The proverbial hum - or is it a whine?
Discussion in 'Gen 2 Prius Main Forum' started by lexidium, May 10, 2024.
  1. lexidium
    lexidium Active Member
    303
    143
    manchester
    Constant hum while moving.
    I've ruled out the engine. I can hear it while rolling slowly in neutral.
    The odd thing is that it stops if I'm turning left.
    What should I be looking at?
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,340
    963
    Monument, Colorado USA
    2008? Wheel bearings is my suspicion. Pretty easy to check, get the wheels off the ground and grab at 9-3 o'clock and check for movement...and same at 12-6.
  3. PriusCamper
    PriusCamper Senior Member
    13,412
    5,413
    Pacific Northwest, USA
    16 year old cars always make lots of strange noises... It's the nature of getting old as a car...
    daisy555 and ColoradoBoo like this.
  4. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    left wheel bearing......(y) betcha 2 pints mate!:p
    ColoradoBoo likes this.
  5. lexidium
    303
    143
    manchester
    I'll look into that. Cheers guys
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,013
    6,902
    Texas Hill Country
    Why do wheel bearings hum? They forgot the words..,
    Lots of Toyota wheel bearings will make noise without getting loose. Generally they get louder up to 45 mph when road noise drowns them out. Typically if the humming decreases when turning left it will be the right passenger side.
    A Toyota mechanic now on his own
    Why do customers cry after buying low cost bearings? Because they fail quickly, often within a year.
  7. highmilesgarage
    highmilesgarage Active Member
    494
    183
    Kansas City
    the 205k mile Prius I recently bought got that issue but it was really worst because the wheel bearings are grinding (not humming) The grinding creates a lot of vibrations inside the cabin and difficult to pinpoint if turning left or right makes a difference. What I did was jack up the front wheels and turn them manually. Then I tried comparing by feel which is noisy (or rough) I bought a pair of wheel hubs and did the right side (passenger) and noise is gone after install. I just keep the other wheel hub for future use (driver side is still ok) In my case the wheel wiggle test (9-3 o'clock) didn't show anything, it's still solid.
  8. ColoradoBoo
    1,340
    963
    A good trick to be able to roll down you windows and listen for various sounds is to drive behind a big, brick business, like a department store building (we have a Khols that's perfect for this.). The sound reflects nicely off the brick and even loud enough to get a video recording so you can have your mechanic listen to it. (Because we all know cars DON'T misbehave when a mechanic is there....little brats!)
    ColoradoCrow and PriusCamper like this.
