The revival of the $300 Prius
Discussion in 'Gen 2 Prius Main Forum' started by Bunce, Jan 25, 2020.
  1. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I'll be leaving this one on charge until tomorrow morning which will be about 40 hours.
    Yep, I have Hybrid reporter so will be doing a test drive and logging it. Probably this Saturday.
  2. Prodigyplace
    12,548
    11,772
    Central Virginia
    Natural selection.
    When you spend that much time flipping burgers to get a car, you want it to last. Weed out the weaker modules before they strand you. ;)
  3. Bunce
    Bunce Active Member
    322
    185
    Oregon
    We'll see what happens after the reconditioning process has been done. If some modules need to be replaced then so be it. This will answer the "what if I just reconditioned it?" question. I'll know for sure and will take the necessary steps. I don't need a car currently and have about 5 months before I will, so I have plenty of time for experimentation.
    And I don't flip burgers, I eat them...occasionally. You probably assume I'm a snotty nosed kid because I go to college, I have underwear older than some of the kids in my classes.
    Prodigyplace likes this.
  4. Prodigyplace
    12,548
    11,772
    Central Virginia
    I was mainly picking on Ray. I too attended college when older than normal. In fact, I work on staff for a University now.
  5. Bunce
    Bunce Active Member
    322
    185
    Oregon
    The adventure continues. I was just informed they were trimming trees close to the car so I should move it. It was at the end of a charge cycle anyway. Well the 12v battery was drained too low over the re-conditioning process so it's not going anywhere. I put a charger on it.
    I did have a preliminary glimpse of things to come using the Torque app. All blocks showed 16.7v except block 8, the known troublemaker, showing 15.3. That bugger's going to make me work for it. I'll have better data once I can take it for a drive.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,431
    3,304
    Madison, Wisconsin
    If it is reading 15.3 I would open it up and get rid of the outlier.
    strawbrad likes this.
  7. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Disappointingly but not at all unexpectedly, block 8 is too weak to bring back to life. We tried, we gave it the kiss of life, the defib, but alas he was too far gone. The bright side is all the others are beautifully balanced.
    I'll see if I can track down a couple of cells and will perform surgery probably next weekend.
    Also, anyone having issues with Hybrid reporter recently? It's next to impossible to get a report to load.
    I'll post some screenshots of data from my phone in a mo'.
  8. Bunce
    Bunce Active Member
    322
    185
    Oregon
    If any has tips after looking at the data please feel free to share.
    I only did a very short test drive around the neighborhood. The battery basically shut down for the end climbing back up the hill. Screenshot_20200131-102431.jpg Screenshot_20200131-102412.jpg Screenshot_20200131-102431.jpg Screenshot_20200131-102412.jpg
  9. Bunce
    Bunce Active Member
    322
    185
    Oregon
    @TMR-JWAP Is there enough info. here for you to match some cells my good Sir? I'd get 2 to replace the whole of block 8. The rest of the pack responded well so hopefully I'll only need to go in once.
  10. Prodigyplace
    12,548
    11,772
    Central Virginia
    Another possibility would be modules from Hybrid Automotive. They try to match based on vehicle mileage, IIRC.
    Bunce likes this.
  11. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Might as well replace the busbars while you're at it. Also clean the battery fan. If battery's original it will have oxidation. You can apply No-Ox to prevent the rust (photo's in my gallery). New busbars will help keep the pack balanced.
    Pixel XL ?
    Raytheeagle likes this.
  12. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I already cleaned the fan ready for the reconditioning. I do intend to clean the bus bars and smother points of contact in dielectric grease. It seems the no ox is conductive, I'll read up on that.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    If he buys 2 modules from @TMR-JWAP , he can also get some busbars :).
    Decent deal too from what I heard ;).
    A one stop shop (y).
    Prodigyplace and mjoo like this.
  14. Bunce
    Bunce Active Member
    322
    185
    Oregon
    After receiving 2 modules from TMR-JWAP, great service as usual, I replaced block 8, cleaned up the copper bars and nuts put the battery back in and fired her up. I was getting a warning triangle but no error codes. Just like on the red Prius after I balance charged that one. Weird since I had charged the 12v battery while I was rebuilding the hybrid battery.
    Block 8 was looking stronger than the existing cells so I balance charged it for about 16 hours, while that was going on I put the 12v on a low trickle charge.
    This morning I took it for a short test drive and am happy to report all seems well, although I think the 12v battery is weak and won't last a lot longer.
    In this area I need to have it emissions tested, so next on the list is new air filter, new gas, an oil change, a headlight bulb and a good highway drive to clean up the catalytic converter before heading to the testing center.
    mjoo likes this.
  15. Bunce
    Bunce Active Member
    322
    185
    Oregon
