The reason CARB exists
Discussion in 'Environmental Discussion' started by bwilson4web, Oct 1, 2019.
  1. bwilson4web
    15,513
    Source: KILLCARB.ORG -
    I am not a fan of the CARB hydrogen fuel cell mistake nor their roll-over in 2000 that killed the EV1. Regardless, they seem to do more good than harm ... considering the alternatives.
    49,401
    agreed.
    like any political machine, you're better off with than without. the evil doers are lurking in the shadows just waiting for their chance :cautious:
  3. Rmay635703
    Rmay635703 Senior Member
    2,593
    1,610
    Somewhere in Wisconsin
    2013 Chevy Volt
  4. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    Complaints without suggestions don't accomplish anything.
  5. Rmay635703
    2,593
    1,610
    2013 Chevy Volt
    I suggest we oppose a constitutional convention, I rather like that CARB can stick it to the man, even if they are also misguided in their own way.
    Both cars I own would have never existed if it weren’t for carb so there is that.
  6. bisco
    49,401
    that should read 'koch'
    edit: sorry, there were two in 2017
  7. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Since it needs reminding, this is the reason CARB exists:
    And lest anyone says otherwise, CARB has been successful in reducing things like ozone:
    tochatihu, bwilson4web and john1701a like this.
  8. tochatihu
    tochatihu Senior Member
    9,046
    3,528
    Kunming Yunnan China
    2001 Prius
    Go here
    ((corrected in later post))
    Depending on parameters selected you may find that ozone has not improved much since end of charts@7.
    #8 tochatihu, Oct 2, 2019
    noonm likes this.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Link appears dead.
    But surely you don't assume population has been stagnate? Even more people, same relatively good level of low smog for an extremely densely populated area.
    And of course you always run up to diminishing returns. Making cars go from 30mpg to 40mpg is awesome but not nearly as awesome as going from 20mpg to 30mpg.
    tochatihu likes this.
  10. tochatihu
    9,046
    3,528
    2001 Prius
  11. tochatihu
    9,046
    3,528
    2001 Prius
    "But surely you don't assume population has been stagnate?" @9. This factor is surely important for any estimation of harm. I am not aware of any published study combining air-quality improvements in US areas with increasing numbers of lungs.
    Let us hope that workers in this field are as creative as toaster, and do it.
    There is probably always room for expositions on topic of fuel economy and fleet size. If only to remind folks that miles per gallon is non linear as stated @9.
  12. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Absolutely true, as we're probably reaching the limits of pollution control on gassers. We'll likely see significant further reductions in ozone only if the BEV/FCEV start becoming a significant % of the vehicles on the road in CA.
  13. tochatihu
    9,046
    3,528
    2001 Prius
    Ozone photochemistry in Calif central valley is much influenced by ag, including messy diesels. Those that are off-road vehicles are lightly regulated as I understand it.
  14. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Good point. That's also consistent with the inland areas of SoCal having worse ozone than the coasts:
    For ozone in particular, hotter temperatures due to climate change also make it worse:
