealers fault for overtigjting.
  4. Mendel Leisk
    41,457
    Foolproof requires keeping your car away from fools.
  5. ChapmanF
    18,204
    Mine's not self-driving.
    If it were, I'm not sure where it would want to go.
  6. Mendel Leisk
    41,457
    In response to me?
    I was saying to be careful who you have doing your oil change.
    Merkey likes this.
  7. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I’ll stick with the og poster, not the dealer fault
  8. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    I ordered the PBT 71117, which appears very similar to that one, and has similar user reviews.
    Of course Amazon dropped the price by $2.70 shortly after I ordered it.
    #108 CR94, Jun 13, 2023
  9. AzusaPrius
    AzusaPrius Senior Member
    2,184
    920
    Check out klickwrench.com
    They have the perfect tool so you never overtighten it again and your tool will never break.
    You can use promo code "azusa" to save some $$$ Screenshot_2023-06-14-17-30-36.jpeg
    jzchen likes this.
  10. Mendel Leisk
    41,457
    Or just score a 3/8” drive torque wrench, and you can use it at various mid-range torque applications.
    xliderider and jzchen like this.
  11. DPri
    DPri Junior Member
    40
    Earth
  12. ASRDogman
    ASRDogman Senior Member
    7,592
    3,916
    You don't even need a torque wrench. Just "snug" it.
    I only had a problem removing mine the first time I did it. It was tight!
    Then put the clip back on, just in case.
    Good video though! (y)
  13. Priipriii
    Priipriii Member
    230
    67
    I normally smear some of the left over oil around the threads before i screw it back on, then hand tight it, never with a wrench. Never had a problem taking it off, nor did it ever leak. 18 ft lbs is a bit extreme for a oil filter imo
    CR94 likes this.
  14. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Yes. I assume they made the torque specification that high to assure it's fully seated even in case of a tighter-than-usual O-ring with no oil. Then idiot mechanics tighten it to several times that ample value. There'd be no problem if they'd designed the cap to have some sort of positive stop so it can't be overtightened.
  15. ChapmanF
    18,204
    That's nearly the way it is already. It turns down in with about a constant amount of force and then bonks to a stop when the flanges touch. You can put as much torque on it as you want from that point, but the extra torque barely turns it at all.
    I suspect the only way they could make that stop any more 'positive' would be to make the whole cap out of a less elastic material.
  16. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Be more creative! How 'bout a protrusion on the cap designed to barely clear a fixed protrusion exactly one revolution before hits it solidly the next time it comes around?
