The right clock spring
Discussion in 'Gen 3 Prius Main Forum' started by Jason Idleman, Feb 17, 2020.
  1. Jason Idleman
    Jason Idleman New Member
    Memphis tn
    2010: I bought an eBay clock spring, but it only has two wire harness sockets and the original has three. Can anyone point me to the correct clock spring that isn't $300 or more?
    I assume the third socket is for the steering wheel buttons, which is what I want to fix.
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    See my previous answer; the price may have increased a bit since then.
    52,799
    don't use chinese clock springs, they don't last. if you don't want a pricey oem, you're better off with low mile salvage if you can find one
  4. Jason Idleman
    Memphis tn
    I get that, but for the price, I could replace the clock spring 50 times and still save money. It takes less than 20 minutes to remove and reassemble.
    AzusaPrius and bisco like this.
  5. Jason Idleman
    Memphis tn
    Soni went to eBay to look for used ones. But what I found was steering angle sensors sold separately. Can I remove the angle sensors and install it on my new one?
  6. ChapmanF
    18,969
    The manual doesn't advise it, but that probably doesn't mean there's no way that can be figured out to do it successfully.
    There have been reports here of people having trouble getting successfully through the calibration after clockspring replacements though, so success might not be guaranteed.
    Jason Idleman likes this.
  7. AzusaPrius
    AzusaPrius Senior Member
    2,252
    942
  8. AzusaPrius
    2,252
    942
    The Steering Angle Sensor is attatched to the clock spring and you must put it on your new clock spring I thought I had got the wrong part but it is two separate parts that are joined. IMG-7CquJKx4Yvo1xCZF3RBAZ5.jpeg
    SFO likes this.
  9. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "It takes less than 20 minutes to remove and reassemble."
    50 x 20 minutes = 16.66 hours of your life, gone forever....
